7.2.2 Kernel Headers
If you need to compile kernel modules or similar code on your development board, you must install the Linux kernel headers. These header files contain various constant definitions, macro definitions, function interface declarations, and data structure definitions from the Linux kernel, and are essential dependencies required to compile kernel module code.
You can install the kernel headers and kernel compilation dependencies using the following commands:
sudo apt update
sudo apt install linux-headers-6.1.158-rt58
sudo apt install bison flex
After successful execution, the kernel headers will be installed under the /usr/src directory:
sunrise@ubuntu:~$ ls /usr/src/linux-headers-$(uname -r)
Documentation Makefile arch crypto include ipc mm samples sound virt
Kbuild Module.symvers block drivers init kernel net scripts tools
Kconfig System.map certs fs io_uring lib rust security usr
Do not run the make clean command inside the /usr/src/linux-headers-$(uname -r) directory, as this will break the kernel module compilation environment on your board.
If you have already executed make clean, please reinstall the linux-headers-6.1.158-rt58 package to restore the environment.
Usage Example
Hello World Kernel Module
We'll demonstrate how to use kernel headers by developing a simple Hello World kernel module. The general steps are as follows:
- Prepare the source code (using
${HOME}/test_kounder thesunriseuser as an example) - Write a Makefile to compile the driver module
- Sign the driver module
- Test loading and unloading the module
- (Optional) Configure automatic module loading at boot
Writing the Hello World Kernel Module
Open your preferred editor (e.g., VIM) and create a file named hello.c with the following content:
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Your Name");
MODULE_DESCRIPTION("Simple Hello World kernel module");
static int __init hello_init(void)
printk(KERN_INFO "Hello, World! Kernel module loaded.\n");
static void __exit hello_exit(void)
printk(KERN_INFO "Goodbye, World! Kernel module unloaded.\n");
module_init(hello_init);
module_exit(hello_exit);
This module prints Hello, World! when loaded and Goodbye, World! when unloaded.
Writing the Makefile
Open your preferred editor (e.g., VIM) and create a file named Makefile with the following content:
ifneq ($(KERNELRELEASE),)
obj-m := hello.o
else
KERN_VER ?= $(shell uname -r)
KERN_DIR ?= /lib/modules/$(KERN_VER)/build
PWD := $(shell pwd)
.PHONY := all prepare clean
all: prepare
$(MAKE) -C $(KERN_DIR) M=$(PWD) modules
$(MAKE) -C $(KERN_DIR) KERNELRELEASE=$(KERN_VER) M=$(PWD) modules_install
prepare:
$(MAKE) -C $(KERN_DIR) prepare
clean:
$(MAKE) -C $(KERN_DIR) M=$(PWD) clean
endif
PWDspecifies the source code path (i.e., the location ofhello.c);KERN_DIRspecifies the kernel source path;KERNELRELEASEis a variable defined in the top-level kernel Makefile, typically used to determine whether the current build is running under theKbuildframework;- Invoke the kernel's native
preparetarget to set up the tools required for compiling and installing kernel modules; - Invoke the kernel's native
modulestarget to compile the kernel module; - Invoke the kernel's native
modules_installtarget to install the compiled kernel module into the system's module directory.
After saving the Makefile, run the make command to compile the module and generate the hello.ko file:
sunrise@ubuntu:~/test_ko$ sudo make
make -C /lib/modules/6.1.158-rt58-DR-5.1.0-2605251554-g369e4b-gf8e87c/build prepare
make[1]: Entering directory '/usr/src/linux-headers-6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8'
SYNC include/config/auto.conf.cmd
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/confdata.o
HOSTCC scripts/kconfig/expr.o
LEX scripts/kconfig/lexer.lex.c
YACC scripts/kconfig/parser.tab.[ch]
HOSTCC scripts/kconfig/lexer.lex.o
HOSTCC scripts/kconfig/menu.o
HOSTCC scripts/kconfig/parser.tab.o
HOSTCC scripts/kconfig/preprocess.o
HOSTCC scripts/kconfig/symbol.o
HOSTCC scripts/kconfig/util.o
HOSTLD scripts/kconfig/conf
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
LEX scripts/dtc/dtc-lexer.lex.c
YACC scripts/dtc/dtc-parser.tab.[ch]
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
HOSTCC scripts/dtc/libfdt/fdt.o
HOSTCC scripts/dtc/libfdt/fdt_ro.o
HOSTCC scripts/dtc/libfdt/fdt_wip.o
HOSTCC scripts/dtc/libfdt/fdt_sw.o
HOSTCC scripts/dtc/libfdt/fdt_rw.o
HOSTCC scripts/dtc/libfdt/fdt_strerror.o
HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o
HOSTCC scripts/dtc/libfdt/fdt_addresses.o
HOSTCC scripts/dtc/libfdt/fdt_overlay.o
HOSTCC scripts/dtc/fdtoverlay.o
HOSTLD scripts/dtc/fdtoverlay
HOSTCC scripts/kallsyms
HOSTCC scripts/sorttable
HOSTCC scripts/asn1_compiler
HOSTCC scripts/sign-file
UPD include/config/kernel.release
UPD include/generated/utsrelease.h
UPD include/generated/compile.h
GEN arch/arm64/include/generated/asm/cpucaps.h
GEN arch/arm64/include/generated/asm/sysreg-defs.h
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/modpost.o
CC scripts/mod/devicetable-offsets.s
UPD scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
CALL scripts/checksyscalls.sh
CHKSHA1 include/linux/atomic/atomic-arch-fallback.h
CHKSHA1 include/linux/atomic/atomic-instrumented.h
CHKSHA1 include/linux/atomic/atomic-long.h
LD arch/arm64/kernel/vdso/vdso.so.dbg
VDSOSYM include/generated/vdso-offsets.h
OBJCOPY arch/arm64/kernel/vdso/vdso.so
make[1]: Leaving directory '/usr/src/linux-headers-6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8'
make -C /lib/modules/6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8/build M=/home/sunrise/test_ko modules
CC [M] /home/sunrise/test_ko/hello.o
MODPOST /home/sunrise/test_ko/Module.symvers
CC [M] /home/sunrise/test_ko/hello.mod.o
LD [M] /home/sunrise/test_ko/hello.ko
make -C /lib/modules/6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8/build KERNELRELEASE=6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8 M=/home/sunrise/test_ko modules_install
INSTALL /lib/modules/6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8/extra/hello.ko
SIGN /lib/modules/6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8/extra/hello.ko
DEPMOD /lib/modules/6.1.158-rt58-DR-4.0.2-2507191817-g7253c2-g30e6e8
- The kernel version shown in the output above will vary depending on your system version;
- For more details on compiling external kernel modules, please refer to: Linux Kernel Doc | Building External Modules.
Module Signing
The compiled driver module has already been automatically signed via modules_install. If you wish to sign it manually, execute the following commands:
# Create a signing script.
sunrise@ubuntu:~/test_ko#
cat << EOF > drobot-sign-file.sh
#!/bin/bash
signing_ko=\$1
output_f=\$2
if [ ! -f "\${signing_ko}" ];then
echo "\${signing_ko} not found!"
exit 1
fi
module_build_dir=/lib/modules/\$(uname -r)/build
signing_algo=\$(cat \${module_build_dir}/.config | grep -w CONFIG_MODULE_SIG_HASH | awk -F '=' '{print \$2}' | tr -d '"')
signing_key_name=\$(cat \${module_build_dir}/.config | grep -w CONFIG_MODULE_SIG_KEY | awk -F '=' '{print \$2}' | tr -d '"')
signing_key_f=\${module_build_dir}/\${signing_key_name}
signing_key_x509_f=\${module_build_dir}/certs/signing_key.x509
if [ -z "\${output_f}" ];then
echo -n "Saving signed module to \${signing_ko} ..."
else
echo -n "Saving signed module to \${output_f} ..."
fi
\${module_build_dir}/scripts/sign-file \${signing_algo} \${signing_key_f} \${signing_key_x509_f} \${signing_ko} \${output_f}
echo "Done!"
EOF
sunrise@ubuntu:~/test_ko# chmod +x ./drobot-sign-file.sh
sunrise@ubuntu:~/test_ko# ./drobot-sign-file.sh hello.ko
Saving signed module to hello.ko ...Done!
If you load the driver module without signing it, the following error will occur:
ERROR: could not insert module hello.ko: Required key not available
Load the module
Load the ko: modprobe hello
sunrise@ubuntu:~/test_ko# sudo modprobe hello
Check if the ko is loaded: lsmod | grep hello
sunrise@ubuntu:~/test_ko# lsmod | grep hello
hello 262144 0
Unload the ko: modprobe -r hello
sunrise@ubuntu:~/test_ko# sudo modprobe -r hello
[ 3136.909409] Goodbye, World!
Run the command dmesg to view the kernel log messages as follows:
sunrise@ubuntu:~/test_ko$ dmesg | tail -n 2
[ 525.710661] Hello, World! Kernel module loaded.
[ 612.716435] Goodbye, World! Kernel module unloaded.
Configure automatic loading at boot
Create a new configuration file with the .conf extension under the /lib/modules-load.d directory, for example hello.conf. Add the name of the module you want to load automatically in this configuration file (without the .ko extension). For example, to automatically load hello.ko, add a line containing hello. If multiple modules need to be loaded, you can list each module on a separate line in a single configuration file. You can easily create and configure the file using the following command:
sudo echo hello > /lib/modules-load.d/hello.conf
Third-party kernel driver module compilation example
Disclaimer:
D-Robotics assumes no responsibility for the development/maintenance of any third-party driver modules.
D-Robotics is not liable for any issues arising from running third-party source code on the D-Robotics platform.
PCAN
- Please ensure your RDK development board is properly connected to the internet and can access the PCAN official website. For example, use the command
ping peak-system.com. Sample output is as follows:sunrise@ubuntu:~$ ping peak-system.com -c 5
PING peak-system.com (37.202.3.222) 56(84) bytes of data.
64 bytes from r2096.agenturserver.it (37.202.3.222): icmp_seq=1 ttl=45 time=280 ms
64 bytes from r2096.agenturserver.it (37.202.3.222): icmp_seq=3 ttl=45 time=279 ms
64 bytes from r2096.agenturserver.it (37.202.3.222): icmp_seq=4 ttl=45 time=278 ms
64 bytes from r2096.agenturserver.it (37.202.3.222): icmp_seq=5 ttl=45 time=277 ms
--- peak-system.com ping statistics ---
5 packets transmitted, 4 received, 20% packet loss, time 4024ms
rtt min/avg/max/mdev = 277.180/278.460/280.280/1.152 ms - According to the official
peak-systeminstructions, download thepcan-kernel-version.shscript and confirm the driver version you need to download:# Download pcan-kernel-version.sh
wget https://www.peak-system.com/fileadmin/media/linux/files/pcan-kernel-version.sh.tar.gz
# Extract script
tar -xzf pcan-kernel-version.sh.tar.gz
# Run the script
./pcan-kernel-version.shinfoD-Robotics RDK Super series only supports Linux kernel version 6.1.
- Download the PCAN driver:
# Depending on the actual internet environment, the download may take minutes to hours
wget --content-disposition https://www.peak-system.com/quick/PCAN-Linux-Driver- The
--content-dispositionoption: saves the file locally using the filename provided by the server;
- The
- Extract the PCAN driver archive. Here we use the PCAN driver version "8.20.0" released on 2025-08-16 as an example. Please adjust the command according to the actual file you downloaded:
tar -xzf peak-linux-driver-8.20.0.tar.gz - Compile the driver:
# Install local module build prerequisites
sudo apt install flex bison -y
# Install PCAN driver prerequisites
sudo apt install libpopt-dev -y
# Setup local module build environment
sudo make -C /usr/src/linux-headers-$(uname -r) prepare
# Build PCAN Driver modules
cd peak-linux-driver-8.20.0
make
# Install PCAN drivers and libraries
sudo make install
- Sign and use the PCAN driver. The following example uses PCAN driver version 8.20.0, where the driver modules are installed by default to
/lib/modules/6.1.158/misc/:- Create a signing script as described in the Module Signing section;
- Run the signing command:
# Sign file
sudo bash drobot-sign-file.sh /lib/modules/6.1.158/misc/pcan.ko - Use the PCAN driver:
# Insert PCAN driver
sudo insmod /lib/modules/6.1.158/misc/pcan.ko
- Use the PCAN driver. The following example uses PCAN driver version 8.20.0, where the driver modules are installed by default to
/lib/modules/6.1.158/misc/:# Insert PCAN driver
