7.2.9 Bluetooth Initialization Guide
This chapter describes the initialization process and usage of the Bluetooth feature on the development board.
Overview
The development board supports connecting Bluetooth modules through USB or UART interfaces. At system startup, the hobot-bluetooth service automatically detects and initializes Bluetooth devices.
Supported Bluetooth Types
TypeInterfaceDescription
USB BluetoothUSB interfaceBluetooth adapter connected through a USB interface
UART BluetoothUART serial portBluetooth module connected through a UART serial port (such as CYW55560)
System Services
hobot-bluetooth Service
Bluetooth initialization is managed by the hobot-bluetooth.service system service, which runs automatically at system startup.
Service configuration file location: /lib/systemd/system/hobot-bluetooth.service
[Unit]
Description=Hobot init Bluetooth
Before=getty.target system-getty.slice
After=hobot-loadko.service
StartLimitIntervalSec=60
StartLimitBurst=5
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/etc/init.d/hobot-bluetooth start
ExecStop=/usr/bin/hciconfig hci0 down > /dev/null 2>&1
TimeoutStartSec=1min
Restart=on-failure
RestartSec=5
[Install]
WantedBy=multi-user.target
Service Management Commands
# Check service status
systemctl status hobot-bluetooth
# Start service manually
sudo systemctl start hobot-bluetooth
# Stop service manually
sudo systemctl stop hobot-bluetooth
# Enable auto-start at boot
sudo systemctl enable hobot-bluetooth
# Disable auto-start at boot
sudo systemctl disable hobot-bluetooth
Initialization Script Description
Initialization Flow
The Bluetooth initialization script /usr/bin/startbt.sh detects and initializes Bluetooth devices in the following order:
│ Bluetooth init start │
│ Detect USB Bluetooth │
│ (lsusb -t | grep btusb) │
USB detected USB not detected
│ Load btusb │ │ Detect UART BT │
│ driver module│ │ (/dev/ttyS1) │
│ UART detected UART not detected
│ │ GPIO control │ │ Exit with │
│ │ FW download │ │ error │
│ │ hciattach │ │ │
│ hciconfig hci0 up │
│ hciconfig piscan │
│ Init complete │
USB Bluetooth Initialization
When a USB Bluetooth device is detected, the initialization flow is as follows:
# 1. Load the btusb driver module
modprobe btusb
# 2. Wait for firmware loading to complete
sleep 3
# 3. Enable the Bluetooth device
hciconfig hci0 up
sleep 2
hciconfig hci0 piscan
UART Bluetooth Initialization
When a UART Bluetooth device is detected, the initialization flow is as follows (using XM612 as an example; if you use a different Bluetooth module, contact the module vendor for details):
# Configuration parameters
BT_REG_GPIO=427 # Bluetooth enable GPIO
UART_PORT="/dev/ttyS1" # UART port
UART_BAUD=921600 # Baud rate
FW="/lib/firmware/cypress/CYW55560A1.hcd" # Firmware path
# 1. Export and configure GPIO
echo 427 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio427/direction
# 2. Reset the Bluetooth module
echo 0 > /sys/class/gpio/gpio427/value
sleep 1
echo 1 > /sys/class/gpio/gpio427/value
sleep 2
# 3. Download firmware
mbt download /lib/firmware/cypress/CYW55560A1.hcd --autobaud3M
mbt update_baudrate 921600
# 4. Start HCI attach
hciattach -s 921600 /dev/ttyS1 any 921600 &
# 5. Enable the Bluetooth device
hciconfig hci0 up
Bluetooth Firmware
Firmware Storage Paths
Bluetooth firmware is stored in the following directories:
Chip ModelFirmware Path
Realtek RTL8852BTU/lib/firmware/rtl_bt/rtl8852btu_fw.bin
Realtek RTL8723BS/lib/firmware/rtl_bt/rtl8723bs_fw.bin
Cypress CYW55560/lib/firmware/cypress/CYW55560A1.hcd
View Loaded Firmware
# View rtl_bt firmware
ls -la /lib/firmware/rtl_bt/
# View cypress firmware
ls -la /lib/firmware/cypress/
Bluetooth Status Query
View Bluetooth Devices
# List Bluetooth devices
hciconfig
# View detailed Bluetooth device information
hciconfig hci0
Example output:
hci0:   Type: Primary  Bus: USB
BD Address: 00:11:22:33:44:55 ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN ISCAN
RX bytes:1234 acl:0 sco:0 events:456 bytes:789
TX bytes:987 acl:0 sco:0 commands:123 errors:0
View Bluetooth Device Properties
# View Bluetooth device status
hciconfig hci0 status
# View Bluetooth device address
hciconfig hci0 | grep "BD Address"
Bluetooth Operation Commands
Enable/Disable Bluetooth
# Enable Bluetooth device
sudo hciconfig hci0 up
# Disable Bluetooth device
sudo hciconfig hci0 down
# Enable scan mode
sudo hciconfig hci0 piscan
# Disable scan mode
sudo hciconfig hci0 noscan
Bluetooth Scanning
# Scan nearby Bluetooth devices
hcitool scan
# Scan BLE devices
hcitool lescan
Bluetooth Pairing
# Pair using bluetoothctl
bluetoothctl
# In the bluetoothctl interactive interface:
[bluetooth]# power on
[bluetooth]# agent on
[bluetooth]# default-agent
[bluetooth]# scan on
[bluetooth]# pair XX:XX:XX:XX:XX:XX
[bluetooth]# trust XX:XX:XX:XX:XX:XX
[bluetooth]# connect XX:XX:XX:XX:XX:XX
FAQ
Bluetooth Device Not Recognized
If the Bluetooth device is not recognized, check the following:
  1. Check service status
  2. Check device connection
    # USB Bluetooth
    lsusb
    # UART devices
    ls -la /dev/ttyS*
  3. Check driver modules
    lsmod | grep bt
Firmware Loading Failed
If firmware loading fails:
  1. Check whether firmware files exist
  2. Check kernel logs
    dmesg | grep -i bluetooth
    dmesg | grep -i firmware
UART Bluetooth Initialization Failed
If UART Bluetooth initialization fails:
  1. Check GPIO status
    cat /sys/class/gpio/gpio427/value
  2. Check UART port permissions
    ls -la /dev/ttyS1
  3. Manually test UART
    stty -F /dev/ttyS1 921600
    cat /dev/ttyS1 &
    echo "test" > /dev/ttyS1
Manually Reinitialize Bluetooth
If you need to manually reinitialize Bluetooth:
# Stop the Bluetooth service
# Disable the Bluetooth device
# Unload the driver module
sudo rmmod btusb
# Reload the driver
sudo modprobe btusb
# Start the Bluetooth service
