8.2.10. sample_usb_cam_4k60 使用说明
8.2.10.1. 程序功能
sample_usb_cam_4k60程序完成sensor、MIPI CSI 、SIF、 ISP 、VENC、USB模块的初始化,实现从sensor实时采集数据,到编码器编码输出,通过usb模块传输到pc端预览视频的功能
软件框图如下所示:
../../_images/4k_60_usb_pipeline.png
8.2.10.2. 功能使用
程序部署
把 sample/sample_usb_cam_4k60/out目录通过winscp等工具拷贝到板子的/userdata目录,进入板子的/userdata/out目录执行sh run_usb_cam_imx415.sh可以把程序运行起来,运行结果如下:
root@x3sdbx3-samsung2G-3200:/userdata/out# cd /userdata/
root@x3sdbx3-samsung2G-3200:/userdata/out# sh run_usb_cam_imx415.sh
run_usb_cam_imx415.sh: line 17: can't create /sys/bus/platform/drivers/ddr_monitor/read_qos_ctrl/all: Permission denied
run_usb_cam_imx415.sh: line 18: can't create /sys/bus/platform/drivers/ddr_monitor/write_qos_ctrl/all: Permission denied
>>>>>>>>>>>>> g1 is exist. delete it!
Detecting platform:
 board : Hobot XJ3 SOC SDB
 udc   : b2000000.dwc3
Stopping the USB gadget
usb-gadget is not running
Detecting platform:
 udc   : b2000000.dwc3
show user config:
USB_VID: 0x1d6b
USB_PID: 0x0102
SERIAL: 0x6856e824
MANUF: hobot
PRODUCT: xj3
USE_UVC: true
USE_HID: false
USE_UAC1: false
USE_UAC2: false
USE_ADB: false
USE_MSD: false
USE_ACM: false
USE_RNDIS: false
USE_ECM: false
Creating the USB gadget
Loading composite module
Creating gadget directory g_comp
OK
init configfs...
Setting Vendor and Product ID's
OK
single function gadget
Setting English strings
OK
Creating Config
Init functions...
funciton_init, but do nothing, please init on demand
OK
Bind functions...
bind uvc...
Creating UVC gadget functionality : uvc.0
sh: 0: unknown operand
OK
waiting
OK
Binding USB Device Controller
OK
usb-gadget start succeed.
Open config file ./config/vin_vps_config_usb_cam.json success
Open config file1 ./config/vin_vps_config_usb_cam.json
Can not find key: tailWeight
Can not find key: manualTimeCount
Can not find key: autoTimeCount
Can not find key: manualAeM1
imx415_init_3840x2160_60_fps_linear_setting OK!
hb_vps_init grp_attr.maxW = 3840, grp_attr.maxH = 2160
chn_attr.width = 3840,chn_attr.height = 2160
set ipu chn Attr ok: GrpId = 0, chn_id = 2, chn_attr.enMirror = 0
start grp ok: grp_id = 0
vps1 us0 factor:0 x:0 y:0 w:968 h:544
vps1 us1 factor:0 x:0 y:0 w:968 h:544
vps1 us2 factor:0 x:0 y:0 w:968 h:544
vps1 us3 factor:0 x:0 y:0 w:968 h:544
vps1 us4 factor:0 x:0 y:0 w:968 h:544
vps1 us5 factor:0 x:0 y:0 w:968 h:544
vps1 us0 factor:0 x:0 y:0 w:648 h:364
vps1 us1 factor:0 x:0 y:0 w:648 h:364
vps1 us2 factor:0 x:0 y:0 w:648 h:364
vps1 us3 factor:0 x:0 y:0 w:648 h:364
vps1 us4 factor:0 x:0 y:0 w:648 h:364
vps1 us5 factor:0 x:0 y:0 w:648 h:364
try to construct empty ring queue##function uvc_gadget_init in
udc_find_video_device g_webcam
function name not matched. g_comp
:g_webcam
udc_find_video_device g_comp
using uvc device: /dev/video8
###uvc_gadget_init###
width: 1280
height: 720
format: 2
io_method: 0
bulk_mode: 1
nbufs: 2
mult: 0
burst: 9
speed: 1
mult_alts: 0
h264_quirk: 0
maxpkt_quirk: 3072
uvc device is dwc3-gadget on bus gadget
uvc open succeeded, file descriptor = 22
uvc_size=4, maxpkt_size=3072
##function uvc_gadget_init succeed
##function uvc_gadget_start in
##function uvc_gadget_start succeed
##function uvc_loop in
dev->mask (0x0), entity_id(1), setup_ops((nil)), app doesn't care
control request (entity_id 01 req 86 cs 04)
send real error code last prepared(06)
control request (entity_id 00 req 81 cs 02)
control request (entity_id 01 req 86 cs 09)
control request (entity_id 01 req 86 cs 0b)
control request (entity_id 01 req 86 cs 0f)
dev->mask (0x0), entity_id(2), setup_ops((nil)), app doesn't care
control request (entity_id 02 req 86 cs 02)
control request (entity_id 02 req 86 cs 03)
control request (entity_id 02 req 86 cs 06)
control request (entity_id 02 req 86 cs 07)
control request (entity_id 02 req 86 cs 08)
control request (entity_id 02 req 86 cs 09)
dev->mask (0x0), entity_id(4), setup_ops((nil)), app doesn't care
control request (entity_id 04 req 85 cs 01)
运行效果说明
通过Potplayer播放器选择UVC Camera,分辨率选择H264 3840x2160P 60,打开设备就可以播放UVC视频流,打开视频流后x3侧的打印如下图:
20220523-173933
potplayer跑起来后的截图如下:
../../_images/20220527131109.png
8.2.10.3. 程序开发
模块划分
模块 目录 描述
头文件 inc 依赖的sensor头文件,json头文件,utils公共接口头文件,vio依赖公共头文件
vio源代码模块 src sensor源代码文件,json配置文件解析源文件,utils公共接口源文件,系统vio公共接口源文件
主程序 sample_usb_cam.cpp main函数入口
顶层源码结构
├── Makefile							#编译的主程序CMakeLists文件
├── vin_vps_config_usb_cam.json			#imx415 sensor配置文件
├── inc
│   ├── camera									#sensor依赖头文件
│   ├── json									#json依赖头文件
│   ├── utils									#编译依赖的公共头文件
│   └── vio										#x3m的vio依赖头文件
├── lib
│   ├── jsoncpp									#依赖的json库
├── libguvc.so									#4k60的usb cam依赖库
├── libimx415.so								#4k60的sensor驱动库
├── README.md									#程序说明文档
├── run_usb_cam_imx415.sh						#程序运行脚本
├── sample_usb_cam.cpp							#主程序代码
├── src
│   ├── camera									#sensor驱动配置代码
│   ├── utils									#编译依赖的公共源代码
│   └── vio										#x3m的vio依赖源文件
└── usb-gadget.sh								#4k60的usb cam驱动加载脚本
头文件结构
├── camera
│   └── camera.h						#sensor依赖头文件,增加新sensor需要修改此文件
├── json								#开源的json库头文件
│   ├── allocator.h
│   ├── assertions.h
│   ├── autolink.h
│   ├── config.h
│   ├── features.h
│   ├── forwards.h
│   ├── json.h
│   ├── reader.h
│   ├── value.h
│   ├── version.h
│   └── writer.h
├── utils
│   ├── utils.h							#ringbuf定义,dump图片视频等到文件功能的公共接口
│   └── yuv2yuv.h						#使用neon加速的yuv格式转换标准接口
└── vio
    ├── vio_cfg.h						#json配置文件解析头文件
    ├── vio_cfg_type.h					#json配置属性值头文件
    ├── vio_log.h						#打印控制头文件
    ├── vio_sys.h						#vp初始化反初始化,系统vio各模块绑定接口头文件
    ├── vio_venc.h						#X3系统编码模块初始化反初始化,启停,数据输入输出处理接口
    ├── vio_video.h						#视频格式枚举定义等通用接口
    ├── vio_vin.h						#vin结构体定义,初始化反初始化,启停,数据处理接口
    └── vio_vps.h						#vps初始化反初始化,启停,数据处理接口
源代码结构
├── camera				#sensor依赖源代码文件,增加新sensor需要在此增加对对应sensor源代码文件
│   ├── camera_base.c
│   └── camera_imx415.cpp
├── utils
│   ├── utils.cpp		#dump图片视频等到文件功能的公共接口源代码文件
│   └── yuv2yuv.c		#使用neon加速的yuv格式转换标准接口源代码文件
└── vio
    ├── vio_cfg.cpp		#json配置文件解析源代码文件
    ├── vio_sys.cpp		#vp初始化反初始化,系统vio各模块绑定接口源代码文件
    ├── vio_venc.cpp	#X3系统编码模块初始化反初始化,启停,数据输入输出处理接口源代码文件
    ├── vio_video.cpp	#视频格式枚举定义等通用接口源代码文件
    ├── vio_vin.cpp		#vin初始化反初始化,启停,数据处理接口源代码文件
    └── vio_vps.cpp		#vps初始化反初始化,启停,数据处理接口源代码文件
程序启动流程图如下:
../../_images/4k60usbcam.drawio.png
编译
当前代码通过一个Makefile文件配置编译
依赖的多媒体头文件和库文件分别在BSP SDK的appsdk目录和system/rootfs_yocto/root目录下,编译时需要注意这两个依赖目录位置是否存在
安装交叉编译工具链后,安装交叉编译工具链后,执行 make 命令直接可以编译生成 sample_usb_cam 程序
cd sample/sample_usb_cam_4k60
$ make clean # 清理源码,保持干净的代码环境
$ make
... ... # 一大段编译打印
$ ls
Makefile  sample_usb_cam  inc  README.md  vin_vps_config_usb_cam.json  libguvc.so  libimx415.so  sample_usb_cam.cpp  sample_usb_cam.d  src  lib  run_usb_cam_imx415.sh  sample_usb_cam.obj
usb-gadget.sh
$ make install # 把产出物安装到 out 目录下
添加新sensor
如果有新sensor需要调试,请参考 src/camera 目录下的源码文件,对应添加一个新的sensor配置即可。
以IMX415的camera_imx415.cpp为例说明关键代码,需要添加MIPI_SENSOR_INFO_S、MIPI_ATTR_S、VIN_DEV_ATTR_S、VIN_PIPE_ATTR_S、VIN_DIS_ATTR_S、VIN_LDC_ATTR_S的新sensor结构体变量:
../../_images/20220525-112411.jpg
../../_images/20220525-112559.png
../../_images/20220525-112809.png
../../_images/20220525-112844.png
同时需要在inc/camera/camera.h把增加的新sensor的变量extern出来如下图imx415示例
../../_images/20220525-113456.png
