Unlisted page
3.5.2 Prepare the editing environment
The editor needs an on‑device environment — expect minimum RAM, disk, and bandwidth. Check these before heavy use.
Pre-flight checklist​
ItemGuidance
DeviceSSH or Type‑C connected, shows online
StorageHeadroom for tooling + project
NetworkFirst launch must reach install payloads
OSPrefer official RDK images or team‑validated ones
Poor-fitting environments​
EnvironmentReason
Stripped imagesMay miss auto‑install deps
Heavily customized team imagesMight need manual env fixes first
Non‑RDK hostsMay work; capability per UI
Non‑standard boards: fall back to official RDK image or have a platform owner prep the host.
Extensions​
Most mainstream extensions work; a few need uncommon system bits and may fail on‑device. If install fails, substitute an alternative or stick to core editing, terminal, and debug.
