1.4 Supported Hardware
RDK Studio offers the most comprehensive support for the RDK series development boards, while also allowing SSH access to standard Linux hosts, Jetson, Raspberry Pi, Rockchip, and other devices.
You can think of the RDK as the primary development board and other Linux hosts as remote development environments.
RDK Device Support​
ItemRDK X3RDK X5RDK S100 / S100P
Flashing MethodTF card flashingTF card flashing; models with eMMC can use the eMMC processS100 flashing process; the page will guide you to prepare xburn
Type-C Direct ConnectionNot supportedSupportedSupported
OpenClaw DeploymentSupported, requires SSH access to the deviceSupported, requires SSH or Type-C access to the deviceSupported, requires the device to be online with network access
This table only describes the support for common features in RDK Studio.
For hardware specifications such as memory, storage, and interfaces, please refer to the official pages:
General SSH Devices​
The SSH Device option in "Add Device" is a general entry point, not limited to RDK. The following devices can be used as remote hosts:
Device FamilyAvailable CapabilitiesLimited Capabilities
General Linux HostMoss, terminal, files, code editor, project workspaceRDK-specific flashing, BPU/TROS knowledge, OpenClaw device deployment
NVIDIA JetsonMoss, terminal, files, code editor, project workspaceRDK-specific flashing and some board-side capabilities
Raspberry PiMoss, terminal, files, code editor, project workspaceRDK-specific flashing, OpenClaw deployment limitations
Rockchip BoardsMoss, terminal, files, code editor, project workspaceRDK-specific hardware knowledge and flashing process
RDK Studio distinguishes between "RDK development boards" and "Linux hosts" based on detection results.
Some features are only displayed on RDK or board-type devices, such as Wi-Fi configuration, Type-C direct connection, BPU temperature, and the OpenClaw installation entry.
Pay Attention to hbm When Running On-Device AI Models​
hbm is the model file format used by the RDK's on-board BPU, typically with a .hbm file extension. It is only relevant to on-device AI inference and is not prerequisite knowledge for connecting devices or using RDK Studio.
If you are only logging in, flashing, adding devices, opening terminals, transferring files, using remote desktop, or working with local large language models, you can ignore hbm for now.
hbm becomes important when you run on-device AI examples like YOLO, detection, segmentation, or deploy your own models to the BPU: different RDK boards require corresponding hbm files and cannot be used interchangeably.
  • hbm files for RDK X3 cannot be directly run on RDK X5 / S100.
  • hbm files for RDK X5 cannot be directly run on RDK X3 / S100.
  • The RDK S100 series also requires using the corresponding compiled model artifacts.
If you encounter issues like hbm version mismatch, model incompatible, or model loading failures, first verify whether the model has been recompiled for the current board type.
For detailed troubleshooting, see 5.5 Cannot load hbm model.
Recommendations for Choosing Connection Methods​
ScenarioRecommended Entry
Known IP, device supports SSHAdd Device → SSH Device
RDK X5 / S100 is near the computer, no LAN IP availableAdd Device → RDK Type-C Direct Connection
Only want to view boot logs or the system network is unreachableTerminal or Add Device → Local Serial Logs
Need to flash a new systemFlash → Select Device → Select Image
Non-RDK Linux hostAdd Device → SSH Device
Serial connection is not a complete device access method. It only opens a local serial terminal, suitable for viewing boot logs or troubleshooting network-unreachable devices. File management, Moss, OpenClaw, and the code editor still require adding the device via SSH.
