Instance Segmentation - Ultralytics YOLO11
This example shows how to run the YOLOv11 instance segmentation model on the BPU. It supports image preprocessing, inference, and post-processing (parse outputs and overlay colored segmentation masks). The sample code is located in /app/cdev_demo/bpu/03_instance_segmentation_sample/02_ultralytics_yolo11_seg/.
This example shows how to run the YOLOv11 instance segmentation model on the BPU. It supports image preprocessing, inference, and post-processing (parse outputs and overlay colored segmentation masks). The sample code is located in /app/cdev_demo/bpu/instance_segmentation_sample/ultralytics_yolo11_seg/.
Model Description
Overview:
Ultralytics YOLO11 is a lightweight object detection and instance segmentation model based on the YOLO series, combining anchor-free and anchor-based ideas with distributional regression. This model is the instance segmentation variant, supporting simultaneous output of bounding boxes, class probabilities, and high-quality pixel-level masks, suitable for multi-object detection and segmentation in real-time scenarios.
- HBM model name: yolo11n_seg_nashe_640x640_nv12.hbm
- HBM model name: yolo11n_seg_nashp_640x640_nv12.hbm
Input format: NV12 image (Y/UV separated), size 640x640
Output:
Object detection results (bounding box + class + score)
Instance segmentation masks (one mask per object)
Feature Overview
Model loading
Load the quantized Ultralytics YOLO11 instance segmentation model and parse runtime metadata.
Input preprocessing
Scale the input BGR image to 640×640 and convert it to NV12 format (Y and UV planes separated) to meet model input requirements.
Inference execution
Trigger the forward pass via the
.infer()method. Outputs include multi-scale class scores, bounding box regression, mask coefficients, and global mask prototype tensors. -
Result post-processing
Filter detection candidates using thresholds and decode bounding boxes and mask coefficients;
Merge outputs from all scales and apply NMS to select final targets;
Reconstruct each object's mask from mask prototypes and coefficients;
Scale masks and bounding boxes back to the original image size;
Optional morphological operations (opening) to refine mask edges;
Final output includes bounding boxes, classes, scores, and pixel-level instance masks.
Environment Dependencies
Before building and running, ensure the following dependencies are installed:
sudo apt update
Directory Structure
|-- CMakeLists.txt # CMake build script
|-- README.md # Usage instructions (this file)
|-- inc
| `-- ultralytics_yolo11_seg.hpp # YOLO11_Seg inference wrapper header (load/preprocess/infer/post-process interfaces)
`-- src
|-- main.cc # Program entry: parse arguments, run full pipeline, save visualization
`-- ultralytics_yolo11_seg.cc # YOLO11_Seg inference: decoding, NMS, mask generation, scaling, etc.
Build the Project
- Configure and build
mkdir build && cd build
cmake ..
make -j$(nproc)
Model Download
If the model is not found at runtime, download it with the following command:
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolo11n_seg_nashe_640x640_nv12.hbm
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s600/ultralytics_YOLO/yolo11n_seg_nashp_640x640_nv12.hbm
Parameter Reference
--model_path | Model file path (.hbm) | /opt/hobot/model/s100/basic/yolo11n_seg_nashe_640x640_nv12.hbm |
--test_img | Input test image path | /app/res/assets/office_desk.jpg |
--label_file | Class label file path | /app/res/labels/coco_classes.names |
--score_thres | Confidence filter threshold (boxes below this are discarded) | 0.25 |
--nms_thres | IoU threshold (intra-class NMS to remove duplicate detections) | 0.7 |
--model_path | Model file path (.hbm) | /opt/hobot/model/s600/basic/yolo11n_seg_nashp_640x640_nv12.hbm |
Quick Start
Run the model
Make sure you are in the
builddirectory -
Use default parameters
./ultralytics_yolo11_seg -
Run with custom parameters
./ultralytics_yolo11_seg \
--model_path /opt/hobot/model/s100/basic/yolo11n_seg_nashe_640x640_nv12.hbm \
--test_img /app/res/assets/office_desk.jpg \
--score_thres 0.25 \
--nms_thres 0.7./ultralytics_yolo11_seg \
--model_path /opt/hobot/model/s600/basic/yolo11n_seg_nashp_640x640_nv12.hbm \
--nms_thres 0.7
View the results
After a successful run, the result is drawn on the original image and saved to
build/result.jpg.[Saved] Result saved to: result.jpg
Notes
The output is saved as
result.jpgfor you to inspect. -
For more deployment options or model support information, refer to the official documentation or contact platform technical support.
License
