Object Detection - Ultralytics YOLOv5x
This example shows how to run image object detection on the BPU using a quantized Ultralytics YOLOv5x model. It supports preprocessing, post-processing, NMS, bounding box drawing, and result saving. The sample code is located in /app/cdev_demo/bpu/02_detection_sample/01_ultralytics_yolov5x/.
This example shows how to run image object detection on the BPU using a quantized Ultralytics YOLOv5x model. It supports preprocessing, post-processing, NMS, bounding box drawing, and result saving. The sample code is located in /app/cdev_demo/bpu/detection_sample/ultralytics_yolov5x/.
Model Description
Overview:
Ultralytics YOLOv5x is a high-performance object detection model. The name stands for "You Only Look Once," meaning a single forward pass performs object localization and classification. YOLOv5x is the largest variant, with more network parameters and higher detection accuracy, suitable for scenarios that require high precision. The model maps the input image to multiple grids, with each grid predicting class labels and bounding boxes for multiple anchors. This model has been quantized to HBM format for BPU chips, with NV12 input at 672×672 resolution.
HBM model name: yolov5x_672x672_nv12.hbm
Input format: NV12, size 672x672 (Y and UV planes separated)
Output: N bounding boxes, each containing a (class index, probability, bounding box) triplet
Feature Overview
Model loading
Load the quantized Ultralytics YOLOv5x model and parse model metadata to prepare for inference.
Input preprocessing
Resize the input image to 672x672, convert it to NV12 format (Y and UV separated), and organize the input as a nested dictionary for the inference interface.
Inference execution
Run inference via the
.infer()method. -
Result post-processing
Dequantize the output tensor;
Decode YOLO outputs to obtain predicted boxes, confidence scores, and class indices;
Apply an initial filter based on the score threshold;
Apply NMS (non-maximum suppression) to remove redundant boxes;
Map predicted box coordinates back to the original image size;
Overlay detection boxes and save the result image.
Environment Dependencies
Ensure the following dependencies are installed:
sudo apt update
Directory Structure
├── CMakeLists.txt # Build configuration
├── README.md # Usage instructions
├── inc
│ └── ultralytics_yolov5x.hpp # YOLOv5x model wrapper class definition
└── src
├── main.cc # Inference entry point (parse arguments, execute)
└── ultralytics_yolov5x.cc # YOLOv5x inference logic implementation
Build the Project
- Configure and build
mkdir build && cd build
cmake ..
make -j$(nproc)
Model Download
If the model is not found at runtime, download it with the following command:
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolov5x_672x672_nv12.hbm
Model Download
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s600/ultralytics_YOLO/yolov5x_672x672_nv12.hbm
Parameter Reference
--model-path | Model file path (.hbm format) | /opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm |
--test-img | Test image path | /app/res/assets/kite.jpg |
--label-file | Class label file path | /app/res/labels/coco_classes.names |
--score-thres | Confidence threshold (filters low-score boxes) | 0.25 |
--nms-thres | IoU threshold (NMS non-maximum suppression) | 0.45 |
--model-path | Model file path (.hbm format) | /opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm |
Quick Start
Run the model
Use default parameters
./ultralytics_yolov5x -
Run with custom parameters
./ultralytics_yolov5x \
--test-img /app/res/assets/kite.jpg \
--score-thres 0.25 \
--nms-thres 0.45./ultralytics_yolov5x \
--nms-thres 0.45
View the results
After a successful run, detection boxes are drawn on the original image and saved to
build/result.jpg.[Saved] Result saved to: result.jpg
Notes
The output is saved as
result.jpgfor you to inspect. -
For more deployment options or model support information, refer to the official documentation or contact platform technical support.
License
