Object Detection - Ultralytics YOLO11
This example performs image object detection with the Ultralytics YOLO11 model using C/C++. It supports image preprocessing, inference, post-processing (including decoding, confidence filtering, and NMS), and result image saving. The sample code is located in /app/cdev_demo/bpu/02_detection_sample/02_ultralytics_yolo11/.
This example performs image object detection with the Ultralytics YOLO11 model using C/C++. It supports image preprocessing, inference, post-processing (including decoding, confidence filtering, and NMS), and result image saving. The sample code is located in /app/cdev_demo/bpu/detection_sample/ultralytics_yolo11/.
Model Description
Overview:
Ultralytics YOLO11 is a lightweight anchor-based object detection model that combines anchor-free and anchor-based ideas, offering fast inference and accurate localization. During the regression stage, it uses discrete regression bins combined with softmax classification and decoding to improve localization accuracy. Ultralytics YOLO11 is suitable for deploying small models in real-time scenarios such as security monitoring and industrial inspection.
- HBM model name: yolo11n_detect_nashe_640x640_nv12.hbm
- HBM model name: yolo11n_detect_nashp_640x640_nv12.hbm
Input format: NV12, size 640x640 (Y and UV planes separated)
Output: Multi-scale feature maps, each containing class score tensors and discrete bounding box regression tensors; final output includes bounding box coordinates, class IDs, and confidence scores
Feature Overview
Model loading
Load the quantized Ultralytics YOLO11 model and extract model metadata for the inference pipeline.
Input preprocessing
Resize the original BGR image to 640×640, convert it to NV12 format (Y and UV separated), and construct a nested dictionary input tensor for the inference interface.
Inference execution
Run the forward pass via the
.infer()method, producing classification and regression tensors at multiple scale branches. -
Result post-processing
Dequantize the output to float32;
Filter classification scores at each scale branch and keep candidate boxes above the confidence threshold;
Decode bounding boxes using the multi-bin regression algorithm;
Merge candidates from all scales and apply NMS (non-maximum suppression) to remove redundant boxes;
Map detection boxes from the model input coordinate system back to the original image size;
Optionally draw detection results and save the output image.
Environment Dependencies
Before building and running, ensure the following dependencies are installed:
sudo apt update
Directory Structure
├── CMakeLists.txt # CMake build script
├── README.md # Usage instructions
├── inc
│ └── ultralytics_yolo11.hpp # YOLO11 model wrapper header
└── src
├── main.cc # Main program entry point
└── ultralytics_yolo11.cc # YOLO11 model implementation
Build the Project
- Configure and build
mkdir build && cd build
cmake ..
make -j$(nproc)
Model Download
If the model is not found at runtime, download it with the following command:
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolo11n_detect_nashe_640x640_nv12.hbm
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s600/ultralytics_YOLO/yolo11n_detect_nashp_640x640_nv12.hbm
Parameter Reference
--model_path | Model file path (.hbm format) | /opt/hobot/model/s100/basic/yolo11n_detect_nashe_640x640_nv12.hbm |
--test_img | Input test image path | /app/res/assets/kite.jpg |
--label_file | Class label file path (one class name per line) | /app/res/labels/coco_classes.names |
--score_thres | Confidence filter threshold (targets below this are discarded) | 0.25 |
--nms_thres | IoU threshold for NMS (non-maximum suppression) | 0.7 |
--model_path | Model file path (.hbm format) | /opt/hobot/model/s600/basic/yolo11n_detect_nashp_640x640_nv12.hbm |
Quick Start
Run the model
Use default parameters
./ultralytics_yolo11 -
Run with custom parameters
./ultralytics_yolo11 \
--model_path /opt/hobot/model/s100/basic/yolo11n_detect_nashe_640x640_nv12.hbm \
--test_img /app/res/assets/kite.jpg \
--score_thres 0.25 \
--nms_thres 0.7./ultralytics_yolo11 \
--model_path /opt/hobot/model/s600/basic/yolo11n_detect_nashp_640x640_nv12.hbm \
--nms_thres 0.7
View the results
After a successful run, detection boxes are drawn on the original image and saved to
build/result.jpg.[Saved] Result saved to: result.jpg
Notes
The output is saved as
result.jpgfor you to inspect. -
For more deployment options or model support information, refer to the official documentation or contact platform technical support.
License
