Pose Estimation - Ultralytics YOLO11
This example shows how to run the Ultralytics YOLO11 pose estimation model on the BPU for human keypoint detection and visualization. It supports model preprocessing, inference, and post-processing (including keypoint decoding, bounding box drawing, and keypoint annotation). The sample code is located in /app/cdev_demo/bpu/04_pose_sample/01_ultralytics_yolo11_pose/.
This example shows how to run the Ultralytics YOLO11 pose estimation model on the BPU for human keypoint detection and visualization. It supports model preprocessing, inference, and post-processing (including keypoint decoding, bounding box drawing, and keypoint annotation). The sample code is located in /app/cdev_demo/bpu/pose_sample/ultralytics_yolo11_pose/.
Model Description
Overview:
Ultralytics YOLO11 Pose is an efficient lightweight human keypoint detection model that supports simultaneous object detection and pose estimation (multi-keypoint prediction). It integrates Distribution Focal Loss (DFL) to improve localization accuracy for both bounding boxes and keypoints, suitable for multi-person pose recognition in real-time applications.
- HBM model name: yolo11n_pose_nashe_640x640_nv12.hbm
- HBM model name: yolo11n_pose_nashp_640x640_nv12.hbm
Input format: NV12 image (Y and UV separated), size 640×640
Output:
Bounding box coordinates for each person (xyxy)
Keypoint positions (K×2, x/y coordinates)
Confidence score for each keypoint
Supports COCO human keypoint format (typically 17 keypoints)
Feature Overview
Model loading
Load the specified Ultralytics YOLO11 pose estimation model and automatically parse model metadata.
Input preprocessing
Resize the input BGR image to 640×640 and convert it to NV12 format (Y and UV separated) for model inference.
Inference execution
Run inference via the
.infer()interface. -
Result post-processing
Decode bounding boxes from multi-scale outputs (using DFL bin decoding);
Decode keypoint positions and confidence scores (K×2 + K);
Apply NMS to remove redundant detection boxes;
Map keypoint coordinates and bounding boxes back to the original image size;
Use threshold controls to display only high-confidence keypoints;
Support image visualization including detection boxes and keypoint drawing.
Environment Dependencies
Before building and running, ensure the following dependencies are installed:
sudo apt update
Directory Structure
|-- CMakeLists.txt # CMake build script: targets, dependencies, include paths
|-- README.md # Usage instructions (this file)
|-- inc
| `-- ultralytics_yolo11_pose.hpp # Model wrapper header: load/preprocess/infer/post-process interface declarations
`-- src
|-- main.cc # Program entry: parse arguments → full pipeline → save visualization
`-- ultralytics_yolo11_pose.cc # Model implementation: decoding, NMS, keypoint post-processing, coordinate restoration
Build the Project
- Configure and build
mkdir build && cd build
cmake ..
make -j$(nproc)
Model Download
If the model is not found at runtime, download it with the following command:
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolo11n_pose_nashe_640x640_nv12.hbm
wget https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s600/ultralytics_YOLO/yolo11n_pose_nashp_640x640_nv12.hbm
Parameter Reference
--model_path | Model file path (.hbm) | /opt/hobot/model/s100/basic/yolo11n_pose_nashe_640x640_nv12.hbm |
--test_img | Input test image path | /app/res/assets/bus.jpg |
--label_file | Class label file (one class name per line) | /app/res/labels/coco_classes.names |
--score_thres | Confidence threshold (detections below this are filtered) | 0.25 |
--nms_thres | IoU threshold (intra-class NMS deduplication) | 0.7 |
--kpt_conf_thres | Keypoint visualization confidence threshold (points below this are not shown) | 0.5 |
--model_path | Model file path (.hbm) | /opt/hobot/model/s600/basic/yolo11n_pose_nashp_640x640_nv12.hbm |
Quick Start
Run the model
Make sure you are in the
builddirectory -
Use default parameters
./ultralytics_yolo11_pose -
Run with custom parameters
./ultralytics_yolo11_pose \
--model_path /opt/hobot/model/s100/basic/yolo11n_pose_nashe_640x640_nv12.hbm \
--test_img /app/res/assets/bus.jpg \
--score_thres 0.25 \
--nms_thres 0.7 \
--kpt_conf_thres 0.5./ultralytics_yolo11_pose \
--model_path /opt/hobot/model/s600/basic/yolo11n_pose_nashp_640x640_nv12.hbm \
--nms_thres 0.7 \
View the results
After a successful run, the result is drawn on the original image and saved to
build/result.jpg.[Saved] Result saved to: result.jpg
Notes
The output is saved as
result.jpgfor you to inspect. -
For more deployment options or model support information, refer to the official documentation or contact platform technical support.
License
