6.3.1. Floating-point Model Preparation
Before you read this section, we recommend that you read Toolchain Operator Support Constraint List section for an understanding of the operators and constraints supported by D-Robotics. Or, after you export your ONNX model, you can first refer to the Check the Model section to check that the model can be deployed with D-Robotics support for normal conversion.
A floating-point model trained on an open source DL framework is the input to the conversion tool, which currently supports the following DL frameworks:
FRAMEWORK
D-Robotics’S TOOLCHAIN
Caffe
Supported
PyTorch
Supported (convert into ONNX)
TensorFlow
PaddlePaddle
MXNet
OTHERS
Contact D-Robotics
As shown above, the caffemodel exported from Caffe framework can be supported directly. While the models trained from PyTorch, TensorFlow and MXNet must be first converted into ONNX before using the conversion tool. Presently D-Robotics supports ONNX opset10 and opset11.
There are standard solutions to convert models of different frameworks into ONNX, refer to the following:
🔗 Pytorch2Onnx: PyTorch’s official API can support exporting models into ONNX models,
click here to see more: https://pytorch.org/tutorials/advanced/super_resolution_with_onnxruntime.html.
🔗 Tensorflow2Onnx: Conversion based on the onnx/tensorflow-onnx of the ONNX community,
click here to see more: https://github.com/onnx/tensorflow-onnx.
🔗 PaddlePaddle2Onnx: PaddlePaddle’s official API can support exporting models into ONNX models,
click here to see more: https://www.paddlepaddle.org.cn/documentation/docs/en/api/paddle/onnx/export_en.html.
🔗 MXNet2Onnx: MXNet’s official API can support exporting models into ONNX models,
click here to see more: https://github.com/dotnet/machinelearning/blob/master/test/Microsoft.ML.Tests/OnnxConversionTest.cs.
🔗 More solutions to convert models of other frameworks into ONNX, please click here:
https://github.com/onnx/tutorials#converting-to-onnx-format.
Attention
Original model limitations: ir_version≤7, opset=10 or 11, for the correspondence between ir_version and onnx version, please refer to onnx official documentation .
