6.4.2. Common Algorithm Model Samples¶
6.4.2.1. Sample Location¶
The common algorithmic model samples are located at 02_preq_examples/, 03_classification/, 04_detection/ and 07_segmentation/ folders in the horizon_model_convert_sample path.
6.4.2.2. Preparing Datasets¶
6.4.2.2.1. Dataset Download Address¶
The dataset can be downloaded from the following address.
Dataset |
Address |
ImageNet |
COCO |
VOC |
http://host.robots.ox.ac.uk/pascal/VOC/ (need to download both versions 2007 and 2012) |
Cityscapes |
CIFAR-10 |
6.4.2.2.2. Dataset Reference Structure¶
To facilitate your subsequent steps, after the dataset has been downloaded, you need to process the evaluation dataset according to the structure suggested by D-Robotics below.
6.4.2.2.2.1. ImageNet¶
imagenet/
├── calibration_data
├── ILSVRC2017_val.txt
├── val
└── val.txt
6.4.2.2.2.2. COCO¶
coco/
└── coco_val2017
├── annotations
│ ├── instances_train2017.json
│ └── instances_val2017.json
└── images
6.4.2.2.2.3. VOC¶
Attention
Please note that the VOC2012 directory currently stores two datasets, VOC2007 and VOC2012, so please follow the directory structure below for the evaluation dataset.
VOCdevkit/
└── VOC2012
├── Annotations
│ ├── 2007_000027.xml
│ └── 2012_004331.xml
├── ImageSets
│ ├── Action
│ │ ├── jumping_train.txt
│ │ ├── jumping_trainval.txt
│ │ ├── jumping_val.txt
│ │ ├── val.txt
│ │ ├── walking_train.txt
│ │ ├── walking_trainval.txt
│ │ └── walking_val.txt
│ ├── Layout
│ │ ├── train.txt
│ │ ├── trainval.txt
│ │ └── val.txt
│ ├── Main
│ │ ├── aeroplane_train.txt
│ │ ├── aeroplane_trainval.txt
│ │ ├── aeroplane_val.txt
│ │ ├── train.txt
│ │ ├── train_val.txt
│ │ ├── tvmonitor_train.txt
│ │ ├── tvmonitor_trainval.txt
│ │ ├── tvmonitor_val.txt
│ │ └── val.txt
│ └── Segmentation
│ ├── train.txt
│ ├── trainval.txt
│ └── val.txt
├── JPEGImages
├── SegmentationClass
├── SegmentationObject
└── train.txt
6.4.2.2.2.4. Cityscapes¶
cityscapes/
├── cityscapes_calibration_data
├── gtFine
│ ├── test
│ │ ├── berlin
│ │ └── munich
│ ├── train
│ │ ├── aachen
│ │ └── zurich
│ └── val
│ ├── frankfurt
│ ├── lindau
│ └── munster
├── leftImg8bit
│ ├── test
│ │ ├── berlin
│ │ └── munich
│ ├── train
│ │ ├── aachen
│ │ └── zurich
│ └── val
│ ├── frankfurt
│ ├── lindau
│ └── munster
├── license.txt
└── README
6.4.2.2.2.5. CIFAR-10¶
cifar-10/
├── batches.meta
├── cifar10_val.txt
├── data_batch_1
├── data_batch_2
├── data_batch_3
├── data_batch_4
├── data_batch_5
├── readme.html
└── test_batch
6.4.2.3. Preparing Models¶
When using the model conversion sample package, please prepare the corresponding floating-point model first.
Note
If you need to do this process in the sample folder, you need to execute the 00_init.sh script in the folder first to get the corresponding original model and dataset.
Sources and modifications (if any) of the original models, please refer to below subsections.
6.4.2.3.1. Fcos_efficientnetb0¶
Attention
This model is a trained model using the QAT method.
To achieve optimal on-board performance, we modified the
remove_node_typeparameter in the YAML file used for bin model compilation and removed theDequantizenode from the bin model.
1.Model source: Obtain from model_zoo in the OE package.
2.MD5sum code:
md5sum |
File |
be2fe17530bc366b038f5309199bf712 |
fcos_eff_b0.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.348(FLOAT)/0.349(INT8)
6.4.2.3.2. Fcos_efficientnetb2¶
Attention
To achieve optimal on-board performance, we modified the remove_node_type parameter in the YAML file used for bin model compilation and removed the Dequantize node from the bin model.
2.MD5sum code:
md5sum |
File |
58ffc007a2ab9a053a559945fb27fac8 |
fcos_eff_b2.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.447(FLOAT)/0.447(INT8)
6.4.2.3.3. Fcos_efficientnetb3¶
Attention
2.MD5sum code:
md5sum |
File |
da37796ea8f2a4a54684a2520fdd6148 |
fcos_eff_b3.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.472(FLOAT)/0.474(INT8)
6.4.2.3.4. MobileNetv1/v2¶
2.MD5sum code:
md5sum |
File |
3fd6889ec48bda46451d67274144e2a8 |
mobilenet.caffemodel |
8922f90f629d428fecf866e798ac7c08 |
mobilenet_deploy.prototxt |
54aab8425ea068d472e8e4015f22360c |
mobilenet_v2.caffemodel |
13101ee86ab6d217d5fd6ed46f7a4faa |
mobilenet_v2_deploy.prototxt |
3.Model accuracy:
MobileNetv1:0.7061(FLOAT)/0.7026(INT8)
MobileNetv2:0.7165(FLOAT)/0.7120(INT8)
6.4.2.3.5. GoogleNet¶
2.MD5sum code:
md5sum |
File |
f107ae6806ea1016afbc718210b7a617 |
googlenet.onnx |
3.Model accuracy: 0.7001(FLOAT)/0.6985(INT8)
6.4.2.3.6. ResNet18¶
2.MD5sum code:
md5sum |
File |
0904d601fc930d4f0c62a2a95b3c3b93 |
resnet18.caffemodel |
ee8ac82cd693a0fe55af42cca3fc52e5 |
resnet18_deploy.prototxt |
3.Model accuracy: 0.6837(FLOAT)/0.6831(INT8)
6.4.2.3.7. EfficientNet_Lite0/1/2/3/4¶
Attention
To quickly start running samples and avoid the risks caused by third party tools, we strongly recommend using the off-the-shelf ONNX model in the model_zoo/mapper/ directory in D-Robotics model release package. If you are interested in reproducing the model conversion process of tflite2onnx, you can still try using the below 3rd-party tool, however, we do not guarantee the quality and success of the conversion.
2.MD5sum of the converted ONNX models in D-Robotics model_zoo:
md5sum |
File |
001a329bd367fbec22b415c7a33d7bdb |
efficientnet_lite0_fp32.onnx |
1205e95aea66650c71292bde236d55a9 |
efficientnet_lite1_fp32.onnx |
474741c15494b79a89fe51d89e0c43c7 |
efficientnet_lite2_fp32.onnx |
550455b41848d333f8359279c89a6bae |
efficientnet_lite3_fp32.onnx |
bde7fe57eadb4a30ef76f68da622dcd5 |
efficientnet_lite4_fp32.onnx |
3.Download and get .tflite from the TAR package, and then convert it to an ONNX model using the tflite2onnx tool (https://pypi.org/project/tflite2onnx/).
Note that model layouts may vary by tflite2onnx version.
If the input layout of the converted ONNX model is NHWC, when building, the configure input_layout_train of the EfficientNet_Lite0/1/2/3/4 should be NHWC.
4.Model accuracy:
EfficientNet_Lite0: 0.7490(FLOAT)/0.7469(INT8)
EfficientNet_Lite1: 0.7648(FLOAT)/0.7624(INT8)
EfficientNet_Lite2: 0.7738(FLOAT)/0.7715(INT8)
EfficientNet_Lite3: 0.7922(FLOAT)/0.7902(INT8)
EfficientNet_Lite4: 0.8069(FLOAT)/0.8058(INT8)
6.4.2.3.8. Vargconvnet¶
2.MD5sum code:
md5sum |
File |
e21b8db17916f9046253bbe0bb8de3ef |
vargconvnet.onnx |
3.Model accuracy: 0.7790(FLOAT)/0.7785(INT8)
6.4.2.3.9. Efficientnasnet_m¶
2.MD5sum code:
md5sum |
File |
fc36c052c6f034c0b64a6197b91b0c62 |
efficientnasnet-m.onnx |
3.Model accuracy: 0.7973(FLOAT)/0.7916(INT8)
6.4.2.3.10. Efficientnasnet_s¶
2.MD5sum code:
md5sum |
File |
e2744bd748f4265f4488676835a6ca24 |
efficientnasnet-s.onnx |
3.Model accuracy: 0.7578(FLOAT)/0.7518(INT8)
6.4.2.3.11. YOLOv2_Darknet19¶
Attention
To quickly start running samples and avoid the risks caused by third party tools, we strongly recommend using the off-the-shelf Caffe model in the model_zoo/mapper/ directory in D-Robotics model release package. If you are interested in reproducing the model conversion process of darknet2caffe, you can still try using the below 3rd-party tool, however, we do not guarantee the quality and success of the conversion.
1.YOLOv2_Darknet19 model: Obtain from model_zoo in the OE package.
Note
As this conversion tool is a simplified version, you should modify the the .prototxt file generated by this tool before the conversion, change the 'Reshape' layer to 'Passthrough' layer, and then add an NCHW2NHWC Permute operation to the output node.
For details about the parameters of the modified Passthrough layer, refer to the yolov2.prototxt sample.
2.MD5sum code:
md5sum |
File |
7aa7a6764401cebf58e73e72fcbd2a45 |
yolov2.caffemodel |
72e9a51c1e284e4b66e69f72ca9214c8 |
yolov2_transposed.prototxt |
3.Model accuracy:
[IoU=0.50:0.95]: 0.276(FLOAT)/0.273(INT8)
6.4.2.3.12. YOLOv3_Darknet53¶
Attention
1.YOLOv3_Darknet53 model: Obtain from model_zoo in the OE package.
2.MD5sum code:
md5sum |
File |
935af6e1530af5c0017b3674adce95e9 |
yolov3_transposed.prototxt |
9a0f09c850656913ec27a6da06d9f9cc |
yolov3.caffemodel |
3.Model accuracy:
[IoU=0.50:0.95]: 0.333(FLOAT)/0.335(INT8)
6.4.2.3.13. YOLOv5x¶
Attention
1.YOLOv5x model: Obtain from model_zoo in the OE package.
Important
When cloning the source code, be sure to use v2.0 tags, otherwise the conversion may fail.
2.MD5sum code:
md5sum |
File |
2e296b5e31bf1e1b6b8ea4bf36153ea5 |
yolov5l.pt |
16150e35f707a2f07e7528b89c032308 |
yolov5m.pt |
42c681cf466c549ff5ecfe86bcc491a0 |
yolov5s.pt |
069a6baa2a741dec8a2d44a9083b6d6e |
yolov5x.pt |
To better adapt to post-processing code, before exporting the ONNX model, we modified the code at Github as follows (for more code details see: https://github.com/ultralytics/yolov5/blob/v2.0/models/yolo.py):
def forward(self, x):
# x = x.copy() # for profiling
z = [] # inference output
self.training |= self.export
for i in range(self.nl):
x[i] = self.m[i](x[i]) # conv
bs, _, ny, nx = x[i].shape # x(bs,255,20,20) to x(bs,3,20,20,85)
# x[i] = x[i].view(bs, self.na, self.no, ny, nx).permute(0, 1, 3, 4, 2).contiguous()
x[i] = x[i].permute(0, 2, 3, 1).contiguous()
Note
Remove the reshape from 4D to 5D at the end of each output branch (i.e., not splitting the channel from 255 to 3x85), then convert the layout from NHWC to NCHW before dumping.
The bottom left image displays the visualization of a certain output node before modifying the model, while the bottom right image displays the visualization of the corresponding output node after the modification.
After download, perform the pt to ONNX file conversion using the script https://github.com/ultralytics/yolov5/blob/v2.0/models/export.py.
Attention
When using the export.py script:
Because D-Robotics algorithm toolchain only supports ONNX opset 10 and 11, please modify the
opset_versionparameter in thetorch.onnx.exportas per the version you use.Change the default input name parameter in the
torch.onnx.exportfrom'image'into'data'to keep it consistent with that of in the YOLOv5s sample in the model conversion sample package.Change the default data input size in the
parser.add_argumentfrom 640x640 to 672x672 as in the YOLOv5x sample in the model conversion sample package.
3.Model accuracy:
[IoU=0.50:0.95]: 0.480(FLOAT)/0.466(INT8)
6.4.2.3.14. SSD_MobileNetv1¶
Attention
1.SSD_MobileNetv1 model: Obtain from model_zoo in the OE package.
2.MD5sum code:
md5sum |
File |
bbcb3b6a0afe1ec89e1288096b5b8c66 |
mobilenet_iter_73000.caffemodel |
3c230e4415195a50c6248be80c49882d |
MobileNetSSD_deploy.prototxt |
3.Model accuracy (mAP): 0.7342(FLOAT)/0.7277(INT8)
6.4.2.3.15. Efficientdetd0¶
Attention
2.MD5sum code:
md5sum |
File |
ec4129c4b300cd04f1e8f71e0fe54ca5 |
efficientdet_nhwc.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.324(FLOAT)/0.315(INT8)
6.4.2.3.16. CenterNet_Resnet101¶
Attention
To achieve optimal on-board performance:
We put the maxpool and sigmoid nodes into the model and specify them to be compiled as BPU nodes for reducing the amount of computation during post-processing.
We modified the
2.MD5sum code:
md5sum |
File |
db195ff784792f475e573c5126401d2a |
centernet_resnet101_coco_modify.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.342(FLOAT)/0.335(INT8)
6.4.2.3.17. Fcos_efficientnetb0¶
Attention
This model is a trained model using the PTQ method.
2.MD5sum code:
md5sum |
File |
9f9a1fe8508e2bd068e70146eb559b4f |
fcos_efficientnetb0.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.358(FLOAT)/0.351(INT8)
6.4.2.3.18. Yolov4¶
Attention
2.MD5sum code:
md5sum |
File |
aaa3c3e5e4c4c1d4830b6501b1720e4d |
yolov4_efficientnetb0.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.351(FLOAT)/0.334(INT8)
6.4.2.3.19. YOLOv3_VargDarknet¶
Attention
1.YOLOv3_VargDarknet model: Obtain from model_zoo in the OE package.
2.MD5sum code:
md5sum |
File |
fd4e46bc7c9798b51778d3aa09c5053a |
yolov3_vargdarknet53.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.335(FLOAT)/0.327(INT8)
6.4.2.3.20. Fcos_resnet50¶
Attention
2.MD5sum code:
md5sum |
File |
0218942777615fac2f54cefdac4fbfa7 |
fcos_resnet50.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.426(FLOAT)/0.424(INT8)
6.4.2.3.21. Fcos_resnext101¶
Attention
2.MD5sum code:
md5sum |
File |
4b80efd22448021721ac5a860909c59f |
fcos_resnext101.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.453(FLOAT)/0.450(INT8)
6.4.2.3.22. Unet_mobilenet¶
Attention
2.MD5sum code:
md5sum |
File |
21c6c645ebca92befbebc8c39d385c1e |
tf_unet_trained.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.6411(FLOAT)/0.6379(INT8)
6.4.2.3.23. DeeplabV3plus_efficientnetb0¶
Attention
To achieve optimal on-board performance, we modified the remove_node_type parameter in the YAML file used for bin model compilation and removed the Reshape and Cast node from the bin model.
2.MD5sum code:
md5sum |
File |
cf3a683f31b4b0ebe090647729f869d9 |
deeplabv3plus_efficientnetb0.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.7630(FLOAT)/0.7568(INT8)
6.4.2.3.24. Fastscnn_efficientnetb0¶
Attention
2.MD5sum code:
md5sum |
File |
c1ace8f08a9c7b9c91509fa68327d0c8 |
fastscnn_efficientnetb0.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.6997(FLOAT)/0.6928(INT8)
6.4.2.3.25. Deeplabv3plus_dilation1248¶
Attention
To achieve optimal on-board performance, we modified the remove_node_type parameter in the YAML file used for bin model compilation and removed the Transpose node from the bin model.
2.MD5sum code:
md5sum |
File |
ad002e572cbb49e1e99d893aac69f3e3 |
deeplabv3_cityscapes_dila1248_permute.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.7462(FLOAT)/0.7452(INT8)
6.4.2.3.26. Deeplabv3plus_efficientnetm1¶
Attention
To achieve optimal on-board performance, we modified the remove_node_type parameter in the YAML file used for bin model compilation and removed the Reshape, Cast, and Transpose node from the bin model.
2.MD5sum code:
md5sum |
File |
0a1dfd01e173c68630d9e8dc1a6036fe |
deeplabv3plus_efficientnetm1.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.7794(FLOAT)/0.7740(INT8)
6.4.2.3.27. Deeplabv3plus_efficientnetm2¶
Attention
2.MD5sum code:
md5sum |
File |
c11a2673c4b3cf6e5d7bf1a051925d38 |
deeplabv3plus_efficientnetm2.onnx |
3.Model accuracy:
[IoU=0.50:0.95]: 0.7882(FLOAT)/0.7856(INT8)
6.4.2.4. Demo of Algorithm Model Samples¶
Taking the GoogleNet model as an example, This section illustrates the steps of floating-point to fixed-point model conversion
by using the scripts in 03_classification/02_googlenet/mapper/.
6.4.2.4.1. Docker Container Prep¶
First complete the docker installation and configuration and enter the docker container accoridng to Docker Container Deployment.
6.4.2.4.2. Obtain the Original Model and Calibration Dataset¶
Execute 00_init.sh in the 03_classification/02_googlenet/mapper/ folder to obtain the model and calibration dataset needed for the current sample.
# 1. Enter the folder the demo script resides
cd samples/ai_toolchain/horizon_model_convert_sample/03_classification/02_googlenet/mapper
# 2. Execute the script to obtain the original model and calibration dataset
sh 00_init.sh
6.4.2.4.3. Check If the Model is Executable¶
1.Run the script as follows:
# Execute model checking
sh 01_check.sh
2.Output the model inspection result:
The above script uses the hb_mapper checker tool to check whether the model can be supported by D-Robotics ASIC. An OP list will also be dumped to show whether an OP is processed by the BPU or the CPU.
Node ON Subgraph Type
Conv_0 BPU id(0) HzSQuantizedConv
MaxPool_3 BPU id(0) HzQuantizedMaxPool
Conv_4 BPU id(0) HzSQuantizedConv
Conv_7 BPU id(0) HzSQuantizedConv
MaxPool_10 BPU id(0) HzQuantizedMaxPool
Conv_11 BPU id(0) HzSQuantizedConv
Conv_14 BPU id(0) HzSQuantizedConv
Conv_17 BPU id(0) HzSQuantizedConv
Conv_20 BPU id(0) HzSQuantizedConv
Conv_23 BPU id(0) HzSQuantizedConv
MaxPool_26 BPU id(0) HzQuantizedMaxPool
Conv_27 BPU id(0) HzSQuantizedConv
Concat_30 BPU id(0) Concat
Conv_31 BPU id(0) HzSQuantizedConv
Conv_34 BPU id(0) HzSQuantizedConv
Conv_37 BPU id(0) HzSQuantizedConv
Conv_40 BPU id(0) HzSQuantizedConv
Conv_43 BPU id(0) HzSQuantizedConv
MaxPool_46 BPU id(0) HzQuantizedMaxPool
Conv_47 BPU id(0) HzSQuantizedConv
Concat_50 BPU id(0) Concat
MaxPool_51 BPU id(0) HzQuantizedMaxPool
Conv_52 BPU id(0) HzSQuantizedConv
Conv_55 BPU id(0) HzSQuantizedConv
Conv_58 BPU id(0) HzSQuantizedConv
Conv_61 BPU id(0) HzSQuantizedConv
Conv_64 BPU id(0) HzSQuantizedConv
MaxPool_67 BPU id(0) HzQuantizedMaxPool
Conv_68 BPU id(0) HzSQuantizedConv
Concat_71 BPU id(0) Concat
Conv_72 BPU id(0) HzSQuantizedConv
Conv_75 BPU id(0) HzSQuantizedConv
Conv_78 BPU id(0) HzSQuantizedConv
Conv_81 BPU id(0) HzSQuantizedConv
Conv_84 BPU id(0) HzSQuantizedConv
MaxPool_87 BPU id(0) HzQuantizedMaxPool
Conv_88 BPU id(0) HzSQuantizedConv
Concat_91 BPU id(0) Concat
Conv_92 BPU id(0) HzSQuantizedConv
Conv_95 BPU id(0) HzSQuantizedConv
Conv_98 BPU id(0) HzSQuantizedConv
Conv_101 BPU id(0) HzSQuantizedConv
Conv_104 BPU id(0) HzSQuantizedConv
MaxPool_107 BPU id(0) HzQuantizedMaxPool
Conv_108 BPU id(0) HzSQuantizedConv
Concat_111 BPU id(0) Concat
Conv_112 BPU id(0) HzSQuantizedConv
Conv_115 BPU id(0) HzSQuantizedConv
Conv_118 BPU id(0) HzSQuantizedConv
Conv_121 BPU id(0) HzSQuantizedConv
Conv_124 BPU id(0) HzSQuantizedConv
MaxPool_127 BPU id(0) HzQuantizedMaxPool
Conv_128 BPU id(0) HzSQuantizedConv
Concat_131 BPU id(0) Concat
Conv_132 BPU id(0) HzSQuantizedConv
Conv_135 BPU id(0) HzSQuantizedConv
Conv_138 BPU id(0) HzSQuantizedConv
Conv_141 BPU id(0) HzSQuantizedConv
Conv_144 BPU id(0) HzSQuantizedConv
MaxPool_147 BPU id(0) HzQuantizedMaxPool
Conv_148 BPU id(0) HzSQuantizedConv
Concat_151 BPU id(0) Concat
MaxPool_152 BPU id(0) HzQuantizedMaxPool
Conv_153 BPU id(0) HzSQuantizedConv
Conv_156 BPU id(0) HzSQuantizedConv
Conv_159 BPU id(0) HzSQuantizedConv
Conv_162 BPU id(0) HzSQuantizedConv
Conv_165 BPU id(0) HzSQuantizedConv
MaxPool_168 BPU id(0) HzQuantizedMaxPool
Conv_169 BPU id(0) HzSQuantizedConv
Concat_172 BPU id(0) Concat
Conv_173 BPU id(0) HzSQuantizedConv
Conv_176 BPU id(0) HzSQuantizedConv
Conv_179 BPU id(0) HzSQuantizedConv
Conv_182 BPU id(0) HzSQuantizedConv
Conv_185 BPU id(0) HzSQuantizedConv
MaxPool_188 BPU id(0) HzQuantizedMaxPool
Conv_189 BPU id(0) HzSQuantizedConv
Concat_192 BPU id(0) Concat
GlobalAveragePool_193 BPU id(0) HzSQuantizedGlobalAveragePool
Gemm_195 BPU id(0) HzSQuantizedConv
Gemm_195_reshape_output CPU -- Reshape
6.4.2.4.4. Prepare Calibration Dataset¶
Run the 02_preprocess.sh script in the same directory, as follows:
# Convert the images in 01_common/data/imagenet/calibration_data
# to: ./calibration_data_rgb_f32
sh 02_preprocess.sh
Note
We extracted 100 images from the ImageNet dataset and use them as a calibration dataset. Before calibration, we pre-processed the data and convert short size resize/crop size/NHWC to NCHW/to rgb.
The
hb_mappertool will load data from the converted binary data, the format of the pre-processed binary data file isc-ordermatrix storage, and data type of each matrix value isuint8.
6.4.2.4.5. Building Heterogeneous Models¶
Run the 03_build.sh script in the same directory, as follows:
sh 03_build.sh
Note
The above script uses the hb_mapper tool to convert the model. The most important thing to focus on is the conversion configuration file,
refer to Model Compiling Tool (hb_mapper makertbin) section.
The output of the above script is as follows:
ls model_output | cat
cache.json
googlenet_224x224_nv12.bin
googlenet_224x224_nv12_calibrated_model.onnx
googlenet_224x224_nv12_optimized_float_model.onnx
googlenet_224x224_nv12_original_float_model.onnx
googlenet_224x224_nv12_quantized_model.onnx
torch-jit-export_subgraph_0.html
torch-jit-export_subgraph_0.json
Note
For now you ONLY need to focus on the googlenet_224x224_nv12.bin file.
6.4.2.4.6. Single Image Inference¶
Run the 04_inference.sh script to inference a single image, as follows:
sh 04_inference.sh
Note
As image pre-processing, model data post-processing are required in the image inference, we offered a Python sample script, please refer to
sh 04_inference.sh.This script is to perform the inference against a single image and verify whether the inference result meets the expectations. If you want to perform accuracy evaluation, refer to the script
05_evaluate.sh.
6.4.2.4.7. Accuracy Evaluation¶
Run the 05_evaluate.sh script to evaluate the accuracy, as follows:
export PARALLEL_PROCESS_NUM=${parallel_process_num}
sh 05_evaluate.sh
Note
As image pre-processing, model data post-processing are required in accuracy evaluation, awe offered a Python sample script, please refer to
sh 05_evaluate.sh.To accelerate the evaluation, you can adjust the number of concurrent processes by using the
-poption; meanwhile, pay attention to the memory usage.When the value of the
-poption is set to 0 or left unfilled, the fixed-point models in the CPU environment will be processed by 10 processes, while other scenarios using 1 process.
6.4.2.5. FAQ¶
6.4.2.5.1. How to align the ONNX original floating-point model obtained using open-source frameworks with the *_original_float_model.onnx model from hb_mapper makertbin?¶
Note
The difference between the original floating-point model and the converted ONNX floating-point model is
guaranteed by the toolchain product, hb_mapper, which is not a required standard process.
1. Understand the concepts of these 2 models
Let’s clarify the concepts of these two models.
The former refers to the original ONNX floating-point models trained by developers using opensource frameworks, e.g., TensorFlow、PyTorch、MXNet, etc.
The latter refers to the *_original_float_model.onnx intermediate model converted by using either the hb_mapper makertbin tool or the 03_classification/${modelname}/mapper/03_build.sh script in D-Robotics model conversion sample package (i.e., the released horizon_model_convert_sample), where, * denotes the name of a specific model (e.g., MobileNetv1, GoogleNet, etc.).
2. Understand the distinctions between these 2 models
Both *_original_float_model.onnx model and the original floating-point model share the same computational accuracy, except that the former added some data pre-processing computation.
Typically, you don’t really need to use this model unless there is abnormality in conversion results, which may help you solve the issue faster if you can provide this model to our technical support.
3. Write your own script to align these 2 models
Note
The following contents take the googlenet model in horizon_model_convert_sample package as an example to describe how to align the inference results of these 2 models.
To do this, you need to write your own scripts, where you need to note the following:
Attention
The logic between the following two should be consistent to avoid inconsistent inference results caused by different image data processing logic:
The image data processing logic in your own script
The logic in the mapper/preprocess.py script in the sample package
Note that code logic may vary by sample package version. In such cases, please refer to the image data preprocessing script or contact our technical staff.
See the following code block for each preprocessing transformer method:
import sys
sys.path.append("../../../01_common/python/data/")
from transformer import *
from dataloader import *
# image calibration transformer
def calibration_transformers():
step:
1、short size resize to 256
2、crop size 224 * 224 from center
3、NHWC to NCHW
4、bgr to rgb
transformers = [
HWC2CHWTransformer(),
BGR2RGBTransformer()
return transformers
# image inference transformer
def infer_transformers(input_layout="NHWC"):
step:
1、PIL resize to 256
2、crop size 224*224 from PIL center
3、bgr to nv12
4、nv12 to yuv444
:param input_layout: input layout
transformers = [
PILResizeTransformer(size=256),
PILCenterCropTransformer(size=224),
BGR2NV12Transformer(data_format="HWC"),
NV12ToYUV444Transformer((224, 224)),
yuv444_output_layout=input_layout[1:]),
return transformers
You can align data pre-processing logic as follows:
def ShortSideResizeTransformer(data, short_size):
image = data
height, width, _ = image.shape
if height < width:
off = width / height
image = cv2.resize(image,
(int(short_size * off), short_size))
else:
off = height / width
(short_size, int(short_size * off)))
data = image
data = data.astype(np.float32)
return data
def CenterCropTransformer(data, crop_size):
image = data
resize_height, resize_width, _ = image.shape
resize_up = resize_height // 2 - crop_size // 2
resize_left = resize_width // 2 - crop_size // 2
data = image[resize_up:resize_up +
crop_size, resize_left:resize_left +
crop_size, :]
return data
def preprocess(data):
data = ShortSideResizeTransformer(data, short_size=256) # ShortSideResize
data = CenterCropTransformer(data, crop_size=224) # CenterCrop
data = np.transpose(data, (2, 0, 1)) # HWC2CHW
data = data * 255 # (0, 1) --> (0, 255)
Attention
As shown in below figure, an HzPreprocess operator is added into the model googlenet_224x224_nv12_original_float_model.onnx,
in order to implement the data_mean_and_scale operation in googlenet_config.yaml.
Therefore, you need to implement the data normalization based on the mean_value and scale_value parameters in googlenet_config.yaml, as follows:
# Normalize
mean = np.array([127.5, 127.5, 127.5])
scale = np.array([0.0078431, 0.0078431, 0.0078431])
norm_data = np.zeros(data.shape).astype(np.float32)
for i in range(data.shape[0]):
norm_data[i,:,:] = (data[i,:,:] - mean[i]) * scale[i]
norm_data = norm_data.reshape(1, 3, 224, 224).astype(np.float32)
Attention
By default, the mapper/04_inference.sh script of all models performs the fixed-point model inference. Therefore, when validating the inference result of a floating-point model, you should run sh 04_inference.sh origin to perform the floating-point model inference.
Note that code logic may vary by sample package version. In such cases, please refer to the comments in the script 03_classification/02_googlenet/mapper/04_inference.sh script.
After implementing the above steps, you can align the results of the original floating-point model with the googlenet_224x224_nv12_original_float_model.onnx model.
6.4.2.5.2. Why is the reproduced accuracy slightly different from the indicators in the documentation?¶
There are two possible reasons:
There may be minor differences in calculation methods when in different server environments, which can cause small data fluctuations in the accuracy of the compiled fixed-point ONNX models in different server environments when compared with the documentation.
The user side uses different versions of third-party libraries such as OpenCV and NumPy, which may produce different results after pre-processing, and this may also lead to slight data fluctuations in reproduced accuracy when compared with the documentation.
No need to worry much about this situation, the records provided in the documentation is only for reference, and it is ok that your reproduced accuracy is slightly different from those in documents.
6.4.2.5.3. Why is the fixed-point model accuracy not aligned with the on-board accuracy of the bin file in the ai_benchmark example?¶
In the standard delivery, when adding the example, we have already aligned the fixed-point model accuracy with the bin on-board accuracy in the ai_benchmark example.
If you find any unaligned accuracy, we recommend you first checking the model input for consistency.
When executing the fixed-point model evaluation script, you use the dataset of image type, while for the bin model used on board, you use the binary dataset converted by the hb_eval_preprocess tool.
Based on this, if the dataset you used on-board is not generated by using the above methods, we recommend that you first use our data preprocessing tool (i.e., hb_eval_preprocess) to regenerate the dataset needed for on-board running on the same server that you run the fixed-point model accuracy and rerun the on-board accuracy to ensure the model inputs are consistent.
Attention
Make sure to use the same environment to generate the dataset by using the hb_eval_preprocess tool and to run the fixed-point model accuracy.
