4.1. Environment Deployment¶
4.1.1. Foreword¶
D-Robotics OpenExplorer currently provides 2 sets of model quantization schemes at the same time.
PTQ: Post-training Quantization.
QAT: Quantization aware training, which only supports the Pytorch framework for now.
Among them:
Both solutions do not interfere with the training phase of the floating-point model, which is your own responsibility. D-Robotics has also provided some open-source implementations of the public version of Pytorch for efficient models in classification, detection, segmentation, and other scenarios in the
samples/ai_toolchain/horizon_model_train_sampledirectory for reference, with the support for training and replication on the host.For PTQ scheme, you need to quantize the model in the host development environment, and then copy the compiled
.binmodel to the dev board environment for subsequent deployment.For the QAT scheme, you need to complete the QAT training of the model in the host development environment, perform the quantization conversion, and then copy the compiled
.hbmmodel to the dev board environment for subsequent deployment.
For both of the above quantization schemes and the development environment of the efficient model, D-Robotics provides both local manual installation and Docker containers. We strongly recommend using Docker containers as they do not pollute the local environment and is easy to use, descriptions of these two are included in the following sections.
4.1.2. Development Environment Deployment¶
4.1.2.1. Download OE Package¶
Please download the OE package and extract it correctly on the development machine. Sample models are included in the model_zoo directory of the OE package.
4.1.2.2. Development Machine Preparation¶
In order to use the toolchain smoothly, we recommends that the development machine you choose should meet the following requirements:
HW/OS |
REQUIREMENTS |
CPU |
CPU above I3 or same level processor as E3/E5 |
Memory Size |
16G or above |
GPU |
CUDA11.6, Drive Version: Linux:>= 510.39.01* (Recommended Drive Version: Linux:515.76) Adapted graphics cards include but are not limited to: 1)GeForce RTX 3090 2)GeForce RTX 2080 Ti 3)NVIDIA TITAN V 4)Tesla V100S-PCIE-32GB 5)A100 |
OS |
Ubuntu 20.04 |
For more information about CUDA compatibility with graphics cards, refer to NVIDIA website information.
4.1.2.3. Docker Container Deployment¶
4.1.2.3.1. Docker Base Environment¶
D-Robotics requires the following Docker base environment, please complete the installation on your host computer in advance.
Docker (19.03 and above, 19.03 is recommended), refer to the Docker Installation Manual.
NVIDIA Container Toolkit (1.13.1-1.13.5, 1.13.5 is recommended), refer to installation manual NVIDIA Container Toolkit installation manual.
After completing the installation of the Docker environment, remember to add non-root users into Docker users group by running below command:
sudo groupadd docker
sudo service docker restart
Please obtain the required Docker image from following:
The naming form is as follows:
GPU Docker:
openexplorer/ai_toolchain_ubuntu_20_x5_gpu:{version}CPU Docker:
openexplorer/ai_toolchain_ubuntu_20_x5_cpu:{version}
Tip
Replace the {version} by the actual version number.
4.1.2.3.2. Docker Image Usage¶
To help you quickly use the toolchain, we provide a Docker image containing the complete development environment, which greatly simplifies the deployment process of the development environment.
Note
If you have downloaded the offline image, you need to use the following command to load the image locally first.
docker load -i docker_openexplorer_xxx.tar.gz
You can start the Docker container corresponding to the current OE version by running the following script directly from the first level of the OE package(the script will automatically pull the image from the official Docker hub if there is no local image):
sh run_docker.sh data/
Where data is the path to the evaluation dataset folder. Please create the path before running the command, otherwise loading problems may occur.
If you want to use the CPU version of the Docker image, you need to add the cpu parameter:
sh run_docker.sh data/ cpu
The download links for the relevant publicly available evaluation datasets that the OE package samples rely on can be accessed by referring to the introduction in section Dataset Download.
If you want to start the Docker container manually, you can refer to the following command, where {version} is the OE version number you are currently using.
Note
For your convenience, we provide CPU Docker and GPU Docker for you to choose on demand.
CPU Docker:
# CPU Docker
docker pull openexplorer/ai_toolchain_ubuntu_20_x5_cpu:{version}
# Start CPU Docker image manually
docker run -it --rm
-v {OE package path}:/open_explorer \ # Mount OE package
-v ./dataset:/data/horizon_x5/data \ # Mount dataset
GPU Docker:
# GPU Docker
docker pull openexplorer/ai_toolchain_ubuntu_20_x5_gpu:{version}
# Start GPU Docker image manually
docker run -it --rm
--gpus all \ # Include the flag when you start a container to access GPU resources
--shm-size=15g \ # Change the shared memory size
-v {dataset path}:/data/horizon_x5/data \ # Mount dataset
Attention
Since the environment variables
PATHandLD_LIBRARY_PATHare configured during the build process of the OE Docker image, not using the recommended way (e.g., docker attach) to enter the container may result in the environment variables not being loaded correctly, which may lead to the use of abnormalities in tools such as Cmake, GCC, CUDA, and so on.If you want the Docker container to exit without removing it, use the command line
docker run -itto start it manually, without the--rmoption.If you want the Docker container to run background after startup, add the
-doption after the command linedocker run -it, the container ID will be returned after the container is started, and then you can enter the container again with the commanddocker exec -it {container ID} /bin/bash.
After successfully entering the Docker container, you can type the command ddk_vcs list to
see if the current version is the one you expected.
4.1.2.4. Local Manual Installation¶
This section describes the local manual installation environment method, and introduces the environment-related dependencies and descriptions for each of the two quantization schemes and D-Robotics open-source efficient model training. We recommend prioritizing the easy-to-use PTQ quantization scheme after the floating-point model training, and switch to the QAT quantization scheme only when accuracy issues cannot be solved.
4.1.2.4.1. Local Manual Installation Environment Method¶
To manually install the environment locally, simply run the script below to complete the environment installation in one click.
cd package/host
bash install.sh
The installation script will automatically check the environment. If there are missing dependencies or configurations, it will interrupt the installation process and give suggestions to fix it. Run the script again after adding the dependencies as suggested.
Note
If you need to generate a board-side executeable program, use the cross-compilation tool
arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu.If you need to generate an X86 emulation environment executable program, use the
X86 gcc, if the script suggests that gcc/g++ versions are incorrect, you need to recreate the gcc and g++ soft links as gcc-11.4.0 and g++-11.4.0 after the required versions are installed.For host-side (x86) dependent libraries (isl, gmp, mpc, mpfr, etc.), if you use lib/x86_64-linux-gnu, please specify them by
LD_LIBRARY_PATHin the compiled project if the compilation reports errors.If there is a glibc library version conflict problem during compilation, for example: the error of undefined symbols for
xxx@GLIBC_xxx, please specify the path toaarch64-linux-gnu/libof the toolchain by using-rpath-linkin the compiled project, and at the same time add-lxxxto the compiled project, for example:-lpthread.In addition, you should pay special attention to the variable
SRCS(boxed below) that records the source file. It is better to put it in front of the${LIBS}link library, otherwise it may also report undefined symbols.
The installation script will automatically check the environment. If there are missing dependencies or configurations, it will interrupt the installation process and you can run the script again after adding the dependencies as suggested.
After the installation script is completed successfully, it will add path and other information to the
~/.bashrcsystem environment variable(The environment variableLD_LIBRARY_PATHis often used and it is recommended that you check that the environment variable is as expected), runsource ~/.bashrcto make the current terminal configuration take effect.The torch version should be 1.13.0 and the torchvision version should be 0.14.0.
After successfully completing the install script, you can type the command ddk_vcs list to verify that the tools and dependencies you need are installed correctly.
4.1.2.4.2. PTQ Quantization Environment Dependence¶
The PTQ scheme has the following software dependencies on the base software of the development machine operating environment:
Operating system: Ubuntu20.04
Python3.8
libpython3.8
python3-devel
python3-pip
gcc&g++: 11.4.0
graphviz
4.1.2.4.3. QAT Quantization Environment Dependence¶
The QAT quantization environment is installed in the local environment and you need to ensure that the following basic environmental conditions are met.
The environmental dependencies required for the quantitative training tool to be trained are listed below:
HW/OS |
GPU |
CPU |
os |
Ubuntu20.04 |
Ubuntu20.04 |
cuda |
11.6 |
N/A |
python |
3.8 |
3.8 |
torch |
1.13.0+cuda-11.6 |
1.13.0+cpu |
torchvision |
0.14.0+cuda-11.6 |
0.14.0+cpu |
Recommended Graphics Cards |
titan v/2080ti/ v100/3090 |
N/A |
After completing the training of the QAT model, we can take one of the following two approaches to complete the subsequent model conversion.
Approach 1: Export the onnx model first, and then complete the model conversion by using yaml file based on the PTQ scheme(For this approach we recommend that you use the docker provided by D-Robotics directly).
Approach 2: Install the relevant toolkits in the current training environment and complete the model conversion directly through the interface call.
4.1.2.4.4. Efficient Model Floating-point Training Environment Instruction¶
D-Robotics provides the source code of several open-source efficient models in samples/ai_toolchain/horizon_model_train_sample. For information on the floating-point and QAT base environment, refer to section QAT Quantization Environment Deployment.
4.1.3. Runtime Environment Deployment¶
Once the model has been quantized, the compiled model can be deployed on the dev board environment for inference and execution.
To deploy the runtime environment, you need to prepare a dev board with the system image programmed, and then copy the relevant supplementary files to the dev board.
4.1.3.1. Dev Board Preparation¶
At this stage, you need to verify the usability of the dev board and program the available system images to the board.
4.1.3.2. Board Side Tool Installation¶
Some of the supplementary tools of the toolchain are not included in the system image, but can be copied to the dev board by running the installation script in the OE package in the host environment, as follows:
cd package/board
bash install.sh ${board_ip}
Note
Where ${board_ip} is the IP address you set for the dev board. Make sure that you can successfully access this IP on the development PC.
After the supplementary files are successfully installed, please restart the dev board and execute hrt_model_exec --help on the dev board to verify if the installation is successful.
