6.4.3. Other Algorithm Model Samples
Other algorithm model samples refer to the samples in the 05_miscellaneous/ and 06_custom_op/ folders.
Among them.
  • The 05_miscellaneous/ folder contains miscellaneous samples used for other features in the X3 Toolchain, e.g., how to enable the RGB data trained model to receive YUV data at runtime using D-Robotics’s model conversion toolchain.
  • The 06_custom_op/ folder is a user custom OP sample helps developers understand how to add custom OP when there are Toolchain unsupported OPs.
For the sample usage, directories, and contents of the above samples, please refer to the following sections.
6.4.3.1. How to Use
Under each subfolder, all usage samples are packaged into a shell script in order.
Run the shell scripts in order to understand the usage of corresponding tools, API features, usage, etc.
6.4.3.2. Miscellaneous Samples
6.4.3.2.1. lenet_gray
6.4.3.2.1.1. Directory
01_lenet_gray/
└── mapper
    ├── 00_init.sh                  // Obtain the model and calibration dataset required for the current sample
    ├── 01_check.sh                 // Pre-validates the model
    ├── 02_get_mnist.sh             // Obtains the calibration dataset
    ├── 03_build.sh                 // Converts the debugging model
    ├── 04_inference.sh             // Performs inference using the ONNX runtime
    ├── README.md
    ├── inference.py
    ├── lenet_gray_config.yaml
    └── process_mnist.py
6.4.3.2.1.2. Descriptions
This section contains model conversion, simulator runtime, and on-board runtime samples of gray image models.
6.4.3.2.2. resnet50_feature
6.4.3.2.2.1. Directory
02_resnet50_feature
└── mapper
    ├── 02_build.sh                 // Converts the debugging model
    ├── 03_inference.sh             // Performs inference using the ONNX runtime
    ├── README.md
    ├── inference.py
    └── resnet50_feature_config.yaml
6.4.3.2.2.2. Descriptions
This section contains model conversion, simulator runtime, and on-board runtime samples of resnet50_feature.
6.4.3.2.3. vector-diff
6.4.3.2.3.1. Directory
03_vector_diff
└── mobilenet_mapper
    ├── 01_inference_rt.sh
    ├── 02_vec_diff.sh                  // Analyzes the output data using the vec_diff tool
    ├── ILSVRC2012_val_00000001.bin
    └── README.md
6.4.3.2.3.2. Output List
CSV files and lists specified by the vec_diff -o command, including Left Files, Right Files, Cosine Similarity, Relative Euclidean Distance, Max Absolute Error, and Mean Square Error, as follows:
Left Files
Right Files
Cosine Similarity
Max Absolute Error
Mean Square Error
Layerxxx-quanti-input.txt
Layerxxx-float-input.txt
xxx
xxx
xxx
xxx
Layerxxx-quanti-param.txt
Layerxxx-float-param.txt
xxx
xxx
xxx
xxx
6.4.3.2.4. multi_input_example
6.4.3.2.4.1. Directory
04_multi_input_example
└── mapper
    ├── 02_preprocess.sh            // Preprocesses the model
    ├── 04_inference.sh             // Performs inference on a single image
    ├── data_preprocess.py
    ├── data_transformer.py
    ├── inference.py
    ├── README.md
    └── mobilenetv2_multi_config.yaml
6.4.3.2.4.2. Description
This section contains model conversion, simulator runtime, and on-board runtime samples of multi-input models.
6.4.3.2.5. model_verifier
6.4.3.2.5.1. Directory
07_model_verifier
├── 01_preprocess.sh                // Preprocesses the model
├── 03_model_verify.sh              // Verifies the model
├── calibration_data_feature
├── preprocess.py
├── README.md
├── mobilenet_config_bgr.yaml
├── mobilenet_config_yuv444.yaml
└── resnet50_featuremap_config.yaml
6.4.3.2.5.2. Description
This section contains samples of model verification tool.
6.4.3.2.6. model_info
6.4.3.2.6.1. Directory
08_model_info
├── 03_model_info_check.sh          // Obtains and prints the model information
├── README.md
├── mobilenet_config.yaml
└── preprocess.py
6.4.3.2.6.2. Description
This section contains a sample of the model validation tool.
6.4.3.2.7. mobilenet_bgr
6.4.3.2.7.1. Directory
09_mobilenet_bgr
└── mapper
    ├── 02_preprocess.sh          // Preprocess the dataset
    ├── README.md
    ├── postprocess.py
    └── preprocess.py
6.4.3.2.7.2. Description
This is a sample of the MobileNetv1 model whose input_type_rt is specified as bgr.
6.4.3.2.8. mobilenet_yuv444
6.4.3.2.8.1. Directory
11_mobilenet_yuv444
└── mapper
    ├── README.md
    ├── postprocess.py
    └── preprocess.py
6.4.3.2.8.2. Description
This is a sample of the MobileNetv1 model whose input_type_rt is specified as yuv444.
6.4.3.3. User Custom OP Sample
6.4.3.3.1. Directory
06_custom_op
└── mapper
    ├── 00_init.sh
    ├── 03_build.sh
    ├── 04_inference.sh
    ├── README.md
    ├── create_onnx.py
    ├── custom_op_config.yaml
    ├── custom_op_inference.py
    └── horizon_ops.py
6.4.3.3.2. Descriptions
When converting the floating-point model trained by open-source frameworks into the fixed-point model, the conversion will fail if the floating-point model contains the ops not supported by the Toolchain. In such cases, developers can still convert the model by adding custom ops using the custom op feature.
The mapper folder contains the scripts and configuration file required by running this sample.
