5.5 Using "Zero-Copy"
Functional Background​
Communication is a fundamental function of robot development engines. The native ROS2 Foxy has issues with high latency and high system load when handling large-volume data communication. TogetheROS.Bot Foxy implements the "zero-copy" feature based on the RDK system software library hbmem , enabling zero-copy data transfer across processes, significantly reducing large data transfer latency and system resource usage. This section describes how to use tros.b Foxy/Humble/Jazzy to create publisher and subscriber nodes for large data transfer and calculate the transfer latency.
info
  • The tros.b Foxy version adds the "zero-copy" feature to ROS2 Foxy.
  • tros.b Humble and subsequent versions use ROS2's "zero-copy" feature. For specific usage, refer to the official ROS2 documentation and code.
  • The usage for versions after tros.b Humble is the same as the Humble version; refer to the Humble version example in this section.
Prerequisites​
tros.b has been successfully installed following apt Installation and Upgrade. Basic knowledge of ROS2 nodes, topics, QoS, how to create packages, and use custom messages is required. For specific tutorials, see the official ROS2 tutorials Creating a package.
ROS2 software package building and compiling tools, etc. Installation command: sudo apt install ros-dev-tools
Task Content​
1. Create a package​
Open a new terminal, source the tros.b setup script, and ensure the ros2 command can run.
source /opt/tros/setup.bash
Use the following command to create a workspace. For details, see the official ROS2 tutorial Creating a workspace.
mkdir -p ~/dev_ws/src
cd ~/dev_ws/src
Run the following command to create a package
ros2 pkg create --build-type ament_cmake hbmem_pubsub
2. Create a custom message​
2.1 Create a new message file​
Run the following command to create a msg directory to store custom message files
cd ~/dev_ws/src/hbmem_pubsub
mkdir msg
Create a new SampleMessage.msg file in the msg directory with the following content:
int32 index
uint64 time_stamp
uint8[4194304] data
uint32 MAX_SIZE=4194304
2.2 Build dependencies​
Return to the ~/dev_ws/src/hbmem_pubsub directory, modify package.xml , and add the following content below <buildtool_depend>ament_cmake</buildtool_depend> :
<build_depend>rosidl_default_generators</build_depend>
<exec_depend>rosidl_default_runtime</exec_depend>
<member_of_group>rosidl_interface_packages</member_of_group>
2.3 Build script​
Modify CMakeLists.txt , add the following content below # find_package(<dependency> REQUIRED) to compile the msg:
find_package(rosidl_default_generators REQUIRED)
rosidl_generate_interfaces(${PROJECT_NAME}
"msg/SampleMessage.msg"
3. Create a message publishing node​
3.1 Create a new message publishing node file​
Create a new publisher_hbmem.cpp file in the ~/dev_ws/src/hbmem_pubsub/src directory to create a publisher node. The specific code and explanation are as follows:
#include <chrono>
#include <functional>
#include <memory>
#include <string>
#include "rclcpp/rclcpp.hpp"
#include "hbmem_pubsub/msg/sample_message.hpp"
using namespace std::chrono_literals;
class MinimalHbmemPublisher : public rclcpp::Node {
public:
MinimalHbmemPublisher () : Node("minimal_hbmem_publisher"), count_(0) {
// Create publisher_hbmem with topic "topic"
publisher_ = this->create_publisher_hbmem<hbmem_pubsub::msg::SampleMessage>(
"topic", rclcpp::SensorDataQoS());
// Timer, calls timer_callback every 40 milliseconds to send messages
timer_ = this->create_wall_timer(
40ms, std::bind(&MinimalHbmemPublisher ::timer_callback, this));
private:
// Timer callback function
void timer_callback() {
// Get the message to send
auto loanedMsg = publisher_->borrow_loaned_message();
// Check if the message is available; it may be unavailable if acquisition fails
if (loanedMsg.is_valid()) {
// Get the actual message by reference
auto& msg = loanedMsg.get();
// Get the current time in microseconds
auto time_now =
std::chrono::duration_cast<std::chrono::microseconds>(
std::chrono::steady_clock::now().time_since_epoch()).count();
// Assign values to the message's index and time_stamp
msg.index = count_;
msg.time_stamp = time_now;
// Print the sent message
RCLCPP_INFO(this->get_logger(), "message: %d", msg.index);
publisher_->publish(std::move(loanedMsg));
// Note: after sending, loanedMsg is no longer available
// Increment the counter
count_++;
} else {
// Failed to get the message, discard it
RCLCPP_INFO(this->get_logger(), "Failed to get LoanMessage!");
// Timer
rclcpp::TimerBase::SharedPtr timer_;
// hbmem publisher
rclcpp::PublisherHbmem<hbmem_pubsub::msg::SampleMessage>::SharedPtr publisher_;
// Counter
size_t count_;
int main(int argc, char * argv[])
rclcpp::init(argc, argv);
rclcpp::spin(std::make_shared<MinimalHbmemPublisher>());
rclcpp::shutdown();
#include <chrono>
#include <memory>
#include <string>
public:
publisher_ = this->create_publisher<hbmem_pubsub::msg::SampleMessage>(
private:
auto time_now =
msg.index = count_;
count_++;
} else {
// Timer
// hbmem publisher
rclcpp::Publisher<hbmem_pubsub::msg::SampleMessage>::SharedPtr publisher_;
// Counter
size_t count_;
rclcpp::shutdown();
#include <chrono>
#include <memory>
#include <string>
public:
private:
auto time_now =
msg.index = count_;
count_++;
} else {
// Timer
// hbmem publisher
// Counter
size_t count_;
rclcpp::shutdown();
#include <chrono>
#include <memory>
#include <string>
public:
private:
auto time_now =
msg.index = count_;
count_++;
} else {
// Timer
// hbmem publisher
// Counter
size_t count_;
rclcpp::shutdown();
3.2 Build dependencies​
Return to the ~/dev_ws/src/hbmem_pubsub directory, modify package.xml , and add the rclcpp dependency below <member_of_group>rosidl_interface_packages</member_of_group> :
  <depend>rclcpp</depend>
3.3 Build script​
Modify CMakeLists.txt , add the following content below the rosidl_generate_interfaces statement to compile the publisher:
find_package(rclcpp REQUIRED)
add_executable(talker src/publisher_hbmem.cpp)
ament_target_dependencies(talker rclcpp)
rosidl_target_interfaces(talker
${PROJECT_NAME} "rosidl_typesupport_cpp")
install(TARGETS
talker
DESTINATION lib/${PROJECT_NAME})
4. Create a message receiving node​
4.1 Create a new message receiving node file​
Create a new subscriber_hbmem.cpp file in the ~/dev_ws/src/hbmem_pubsub/src directory to create a subscriber node. The specific code and explanation are as follows:
#include <memory>
class MinimalHbmemSubscriber : public rclcpp::Node {
public:
MinimalHbmemSubscriber () : Node("minimal_hbmem_subscriber") {
// Create subscription_hbmem with topic "sample"
// The message callback function is topic_callback
subscription_ =
this->create_subscription_hbmem<hbmem_pubsub::msg::SampleMessage>(
"topic", rclcpp::SensorDataQoS(),
std::bind(&MinimalHbmemSubscriber ::topic_callback, this,
std::placeholders::_1));
private:
// Message callback function
void topic_callback(
const hbmem_pubsub::msg::SampleMessage::SharedPtr msg) const {
// Note: msg can only be used within the callback function; after the callback returns, the message will be released
auto time_now =
.count();
// Calculate latency and print it
RCLCPP_INFO(this->get_logger(), "msg %d, time cost %dus", msg->index,
time_now - msg->time_stamp);
// hbmem subscription
rclcpp::SubscriptionHbmem<hbmem_pubsub::msg::SampleMessage>::SharedPtr
subscription_;
rclcpp::spin(std::make_shared<MinimalHbmemSubscriber>());
rclcpp::shutdown();
#include <memory>
public:
subscription_ =
this->create_subscription<hbmem_pubsub::msg::SampleMessage>(
private:
auto time_now =
.count();
rclcpp::Subscription<hbmem_pubsub::msg::SampleMessage>::SharedPtr
subscription_;
rclcpp::shutdown();
#include <memory>
public:
subscription_ =
private:
auto time_now =
.count();
subscription_;
rclcpp::shutdown();
4.2 Build script​
Return to the ~/dev_ws/src/hbmem_pubsub directory. The rclcpp dependency has already been added to package.xml , so no modification to package.xml is needed.
Modify CMakeLists.txt , add the following content below the install statement to compile the subscriber:
add_executable(listener src/subscriber_hbmem.cpp)
ament_target_dependencies(listener rclcpp)
rosidl_target_interfaces(listener
install(TARGETS
listener
5. Build​
The entire workspace directory structure is as follows:
dev_ws/
└── src
└── hbmem_pubsub
├── CMakeLists.txt
├── include
│   └── hbmem_pubsub
├── msg
│   └── SampleMessage.msg
├── package.xml
└── src
├── publisher_hbmem.cpp
└── subscriber_hbmem.cpp
The complete package.xml content is as follows:
<?xml version="1.0"?>
<?xml-model href="http://download.ros.org/schema/package_format3.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?>
<package format="3">
<name>hbmem_pubsub</name>
<version>0.0.0</version>
<description>TODO: Package description</description>
<maintainer email="root@todo.todo">root</maintainer>
<license>TODO: License declaration</license>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
The complete CMakeLists.txt content is as follows:
cmake_minimum_required(VERSION 3.5)
project(hbmem_pubsub)
# Default to C99
if(NOT CMAKE_C_STANDARD)
set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()
if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang")
add_compile_options(-Wall -Wextra -Wpedantic)
endif()
# find dependencies
find_package(ament_cmake REQUIRED)
# uncomment the following section in order to fill in
# further dependencies manually.
install(TARGETS
talker
install(TARGETS
listener
if(BUILD_TESTING)
find_package(ament_lint_auto REQUIRED)
# the following line skips the linter which checks for copyrights
# uncomment the line when a copyright and license is not present in all source files
#set(ament_cmake_copyright_FOUND TRUE)
# the following line skips cpplint (only works in a git repo)
# uncomment the line when this package is not in a git repo
#set(ament_cmake_cpplint_FOUND TRUE)
ament_lint_auto_find_test_dependencies()
endif()
ament_package()
In the workspace root directory ~/dev_ws , compile the package:
colcon build --packages-select hbmem_pubsub
If the colcon command is not installed, use the following command to install it:
6. Run​
Open a new terminal, cd to the dev_ws directory, and source the tros.b and current workspace setup files:
cd ~/dev_ws
. install/setup.bash
# Run the talker node:
ros2 run hbmem_pubsub talker
cd ~/dev_ws
export RMW_IMPLEMENTATION=rmw_fastrtps_cpp
export FASTRTPS_DEFAULT_PROFILES_FILE=/opt/tros/humble/lib/hobot_shm/config/shm_fastdds.xml
export RMW_FASTRTPS_USE_QOS_FROM_XML=1
export ROS_DISABLE_LOANED_MESSAGES=0
cd ~/dev_ws
cd ~/dev_ws
export FASTRTPS_DEFAULT_PROFILES_FILE=/opt/tros/jazzy/lib/hobot_shm/config/shm_fastdds.xml
The following output will appear on the terminal:
[INFO] [1649227473.431381673] [minimal_hbmem_publisher]: message: 0
[INFO] [1649227473.470746697] [minimal_hbmem_publisher]: message: 1
[INFO] [1649227473.510923361] [minimal_hbmem_publisher]: message: 2
[INFO] [1649227473.550886783] [minimal_hbmem_publisher]: message: 3
[INFO] [1649227473.590664377] [minimal_hbmem_publisher]: message: 4
[INFO] [1649227473.630857041] [minimal_hbmem_publisher]: message: 5
Open another new terminal, cd to the dev_ws directory, source the setup file, and then run the listener node:
cd ~/dev_ws
ros2 run hbmem_pubsub listener
cd ~/dev_ws
cd ~/dev_ws
cd ~/dev_ws
The terminal will display output similar to the following, indicating that the subscriber has successfully received the message sent by the publisher:
[INFO] [1649227450.387089523] [minimal_hbmem_subscriber]: msg 10, time cost 1663us
[INFO] [1649227450.427071280] [minimal_hbmem_subscriber]: msg 11, time cost 1713us
[INFO] [1649227450.466993413] [minimal_hbmem_subscriber]: msg 12, time cost 1622us
[INFO] [1649227450.507029960] [minimal_hbmem_subscriber]: msg 13, time cost 1666us
[INFO] [1649227450.546146910] [minimal_hbmem_subscriber]: msg 14, time cost 998us
[INFO] [1649227450.587002681] [minimal_hbmem_subscriber]: msg 15, time cost 1768us
Press Ctrl+C to stop each node.
Usage Limitations​
Compared to ROS2's publisher/subscriber data transfer method, using zero-copy transfer has the following limitations:
  • QOS History only supports KEEPLAST, not KEEPALL, and KEEPLAST cannot be set too high due to memory constraints. Currently, it is set to a maximum of 256MB.
  • The size of the transmitted message is fixed, meaning the sizeof value of the message is constant, and it cannot contain variable-length data types (e.g., string, dynamic arrays).
  • For TROS Humble and later versions, it is recommended to use RMW_QOS_POLICY_RELIABILITY_BEST_EFFORT for QOS Reliability (it is recommended to directly use rclcpp::SensorDataQoS() to set QOS). RMW_QOS_POLICY_RELIABILITY_RELIABLE has stability issues in various communication scenarios.
  • It can only be used for inter-process communication on the same device, not for cross-device transmission.
  • The publisher must first acquire the message before assigning values and sending, and must check whether the acquisition was successful.
  • The validity of messages received by the subscriber is limited to the callback function; they cannot be used outside the callback function.
