5.1.2 apt Installation and Upgrade
This section introduces how to install TogetheROS.Bot using apt on RDK platforms.
RDK Platform​
Prerequisites
  • Completed the work in Environment Preparation
  • Ubuntu system is installed on RDK
  • RDK can access the internet normally
  • RDK supports remote ssh
📋 System Version Confirmation and Download
Before installing TogetheROS, you need to confirm the system version and download the latest image. For system image download, please refer to: Download Resources Summary
Please note for RDK X3 platform:
Note
  • 2.x version tros.b only supports 2.x version system images. 1.x version tros.b only supports 1.x version systems.
  • If you are using a 1.x version system image, you need to upgrade from Environment Preparation to 2.x version.
  • For system and tros.b version checking methods and detailed instructions, please refer to FAQs.
Dependency1.x tros.b2.x tros.b
1.x System Image√x
2.x System Imagex√
Installing tros.b​
Note: The RDK IP used here is 10.64.61.241. Replace with your own RDK IP during installation.
Log in to RDK:
ssh root@10.64.61.241
Install tros.b package:
sudo apt update
sudo apt install tros
sudo apt update
sudo apt install tros-humble
sudo apt update
sudo apt install tros-jazzy
Note
  • If the sudo apt update command fails or reports an error, please refer to the FAQ section Q10: How to handle apt update command failure or error? for resolution.
  • If after running the install command you see E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution). , first run apt --fix-broken install to install related dependencies, then install tros.b.
Note
Note
  • If the sudo apt update command fails or reports an error, please refer to the FAQ section Q6: How to handle apt update command failure or error? for resolution.
Note
After installation, check files in the /opt directory
root@ubuntu:/userdata# ls /opt/
hobot tros
You can see tros.b is installed in the /opt directory.
Upgrading tros.b​
The following uses RDK installation as an example to introduce the upgrade method.
Log in to RDK
Upgrade tros.b deb package
sudo apt update
sudo apt upgrade
Note
Note
Note
Note
Check Current tros.b Version​
root@ubuntu:~# apt show tros
Package: tros
Version: 2.0.0-20230523223852
Maintainer: kairui.wang <kairui.wang@d-robotics.cc>
Installed-Size: unknown
Depends: hobot-models-basic, tros-ros-base, tros-ai-msgs, tros-audio-control, tros-audio-msg, tros-audio-tracking, tros-body-tracking, tros-dnn-benchmark-example, tros-dnn-node, tros-dnn-node-example, tros-dnn-node-sample, tros-elevation-net, tros-gesture-control, tros-hand-gesture-detection, tros-hand-lmk-detection, tros-hbm-img-msgs, tros-hobot-app-xrrobot-body-tracking, tros-hobot-app-xrrobot-gesture-control, tros-hobot-codec, tros-hobot-cv, tros-hobot-falldown-detection, tros-hobot-hdmi, tros-hobot-image-publisher, tros-hobot-mot, tros-hobot-usb-cam, tros-image-subscribe-example, tros-img-msgs, tros-imu-sensor, tros-line-follower-model, tros-line-follower-perception, tros-mipi-cam, tros-mono2d-body-detection, tros-mono2d-trash-detection, tros-mono3d-indoor-detection, tros-parking-perception, tros-parking-search, tros-rgbd-sensor, tros-websocket, tros-xrrobot, tros-xrrobot-msgs
Download-Size: 980 B
APT-Manual-Installed: yes
APT-Sources: http://archive.d-robotics.cc/ubuntu-rdk focal/main arm64 Packages
Description: TogetheROS Bot
You can see the current tros.b version has been upgraded to 2.0.0.
root@ubuntu:~# apt show tros-humble
Package: tros-humble
Version: 2.2.0-jammy.20240410.221258
Priority: optional
Section: misc
Maintainer: zhuo <zhuo.wang@d-robotics.cc>
Installed-Size: 44.0 kB
Depends: hobot-models-basic, tros-humble-ai-msgs, tros-humble-audio-control, tros-humble-audio-msg, tros-humble-audio-tracking, tros-humble-base, tros-humble-body-tracking, tros-humble-dnn-benchmark-example, tros-humble-dnn-node, tros-humble-dnn-node-example, tros-humble-dnn-node-sample, tros-humble-elevation-net, tros-humble-gesture-control, tros-humble-hand-gesture-detection, tros-humble-hand-lmk-detection, tros-humble-hbm-img-msgs, tros-humble-hobot-audio, tros-humble-hobot-chatbot, tros-humble-hobot-codec, tros-humble-hobot-cv, tros-humble-hobot-falldown-detection, tros-humble-hobot-hdmi, tros-humble-hobot-image-publisher, tros-humble-hobot-llm, tros-humble-hobot-mot, tros-humble-hobot-shm, tros-humble-hobot-tts, tros-humble-hobot-usb-cam, tros-humble-hobot-vio, tros-humble-hobot-visualization, tros-humble-img-msgs, tros-humble-imu-sensor, tros-humble-line-follower-model, tros-humble-line-follower-perception, tros-humble-mipi-cam, tros-humble-mono2d-body-detection, tros-humble-mono2d-trash-detection, tros-humble-mono3d-indoor-detection, tros-humble-parking-perception, tros-humble-parking-search, tros-humble-rgbd-sensor, tros-humble-websocket, tros-humble-ros-workspace
Download-Size: 5,546 B
APT-Sources: http://archive.d-robotics.cc/ubuntu-rdk jammy/main arm64 Packages
You can see the current tros.b version has been upgraded to 2.2.0.
root@ubuntu:~# apt show tros-jazzy
Package: tros-jazzy
Version: 2.5.0-noble.20251202.080038
Priority: optional
Section: misc
Depends: hobot-models-basic, tros-jazzy-ai-msgs, tros-jazzy-audio-control, tros-jazzy-audio-msg, tros-jazzy-audio-tracking, tros-jazzy-base, tros-jazzy-body-tracking, tros-jazzy-dnn-benchmark-example, tros-jazzy-dnn-node, tros-jazzy-dnn-node-example, tros-jazzy-dnn-node-sample, tros-jazzy-elevation-net, tros-jazzy-gesture-control, tros-jazzy-hand-gesture-detection, tros-jazzy-hand-lmk-detection, tros-jazzy-hbm-img-msgs, tros-humble-hobot-audio, tros-jazzy-hobot-chatbot, tros-jazzy-hobot-codec, tros-jazzy-hobot-cv, tros-jazzy-hobot-falldown-detection, tros-jazzy-hobot-hdmi, tros-jazzy-hobot-image-publisher, tros-jazzy-hobot-llm, tros-jazzy-hobot-mot, tros-jazzy-hobot-shm, tros-jazzy-hobot-tts, tros-jazzy-hobot-usb-cam, tros-jazzy-hobot-vio, tros-humble-hobot-visualization, tros-jazzy-img-msgs, tros-jazzy-imu-sensor, tros-jazzy-line-follower-model, tros-humble-line-follower-perception, tros-jazzy-mipi-cam, tros-jazzy-mono2d-body-detection, tros-jazzy-mono2d-trash-detection, tros-jazzy-mono3d-indoor-detection, tros-jazzy-parking-perception, tros-jazzy-parking-search, tros-jazzy-rgbd-sensor, tros-jazzy-websocket, tros-jazzy-ros-workspace
APT-Sources: http://archive.d-robotics.cc/ubuntu-rdk-s600 noble/main arm64 Packages
You can see the current tros.b version has been upgraded to 2.5.0.
Note
  • The version number Version displayed in the query is the actually installed tros.b version, which may differ from the version number Version shown in this example.
  • For tros.b release version information, see Release Notes.
