5.5.4 Performance Flame Graph
Introduction
A flame graph is a graphical way to display performance data collected by tools such as perf. It aggregates and analyzes the data to help identify performance hotspots.
Each box in a flame graph represents a function. The width of a box represents its execution time, so wider functions take longer to execute.
Each level higher in the flame graph represents a deeper function call. The top-level functions are leaf functions.
Code repository: (https://github.com/brendangregg/FlameGraph.git)
Supported Platforms
| Platform | Runtime Environment |
| RDK X3, RDK X3 Module | Ubuntu 20.04 (Foxy), Ubuntu 22.04 (Humble) |
| RDK X5, RDK X5 Module | Ubuntu 22.04 (Humble) |
Preparation
RDK Platform
The flame graph tool consists of two parts. The first part is the
perfexecutable.perfis a software performance analysis tool used to collect and output function call statistics for the system or a specific process. The RDK operating system already includesperf, so you can use it directly. -
The second part of the flame graph tool is a script that parses perf text output. The script parses the text data collected by perf and generates an SVG function call flame graph for easy observation and analysis.
Usage
Use the
perf recordtool to sample function calls on the RDK system and generate aperf.datafile.root@ubuntu:~# perf record -F 99 -a -g -- sleep 60 -
Use
perf scriptto parse theperf.datafile and generateout.perf.root@ubuntu:~# perf script > out.perf -
On a PC or RDK, run
git clone https://github.com/brendangregg/FlameGraph.git, enter the flamegraph directory, and copy theout.perffile generated in step 2 into the flamegraph directory. Usestackcollapse-perf.plfrom the flame graph tool package to collapseout.perfintoout.folded../stackcollapse-perf.pl out.perf > out.folded -
Use
flamegraph.plto generate an SVG flame graph../flamegraph.pl out.folded > flame.svg
Steps 1 and 2 are performed on the RDK. Steps 3 and 4 can be performed on a PC or RDK.
Result Analysis
After following the workflow in the previous section, the function calls recorded on the RDK system are shown below.
