5.2.3 Image Encoding and Decoding
Overview
The image encoding and decoding functionality is similar to the ROS image_transport package. RDK uses hardware units to accelerate conversion between MJPEG/H264/H265 and BGR8/RGB8/NV12 formats, which can significantly reduce CPU usage while improving format conversion efficiency.
Code repository: (https://github.com/D-Robotics/hobot_codec)
Supported Platforms
| Platform | Runtime Environment | Example Function |
| RDK X3, RDK X3 Module | Ubuntu 20.04 (Foxy), Ubuntu 22.04 (Humble) | Start MIPI camera to capture images, encode them, and display via Web |
| RDK X5, RDK X5 Module, RDK S100 | Ubuntu 22.04 (Humble) | Start MIPI camera to capture images, encode them, and display via Web |
| RDK S600 | Ubuntu 24.04 (Jazzy) | Start MIPI camera to capture images, encode them, and display via Web |
Prerequisites
RDK Platform
RDK has been flashed with the Ubuntu system image.
TogetheROS.Bot has been successfully installed on RDK.
RDK is connected to an F37 or other MIPI camera.
Usage
The following uses JPEG encoding as an example to describe obtaining NV12 format image data from a camera or image publisher tool, compressing and encoding it as JPEG, and previewing the image on a PC web browser.
RDK Platform
Obtain YUV data and start JPEG encoding:
Log in to RDK via SSH, use mipi_cam as the data source, configure hobot_codec input as NV12 format and output as JPEG format. You can change mipi_cam to the actual sensor model in use.
a. Start mipi_cam
- Foxy
- Humble
source /opt/tros/setup.bash# Configure tros.b environment
source /opt/tros/humble/setup.bash- Humble
source /opt/tros/humble/setup.bash- Jazzy
source /opt/tros/jazzy/setup.bashros2 launch mipi_cam mipi_cam.launch.py mipi_video_device:=F37b. Start hobot_codec encoding
- Foxy
- Humble
source /opt/tros/jazzy/setup.bashros2 launch hobot_codec hobot_codec_encode.launch.py codec_in_mode:=shared_mem codec_in_format:=nv12 codec_out_mode:=ros codec_out_format:=jpeg codec_sub_topic:=/hbmem_img codec_pub_topic:=/image_jpeg -
View JPEG encoded images on the web. Open another terminal:
- Foxy
- Humble
source /opt/tros/jazzy/setup.bashros2 launch websocket websocket.launch.py websocket_image_topic:=/image_jpeg websocket_only_show_image:=true -
Open a browser on the PC (Chrome/Firefox/Edge) and enter
http://IP:8000, where IP is the RDK device IP address. Click Web Display in the upper left to view the real-time JPEG encoded feed.
Notes
If the Hobot codec node fails to start, troubleshoot using the following steps:
- Check whether the tros.b environment is configured
- Verify parameters are correct. For details, refer to the Hobot_codec README.md
