5.2.5 Data Communication
Zero-Copy
Overview
TogetheROS.Bot provides flexible and efficient zero-copy functionality that can significantly reduce communication latency and CPU usage for large data transfers. tros.b integrates the performance_test tool to conveniently benchmark performance differences before and after enabling zero-copy. The performance_test tool supports configuration of subscriber count, message size, QoS, and other parameters to evaluate communication performance in different scenarios. The main performance metrics are as follows:
- Latency: the transmission time from pub to sub for each message
- CPU usage: the percentage of CPU used by communication activity
- Resident memory: includes heap-allocated memory, shared memory, and stack memory used internally by the system
- Sample statistics: includes the number of messages sent, received, and lost in each experiment
Code repositories:
- https://github.com/D-Robotics/rclcpp
- https://github.com/D-Robotics/rcl_interfaces
- https://github.com/D-Robotics/benchmark
- The tros.b Foxy version adds the "zero-copy" feature based on ROS2 Foxy.
- The tros.b Humble version and later versions use the ROS2 "zero-copy" feature.
Supported Platforms
| Platform | Runtime Environment |
| RDK X3, RDK X3 Module | Ubuntu 20.04 (Foxy), Ubuntu 22.04 (Humble) |
| RDK X5, RDK X5 Module, RDK S100 | Ubuntu 22.04 (Humble) |
| RDK S600 | Ubuntu 24.04 (Jazzy) |
Prerequisites
RDK
Before testing, set the RDK to performance mode to ensure accurate test results. Run the following command:
echo performance > /sys/devices/system/cpu/cpufreq/policy0/scaling_governorFor more configuration details, refer to the System Configuration section.
The performance_test package has been successfully installed on RDK. Installation command:
- Foxy
- Humble
sudo apt update
sudo apt install tros-performance-testsudo apt update
sudo apt install tros-humble-performance-test- Humble
sudo apt update
sudo apt update
sudo apt install tros-humble-performance-test- Jazzy
sudo apt update
sudo apt install tros-jazzy-performance-test
If the sudo apt update command fails or reports an error, please refer to the FAQ section Q10: How to handle apt update command failure or error? for resolution.
If the sudo apt update command fails or reports an error, please refer to the FAQ section Q6: How to handle apt update command failure or error? for resolution.
Usage
RDK Platform
- 4M data transfer test without zero-copy enabled. Run the following command:
- Foxy
- Humble
source /opt/tros/setup.bash
ros2 run performance_test perf_test --reliable --keep-last --history-depth 10 -s 1 -m Array4m -r 100 --max-runtime 30
- Humble
- Humble
- Jazzy
Test results are as follows:
run time
| T_experiment | 30.982817 | T_loop | 1.000126 |
samples latency
| recv | sent | lost | data_recv | relative_loss | | min | max | mean | variance |
| 99 | 100 | 0 | 418505326 | 0.000000 | | 0.004327 | 0.005605 | 0.004546 | 0.000000 |
publisher loop subscriber loop
| min | max | mean | variance | | min | max | mean | variance |
| 0.007260 | 0.008229 | 0.008057 | 0.000000 | | 0.000000 | 0.000000 | 0.000000 | 0.000000 |
system usage
| utime | stime | maxrss | ixrss | idrss | isrss | minflt | majflt |
| 23120954000 | 121597000 | 65092 | 0 | 0 | 0 | 11578 | 2 |
| nswap | inblock | oublock | msgsnd | msgrcv | nsignals | nvcsw | nivcsw |
| 0 | 0 | 0 | 0 | 0 | 0 | 9885 | 7193 |
Maximum runtime reached. Exiting.
- 4M data transfer test with zero-copy enabled (add the
--zero-copyparameter). Run the following command:
- Foxy
- Humble
ros2 run performance_test perf_test --zero-copy --reliable --keep-last --history-depth 10 -s 1 -m Array4m -r 100 --max-runtime 30
export RMW_IMPLEMENTATION=rmw_fastrtps_cpp
export FASTRTPS_DEFAULT_PROFILES_FILE=/opt/tros/humble/lib/hobot_shm/config/shm_fastdds.xml
export RMW_FASTRTPS_USE_QOS_FROM_XML=1
export ROS_DISABLE_LOANED_MESSAGES=0
- Humble
- Humble
- Jazzy
export FASTRTPS_DEFAULT_PROFILES_FILE=/opt/tros/jazzy/lib/hobot_shm/config/shm_fastdds.xml
run time
| T_experiment | 30.554773 | T_loop | 1.000084 |
samples latency
| 99 | 99 | 0 | 418701472 | 0.000000 | | 0.000146 | 0.000381 | 0.000195 | 0.000000 |
| 0.009812 | 0.009895 | 0.009877 | 0.000000 | | 0.000000 | 0.000000 | 0.000000 | 0.000000 |
system usage
| 8727113000 | 307920000 | 46224 | 0 | 0 | 0 | 6440 | 0 |
| 0 | 0 | 0 | 0 | 0 | 0 | 9734 | 2544 |
Result Analysis
The performance_test tool outputs various types of statistical results. The following mainly compares differences in latency and system usage:
latency Comparing the average communication latency with "zero-copy" disabled and enabled, the values are 4.546ms and 0.195ms respectively, showing that the "zero-copy" feature significantly reduces communication latency.
system usage
| userspace time (Hz)| system time (Hz)| resident memory size (Byte) | 0 | 0 | 0 | minor page fault count | major page fault count |
| 0 | 0 | 0 | 0 | 0 | 0 | voluntary context switch count| involuntary context switch count|
| Communication Mode | latency | utime+stime | maxrss | minflt | majflt | nvcsw | nivcsw |
| Non-"zero-copy" | 0.004546 | 23242551000 | 65092 | 11578 | 2 | 9885 | 7193 |
| "zero-copy" | 0.000381 | 9035033000 | 46224 | 6440 | 0 | 9734 | 2544 |
Comparison shows:
- The sum of "zero-copy" utime and stime is significantly lower than non-"zero-copy", indicating that "zero-copy" consumes fewer CPU resources
- "zero-copy" maxrss is less than non-"zero-copy", indicating that "zero-copy" uses less memory
- "zero-copy" minflt and majflt are significantly less than non-"zero-copy", indicating less communication jitter with "zero-copy"
- "zero-copy" nvcsw and nivcsw are significantly less than non-"zero-copy", indicating less communication jitter with "zero-copy"
Overall, for large data communication, "zero-copy" is significantly better than non-"zero-copy" in terms of CPU consumption, memory usage, and communication latency jitter
