Version
4.7.6. hb_gpioinfo
hb_gpioinfo is a tool used to display GPIO pin information. It supports the following features:
  • Display basic information of GPIO pins (e.g., pin name, offset, direction, bias, drive mode, etc.).
  • Display the current state of pins (e.g., input/output, active-low, edge detection, etc.).
  • Display additional functional information of pins for specific platforms (e.g., pin function, pin number, etc.).
4.7.6.1. Syntax Description
Below is the command format for executing hb_gpioinfo:
hb_gpioinfo [OPTIONS] [line]...
4.7.6.2. Parameter Options Description
Below are the options supported by chip_log and their descriptions:
  • -c, --chip <chip>: Restrict scope to a specific GPIO chip.
  • -h, --help: Display help information and exit.
  • -s, --strict: Check all lines—do not assume pin names are unique.
  • -v, --version: Display version information and exit.
4.7.6.3. Command Options and Their Function Descriptions
Display Help Information
Command:
hb_gpioinfo --help
Function:
Display usage help information for this command.
Usage: hb_gpioinfo [OPTIONS] [line]...
Print information about GPIO lines.
Lines are specified by name, or optionally by offset if the chip option is provided.
If no lines are specified then all lines are displayed.
  -c, --chip <chip>	restrict scope to a particular chip
  -h, --help	display this help and exit
  -s, --strict	check all lines - don't assume line names are unique
      --unquoted	don't quote line or consumer names
  -v, --version	output version information and exit
Display All GPIO Pin Information
Command:
root@buildroot:~# hb_gpioinfo
Function:
Display detailed information for all GPIO pins in the system.
Output:
        [Number]                [Mode]  [Status]  [GpioName]       [PinName]          [PinNum]   [PinFunc]
        line  0:        unnamed input                             AON_GPIO_PIN0         498      aon_gpio_0
        line  1:        unnamed input                             AON_GPIO_PIN1         499      Default
        line  2:        unnamed input  active-low  GPIO Key Power AON_GPIO_PIN2         500      aon_gpio_2
        line  3:        unnamed input                             AON_GPIO_PIN3         501      Default
        line  4:        unnamed input                             AON_GPIO_PIN4         502      aon_gpio_4
        line  5:        unnamed input              id             AON_ENV_VDD           503      aon_gpio_5
        line  6:        unnamed input              id             AON_ENV_CNN0          504      aon_gpio_6
        line  7:        unnamed input                             AON_ENV_CNN1          505      aon_gpio_7
        line  0:        unnamed input                             HSIO_ENET_MDC         466      enetgrp
        line  1:        unnamed input                             HSIO_ENET_MDIO        467      enetgrp
        line  2:        unnamed input                             HSIO_ENET_TXD_0       468      enetgrp
        line  3:        unnamed input                             HSIO_ENET_TXD_1       469      enetgrp
        line  4:        unnamed input                             HSIO_ENET_TXD_2       470      enetgrp
        line  5:        unnamed input                             HSIO_ENET_TXD_3       471      enetgrp
        line  6:        unnamed input                             HSIO_ENET_TXEN        472      enetgrp
        line  7:        unnamed input                             HSIO_ENET_TX_CLK      473      enetgrp
        line  8:        unnamed input                             HSIO_ENET_RX_CLK      474      enetgrp
        line  9:        unnamed input                             HSIO_ENET_RXD_0       475      enetgrp
        line 10:        unnamed input                             HSIO_ENET_RXD_1       476      enetgrp
        line 11:        unnamed input                             HSIO_ENET_RXD_2       477      enetgrp
        line 12:        unnamed input                             HSIO_ENET_RXD_3       478      enetgrp
        line 13:        unnamed input                             HSIO_ENET_RXDV        479      enetgrp
        line 14:        unnamed input                             HSIO_ENET_PHY_CLK     480      enetgrp
        line 15:        unnamed input                             HSIO_SD_WP            481      sdgrp
        line 16:        unnamed input                             HSIO_SD_XLK           482      sdgrp
        line 17:        unnamed input                             HSIO_SD_CMD           483      sdgrp
        line 18:        unnamed input                             HSIO_SD_CDN           484      sdgrp
        line 19:        unnamed input                             HSIO_SD_DATA0         485      sdgrp
        line 20:        unnamed input                             HSIO_SD_DATA1         486      sdgrp
        line 21:        unnamed input                             HSIO_SD_DATA2         487      sdgrp
        line 22:        unnamed input                             HSIO_SD_DATA3         488      sdgrp
        line 23:        unnamed input                             HSIO_SDIO_WP          489      sdiogrp
        line 24:        unnamed input                             HSIO_SDIO_XLK         490      sdiogrp
        line 25:        unnamed input                             HSIO_SDIO_CMD         491      sdiogrp
        line 26:        unnamed output             power          HSIO_SDIO_CDN         492      hsio_gpio0_26
        line 27:        unnamed input                             HSIO_SDIO_DATA0       493      sdiogrp
        line 28:        unnamed input                             HSIO_SDIO_DATA1       494      sdiogrp
        line 29:        unnamed input                             HSIO_SDIO_DATA2       495      sdiogrp
        line 30:        unnamed input                             HSIO_SDIO_DATA3       496      sdiogrp
Result Explanation:
Detailed information for each pin is displayed in the following format:
line <N>: <GpioName> <Mode> <Status> <PinName> <PinNum> <PinFunc>
  • line <N>: The pin number.
  • <GpioName>: The name of the GPIO pin (displayed as “unnamed” if not named).
  • <Mode>: The pin mode (e.g., input or output).
  • <Status>: The pin status (e.g., active-low, bias=pull-up, drive=open-drain, etc.).
  • <PinName>: The name of the pin.
  • <PinNum>: The pin number.
  • <PinFunc>: The multiplexing function of the pin.
Display Information for a Specific GPIO Chip
Command:
root@buildroot:~# hb_gpioinfo -c gpiochip4
Function:
Display pin information only for GPIO chip gpiochip4.
Output:
        line  0:        unnamed input                             LSIO_UART7_RX         379      lsio_gpio0_0
        line  1:        unnamed input                             LSIO_UART7_TX         380      lsio_gpio0_1
        line  2:        unnamed input                             LSIO_UART7_CTS        381      lsio_gpio0_2
        line  3:        unnamed input                             LSIO_UART7_RTS        382      lsio_gpio0_3
        line  4:        unnamed input                             LSIO_UART1_RX         383      lsio_gpio0_4
        line  5:        unnamed input                             LSIO_UART1_TX         384      lsio_gpio0_5
        line  6:        unnamed input                             LSIO_UART1_CTS        385      lsio_gpio0_6
        line  7:        unnamed input                             LSIO_UART1_RTS        386      lsio_gpio0_7
        line  8:        unnamed input                             LSIO_UART2_RX         387      uart2grp
        line  9:        unnamed input                             LSIO_UART2_TX         388      uart2grp
        line 10:        unnamed input              scl            LSIO_UART3_RX         389      i2c5grp
        line 11:        unnamed input              sda            LSIO_UART3_TX         390      i2c5grp
        line 12:        unnamed input                             LSIO_UART4_RX         391      lsio_gpio0_12
        line 13:        unnamed input                             LSIO_UART4_TX         392      lsio_gpio0_13
        line 14:        unnamed input                             LSIO_SPI0_SCLK        393      Default
        line 15:        unnamed input                             LSIO_SPI1_SSN_1       394      Default
        line 16:        unnamed input                             LSIO_SPI1_SCLK        395      Default
        line 17:        unnamed input                             LSIO_SPI1_SSN         396      Default
        line 18:        unnamed input                             LSIO_SPI1_MISO        397      Default
        line 19:        unnamed input                             LSIO_SPI1_MOSI        398      Default
        line 20:        unnamed input                             LSIO_SPI2_SCLK        399      spi2grp
        line 21:        unnamed input                             LSIO_SPI2_SSN         400      spi2grp
        line 22:        unnamed input                             LSIO_SPI2_MISO        401      spi2grp
        line 23:        unnamed input                             LSIO_SPI2_MOSI        402      spi2grp
        line 24:        unnamed input                             LSIO_SPI3_SCLK        403      lsio_gpio0_24
        line 25:        unnamed input                             LSIO_SPI3_SSN         404      pinctrl_lpwm1_1
        line 26:        unnamed input                             LSIO_SPI3_MISO        405      lsio_gpio0_26
        line 27:        unnamed input                             LSIO_SPI3_MOSI        406      lsio_gpio0_27
        line 28:        unnamed input                             LSIO_SPI4_SCLK        407      uart5grp
        line 29:        unnamed input                             LSIO_SPI4_SSN         408      uart5grp
        line 30:        unnamed input                             LSIO_SPI4_MISO        409      lsio_gpio0_30
        line 31:        unnamed output             phyreset       LSIO_SPI4_MOSI        410      lsio_gpio0_31
