Gesture Interaction
This feature integrates D-Robotics' gesture recognition algorithm to enable interaction with the RDK X5 Magicbox through hand gestures.
IP Address Explanation
Model Information​
FunctionModelInput SizeInference Frame Rate (fps)
Human Detectionfastrcnn1x3x544x960125.21
Hand Keypoint DetectionhandLMKs8x21948
Gesture RecognitiongestureDet8x211252.44
Hand Gestures and Trigger Actions​
GestureHand MovementTrigger Action
ThumbUpThumbs upRocking arm shakes
Victory"V" gestureRocking arm lifts
ThumbLeftThumb pointing leftRaise left rocking arm
ThumbRightThumb pointing rightRaise right rocking arm
OkayOK gestureLight flashes
Functional Architecture Diagram​
Startup Steps​
  1. Use the following command to start the gesture interaction feature.
      cd /userdata/magicbox
    source app/ros_ws/install/setup.bash
    ros2 launch gesture_interaction gesture_interaction.launch.py
  2. Access [IP]:8000 via a web browser to view the gesture interaction results.
    Interaction Results
Reference Materials​
User Manual: Gesture Recognition
