Configure U-Boot and Kernel Option Parameters
In system software development, it is often necessary to configure U-Boot and Kernel option parameters. This chapter introduces some common configuration methods for user reference.
Configure U-Boot Option Parameters​
Note
The following instructions take modifying the board_x5_rdk_ubuntu_nand_sdcard_debug_config configuration file as an example.
The specific U-Boot configuration file used can be checked in the bootloader/device/.board_config.mk board-level configuration file under the HR_UBOOT_CONFIG_FILE variable value after running ./xbuild.sh lunch.
Configuring via the xbuild Command​
First, enter the source/bootloader directory. The directory structure is as follows:
├── build           # System code compilation directory, provides shell scripts for compiling various functional modules, and tools used in compilation
├── device # Board-level configuration directory, each hardware platform has its corresponding configuration file where you can set compilation options and partition tables
├── miniboot # Generates the minimal boot firmware containing GPT, MBR, BL2, DDR, and BL3x
├── out # Compilation output directory
└── uboot # U-Boot source code
build/xbuild.sh is the main build script that provides the following commands to help users configure U-Boot options. This command will automatically use the U-Boot configuration file set in the board-level configuration file. After the configuration is completed, it will automatically save the savedefconfig and other relevant files.
./xbuild.sh uboot menuconfig
After the command is successfully executed, the U-Boot graphical configuration interface will open. You can complete the option configurations in this interactive interface, including removing unnecessary features and enabling the required ones.
U-Boot Graphical Configuration
After completing the configuration in the menuconfig interface, select Exit to exit. Follow the prompts to choose either Yes or No to save the changes to the .config file.
Save Configuration
After exiting the configuration, the configuration file will be automatically saved. The automatic tasks include:
# Call `savedefconfig` to clean the configuration file, keep the necessary items, remove dependencies, and generate the `defconfig` file
make savedefconfig
# Use the `defconfig` file to overwrite the U-Boot configuration file set in the board-level configuration file
cp -f defconfig <U-Boot configuration file set in the board-level configuration file>
Manual Configuration​
First, navigate to the source/bootloader/uboot directory and execute the command make ARCH=arm64 hobot_x5_rdk_nand_defconfig. The make command will first execute the Makefile in the top-level directory. For targets ending with config, there is a common entry point:
%config: scripts_basic outputmakefile FORCE
$(Q)$(MAKE) $(build)=scripts/kconfig $@
The expanded command to be executed is:
make -f ./scripts/Makefile.build obj=scripts/kconfig hobot_x5_rdk_nand_defconfig
After executing this command, a .config file will be generated in the root directory of the uboot source code.
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
YACC scripts/kconfig/zconf.tab.c
LEX scripts/kconfig/zconf.lex.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
# configuration written to .config
Then, you can execute make ARCH=arm64 menuconfig to open the graphical configuration interface for configuring U-Boot options.
Once the configuration is saved, you can run the command diff .config configs/hobot_x5_rdk_nand_defconfig to compare the differences and verify that the changes are as expected.
If the modifications are correct, execute cp .config configs/hobot_x5_rdk_nand_defconfig to replace the default configuration file.
To clean up the .config and other files in the source directory, otherwise, when recompiling the system, you may encounter a warning saying xxx is not clean, please run 'make mrproper':
make distclean
# or
make mrproper
Configuring Kernel Option Parameters​
Note
The following instructions use the hobot_x5_rdk_ubuntu_defconfig configuration file as an example.
The specific configuration file used by the kernel can be found in the kernel_config_file variable in the mk_kernel.sh script.
Configuring via mk_kernel Command​
The mk_kernel.sh script provides the following commands to help users configure Kernel options. This command will automatically use the Kernel configuration file set in the board-level configuration file. After the configuration is complete, it will automatically perform savedefconfig and save the changes.
./mk_kernel.sh menuconfig
After executing the command successfully, the Kernel graphical configuration interface will open. You can complete the configuration options in this interactive interface, including removing unnecessary features and enabling the required ones.
Kernel Configuration Interface
Save Configuration
make savedefconfig
# Use the `defconfig` file to overwrite the Kernel configuration file set in the board-level configuration file
cp defconfig <Kernel configuration file set in the board-level configuration file>
The process of configuring the kernel via menuconfig is the same as configuring uboot. The execution steps are as follows:
First, navigate to the boot/kernel directory and then follow these steps to configure the kernel options.
  • Use hobot_x5_rdk_ubuntu_defconfig to generate the .config file. If a full build has been performed on the source code, the .config file will already be configured.
make ARCH=arm64 hobot_x5_rdk_ubuntu_defconfig
  • Execute the following command to modify the configuration
  • After making the changes, you can first check the differences between the modified and the original configuration.
diff .config arch/arm64/configs/hobot_x5_rdk_ubuntu_defconfig
  • Overwrite the hobot_x5_rdk_ubuntu_defconfig with the new configuration.
cp .config arch/arm64/configs/hobot_x5_rdk_ubuntu_defconfig
  • Clean up the .config and other files in the source directory; otherwise, when recompiling the system, you may encounter a message saying xxx is not clean, please run 'make mrproper'.
make distclean
# or
make mrproper
Modifying the Kernel DTS​
This section introduces the DTS (Device Tree Source) file structure of the RDK product and explains how to modify it to support secondary development.
The kernel DTS files are located in x5-rdk-gen/source/kernel/arch/arm64/boot/dts/hobot/.
Note
  • DTS files describe hardware resource allocations (such as GPIO, I²C, SPI, interrupt numbers, memory addresses, etc.). Incorrect modifications may cause the device to fail to boot, drivers to fail to load, or even damage the hardware.
  • Misconfigurations may also lead to kernel build failures or prevent the system from booting properly. In severe cases, you may need to re-flash the system image to recover.
Kernel Device Tree​
DTS FilePurpose
pinmux-func.dtsiDefines the functional groups of each pin.
pinmux-gpio.dtsiDefines GPIO groups.
x5.dtsiDefines the default configuration of all modules on the X5 platform. It serves as the base hardware description and is not recommended for user modification.
x5-rdk.dtsiDefines common configuration items for different SDK hardware versions. It includes the default configuration from x5.dtsi.
x5-board.dtsBoard-level device tree file. It includes the default configuration from x5.dtsi and defines enabling/disabling of functional modules as well as hardware-specific peripheral configurations.
Inclusion Hierarchy​
x5-board.dts → x5-rdk.dtsi → x5.dtsi → (pinmux-func.dtsi and pinmux-gpio.dtsi)
Board-Level DTS Files​
The hardware version can be identified from the silkscreen on the board, or by running the hrut_boardid command and checking the board_id.
Hardware Versionboard_idDTS File
RDK X5 V0.10x301x5-rdk.dts
RDK X5 V1.00x302x5-rdk-v1p0.dts
RDK X5 MD V0.10x501x5-md-v0p1.dts
RDK X5 MD V0.20x502x5-md-v0p2.dts
RDK X5 MD V0.30x503x5-md-v0p2.dts
RDK X5 MD V1.00x504x5-md-v0p2.dts
RDK X5 MD V1.10x505x5-md-v0p2.dts
Build​
In the x5-rdk-gen directory, use the mk_kernel.sh script to build the kernel:
sudo ./mk_kernel.sh
After compilation, the DTB files will be generated in the x5-rdk-gen/deploy/kernel/dtb/ directory. You can copy them to the /boot/hobot/ directory on the board, and the system will automatically load them on boot.
Alternatively, you can run the following command to package the kernel DTB files into a .deb package for system installation.
sudo ./mk_debs.sh hobot-dtb
The generated .deb file will be located atx5-rdk-gen/deploy/deb_pkgs/hobot-dtb_version-date_arm64.deb
