LCD Driver Debugging Guide
1. Specifications​
The MIPI-DSI interface specifications for X5 are as follows:
  • Supports up to four data lanes
  • The maximum rate for each lane is 2.5Gbps
  • Supports Non-Burst-Sync-Pulse synchronous pulse mode, Non-Burst-Sync-Even synchronous event mode, and Burst mode
  • Supports MIPI_DSI_CLOCK_NON_CONTINUOUS non-continuous clock mode and MIPI_DSI_CLOCK_CONTINUOUS continuous clock mode
2. Debugging Process​
Before adding a new screen driver, the following information needs to be determined:
  • The screen's timing, including hbp (horizontal back porch), hfp (horizontal front porch), hsa (horizontal sync active), vbp (vertical back porch), vfp (vertical front porch), and vsa (vertical sync active)
  • The screen's initialization sequence
  • The supported transmission mode of the screen, whether it is burst or non-burst
  • The supported clock mode of the screen, whether it is continuous or non-continuous
Taking the JC050HD134 screen as an example, the following information can be derived from the configuration provided by the manufacturer:
#define Width 720
#define Height 1280
#define VFP 20
#define VBP 20
#define VSA 4
#define HFP 32
#define HBP 20
#define HSA 20
Kernel Driver Layer​
In the kernel, there is a pre-debugged reference driver: panel-atk-md0550.c. Future panel drivers can be derived from this driver.
Copy the panel-atk-md0550.c file from kernel/drivers/gpu/drm/panel/ and rename it as panel-jc-050hd134.c.
The following modifications are based on panel-jc-050hd134.c.
Modify the name attribute in panel_simple_dsi_driver to panel-jc-050hd134:
static struct mipi_dsi_driver panel_simple_dsi_driver = {
.driver =
.name = "panel-jc-050hd134",
.of_match_table = dsi_of_match,
.probe = panel_simple_dsi_probe,
.remove = panel_simple_dsi_remove,
.shutdown = panel_simple_dsi_shutdown,
Modify the drm_display_mode structure:
static const struct drm_display_mode jc_050hd134_mode = { // Change structure name to jc_050hd134_mode
.clock = 65000, // Pixel clock in kHz, calculated by: fps * (htotal + vtotal)
.hdisplay = 720, // Horizontal display area width
.hsync_start = 720 + 32, // hdisplay + hfp (Horizontal Front Porch)
.hsync_end = 720 + 32 + 20, // hsync_start + hsa (Horizontal Sync Active)
.htotal = 720 + 32 + 20 + 20, // hsync_end + hbp (Horizontal Back Porch)
.vdisplay = 1280, // Vertical display area height
.vsync_start = 1280 + 20, // vdisplay + vfp (Vertical Front Porch)
.vsync_end = 1280 + 20 + 4, // vsync_start + vsa (Vertical Sync Active)
.vtotal = 1280 + 20 + 4 + 20, // vsync_end + vbp (Vertical Back Porch)
.flags = DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC, // Polarity flags
Modify the panel_desc_dsi structure as follows:
static const struct panel_desc_dsi jc_050hd134 = { // Rename structure to jc_050hd134
.desc =
.modes = &jc_050hd134_mode, // Points to the timing structure
.num_modes = 1, // Number of timing modes for this panel, typically 1
.bpc = 8, // Bits per color, RGB888 means 8 bits per color, RGB666 means 6 bits per color
.size = // Physical size of the visible area in mm
.width = 62,
.height = 110,
.connector_type = DRM_MODE_CONNECTOR_DSI, // DSI connector type
.flags = MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_SYNC_PULSE, // DSI mode flags, indicating video mode and non-burst mode
// For more flags, refer to kernel/include/drm/drm_mipi_dsi.h
.format = MIPI_DSI_FMT_RGB888, // Panel color format
.lanes = 4, // Number of data lanes
Modify the dsi_of_match to prepare for binding the device tree:
static const struct of_device_id dsi_of_match[] = {
{.compatible = "jc-050hd134", .data = &jc_050hd134}, // Bind the device tree compatible string to the panel description
/* sentinel */
MODULE_DEVICE_TABLE(of, dsi_of_match); // Register the device table for device tree matching
Modify the panel_simple_dsi_init function. This function essentially calls the dsi_dcs_write_seq function to write the MIPI initialization sequence to the panel.
If you receive the initialization parameters from the screen manufacturer in the following format:
DSI_CMD(0x04);DSI_PA(0xB9);
DSI_PA(0xF1);
DSI_PA(0x12);
DSI_PA(0x83);
DSI_CMD(0x1C);DSI_PA(0xBA);
DSI_PA(0x33); // 1
DSI_PA(0x81); // 2
DSI_PA(0x05); // 3
DSI_PA(0xF9); // 4
DSI_PA(0x0E); // 5
DSI_PA(0x0E); // 6
DSI_PA(0x20); // 7
DSI_PA(0x00); // 8
DSI_PA(0x00); // 9
DSI_PA(0x00); //10
DSI_PA(0x00); //11
DSI_PA(0x00); //12
DSI_PA(0x00); //13
DSI_PA(0x00); //14
DSI_PA(0x44); //15
DSI_PA(0x25); //16
DSI_PA(0x00); //17
DSI_PA(0x91); //18
DSI_PA(0x0A); //19
DSI_PA(0x00); //20
DSI_PA(0x00); //21
DSI_PA(0x02); //22
DSI_PA(0x4F); //23
DSI_PA(0xD1); //24
DSI_PA(0x00); //25
DSI_PA(0x00); //26
DSI_PA(0x37); //27
Convert to Driver Code
dsi_dcs_write_seq(dsi, 0xb9, 0xF1, 0x12, 0x83);
dsi_dcs_write_seq(dsi, 0xBA, 0x33, 0x81, 0x05, 0xF9, 0x0E, 0x0E, 0x20, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x44, 0x25, 0x00, 0x91, 0x0A, 0x00, 0x00, 0x02,
0x4F, 0xD1, 0x00, 0x00, 0x37);
You can see that in the two sets of initialization sequences provided by the manufacturer, the first value written is the length of the initialization sequence itself. When converting this into driver code, you don't need to include it manually as it will be calculated automatically during the writing process.
If the initialization sequence provided by the screen manufacturer looks like the following:
panel-init-sequence-zero = [
39 00 04 B9 FF 83 94
15 00 02 36 01
39 00 07 BA 63 03 68 6B B2 C0
39 00 0B B1 48 12 72 09 32 54 71 71 57 47
Converting to Driver Code:
	dsi_dcs_write_seq(dsi, 0xb9, 0xff, 0x83, 0x94);
dsi_dcs_write_seq(dsi, 0x36, 0x01);
dsi_dcs_write_seq(dsi, 0xba, 0x63, 0x03, 0x68, 0x6b, 0xb2, 0xc0);
dsi_dcs_write_seq(dsi, 0xb1, 0x48, 0x12, 0x72, 0x09, 0x32, 0x54, 0x71, 0x71, 0x57, 0x47);
Here, we will explain the conversion using the first sequence 39 00 04 B9 FF 83 94 as an example:
  • 39 indicates that this sequence is written using the MIPI_DSI_DCS_LONG_WRITE (0x39) data type. When converting to driver code, you do not need to specify this manually; it will be automatically generated based on the length of the sequence.
  • 00 indicates that after this write operation, the system will sleep for 0ms, which can be implemented using the msleep(ms) function.
  • 04 marks the length of the write sequence, which will be automatically generated, so you do not need to fill it in.
  • The remaining data represents the initialization sequence itself.
For displays that require specific power-on-reset timing, you can modify the GPIO behavior in the panel_simple_prepare and panel_simple_unprepare functions, which correspond to the initialization and de-initialization states respectively.
To apply the changes, modify the following files:
  • kernel/drivers/gpu/drm/panel/Kconfig
  • kernel/drivers/gpu/drm/panel/Makefile
Kconfig:
config DRM_PANEL_JC_050HD134
tristate "JC 050HD134 panel"
depends on OF
depends on DRM_MIPI_DSI
depends on BACKLIGHT_CLASS_DEVICE
select VIDEOMODE_HELPERS
help
Say Y here if you want to enable support for the JC050HD134
panel with 720x1280 resolution. This panel support
MIPI DSI interface.
Makefile:
obj-$(CONFIG_DRM_PANEL_JC_050HD134) += panel-jc-050hd134.o
Kernel Device Tree Level​
At the board-level device tree, here we take kernel/arch/arm64/boot/dts/hobot/x5-evb.dts as an example.
Add the following properties to the mipi_dsi0 node:
&mipi_dsi0 {
dsi_panel0@0 {
compatible = "jc-050hd134"; // This should match dsi_of_match
reg = <0>;
pinctrl-0 = <&lsio_gpio0_14>; // Related to the reset pin
reset-gpios = <&ls_gpio0_porta 14 GPIO_ACTIVE_HIGH>; // Related to the reset pin. The active level should be decided based on your screen's specifications.
backlight = <&dsi_backlight>; // Backlight related
port {
panel_in: endpoint {
remote-endpoint =
<&mipi_dsi_out>;
添加dsi_backlight节点:
&dsi_backlight {
pwms = <&lpwm1 1 1000000>; // Related to hardware PCB, check where the backlight PWM signal is sourced from. This indicates the backlight signal comes from LPWM1_1.
// For other properties and details, please refer to kernel/Documentation/devicetree/bindings/leds/backlight/pwm-backlight.yaml
3. Compile​
Please refer to section 7.2.1 to set up the build environment and successfully compile the image before proceeding with the following steps!
Execute ./mk_kernel.sh menuconfig to enter the kernel configuration menu, and follow the path below to enter the Panels compilation options:
Device Drivers  --->
Graphics support --->
Display Panels --->
Find the JC 050HD134 panel, press the spacebar to compile it as a module. Then, save the configuration and exit.
Execute ./mk_kernel.sh to compile the kernel. After compilation, you can find the corresponding driver file panel-jc-050hd134.ko in the deploy/kernel/modules/lib/modules/6.1.83/kernel/drivers/gpu/drm/panel directory.
Execute the following commands to generate the required .deb packages:
  • ./mk_deb.sh hobot-dtb
  • ./mk_deb.sh hobot-boot
  • ./mk_deb.sh hobot-kernel-headers
The resulting .deb packages, such as hobot-dtb*.dtb, hobot-boot*.dtb, and hobot-kernel-headers*.dtb, will be located in the deploy/deb_pkgs/ directory.
These three .deb packages can be directly transferred to the device to update the device tree, kernel, driver files, and kernel headers. Alternatively, you can execute ./pack_image.sh to include them in the filesystem.
4. Testing​
After powering on the RDK X5, the display-related drivers will be loaded, and the Ubuntu desktop will appear. To enable the JC-050HD134 panel, you need to edit the /etc/init.d/S70loadko script. Add the modprobe panel-jc-050hd134 command before modprobe vio_n2d.
Since the RDK X5 system defaults to HDMI output, you need to switch to the MIPI DSI display mode by executing the following command:
mv /etc/X11/xorg.conf.d/xorg_dsi_ignore.conf /etc/X11/xorg.conf.d/xorg_dsi_ignore.conf.disable
mv /etc/X11/xorg.conf.d/xorg_hdmi_ignore.conf.disable /etc/X11/xorg.conf.d/xorg_hdmi_ignore.conf
You can also choose the display output method using raspi-config. For details, refer to the Display Choose DSI or HDMI section.
After rebooting the device, you should see the system desktop on the LCD screen.
If the LCD does not display anything, please verify the following steps:
  1. Check if the screen has backlight or a control chip and whether the corresponding driver has been loaded successfully.
  2. Confirm whether the DRM and MIPI drivers have loaded correctly by running the command:
root@ubuntu:~# dmesg | grep drm
[ 6.717478] systemd[1]: Starting Load Kernel Module drm...
[ 13.676055] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e080000.vs-sif (ops sif_component_ops [vs_drm])
[ 13.676374] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e000000.dc8000Nano (ops dc_component_ops [vs_drm])
[ 13.676514] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e010000.bt1120 (ops bt1120_component_ops [vs_drm])
[ 13.676553] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e000000.disp_apb:bt1120_bridge (ops bt1120_bridge_component_ops [vs_drm])
[ 13.676595] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e000000.disp_apb:bt1120_bridge_wb (ops bt1120_bridge_component_ops [vs_drm])
[ 13.676710] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e060000.mipi_dsi0 (ops dsi_component_ops [vs_drm])
[ 13.676834] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e000000.disp_apb:dsi-encoder (ops encoder_component_ops [vs_drm])
[ 13.676940] vs-drm 3e000000.disp_apb:display-subsystem: bound 3e000000.disp_apb:hdmi-encoder (ops encoder_component_ops [vs_drm])
[ 13.678810] [drm] Initialized vs-drm 1.0.0 20191101 for 3e000000.disp_apb:display-subsystem on minor 0
1.The message vs-drm 3e000000.disp_apb:display-subsystem: bound 3e060000.mipi_dsi0 (ops dsi_component_ops [vs_drm]) indicates that the MIPI DSI interface has been successfully loaded and initialized.
2.The message [drm] Initialized vs-drm 1.0.0 20191101 for 3e000000.disp_apb:display-subsystem on minor 0 indicates that the display driver has been successfully loaded.
3.To check the status of the connectors, run the following command:modetest -M vs-drm -c
root@ubuntu:~# modetest -M vs-drm -c
Connectors:
id encoder status name size (mm) modes encoders
73 72 connected DSI-1 800x480 1 72
modes:
index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot
#0 800x480 60.00 800 890 892 950 480 487 489 510 29070 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
flags: immutable range
values: 0 1
value: 0
4 TILE:
blobs:
value:
  1. Test with modetest command
Use the following command to stop the lightdm desktop:sudo systemctl stop lightdm
Then use the modetest command to perform the test:modetest -M vs-drm -a -s 73@31:800x480 -P 33@31:800x480@NV12
If everything is successful, the connected screen will light up and display the following pattern:
image-20220518111319607
5. Remarks​
Currently, the RDK X5 supports 7 models of Waveshare LCD screens. For usage instructions, refer to the Display Screen Usage section.
The drivers have been integrated into the kernel:
kernel/drivers/gpu/drm/panel/panel-wh-cm480.c
kernel/drivers/gpu/drm/panel/panel-waveshare-dsi.c
Device tree modifications are implemented through dtoverlay. For more details, refer to source/hobot-display.
You can also follow this approach to support additional LCD screens.
