PWM Driver Debugging Guide
The X5 has two types of controllers: one is the standard PWM, with 4 groups, each having 2 output channels, for a total of 8 PWM outputs. The other is LPWM, with 2 groups, each having 4 PWM outputs, primarily used for supporting synchronized exposure of sensors.
  • PWM supports a default frequency range of 0.05 Hz to 1 MHz.The duty-cycle register RATIO has 16-bit precision.The effective period range is 1 μs to 20 s, and the effective duty-cycle width is 10 ns to 20 s.
  • LPWM supports a default frequency range of 1 Hz to 1 MHz,with an output pulse-width range of 1 μs to 4 ms.
  • LPWM is designed for sensor synchronization and is not a general-purpose PWM. For pure PWM functionality, it is recommended to use PWM.
Driver Code​
Code Path​
The PWM driver code is located at:
drivers/pwm/pwm-hobot.c
Path of LPWM code
kernel/drivers/media/platform/horizon/camsys/lpwm/
Kernel Configuration​
/* arch/arm64/configs/hobot_x5_rdk_ubuntu_defconfig */
CONFIG_HOBOT_LPWM=m
CONFIG_PWM_DROBOT=y
DTS Node Configuration​
The device tree definitions for X5 PWM and LPWM controllers are located in the x5.dtsi file under the arch/arm64/boot/dts/hobot/ folder in the SDK package.
note
The nodes in x5.dtsi primarily declare SoC common features and are not related to a specific circuit board. In most cases, modifications are not required.
When you need to enable a specific PWM port output, you can modify the corresponding board-level file. Here, as an example, we enable lpwm1_0, lpwm1_1, pwm0_0, pwm0_1, pwm1_0, pwm1_1, pwm2_0, pwm2_1, pwm3_0, and pwm3_1 in the x5-rdk-v1p0.dts file.
&lpwm1 {
/** for display backlight **/
pinctrl-0 = <&pinctrl_lpwm1_0 &pinctrl_lpwm1_1>;
&pwm0 {
pinctrl-0 = <&pinctrl_pwm0_0 &pinctrl_pwm0_1>;
&pwm1 {
pinctrl-0 = <&pinctrl_pwm1_0 &pinctrl_pwm1_1>;
&pwm2 {
pinctrl-0 = <&pinctrl_pwm2_0 &pinctrl_pwm2_1>;
&pwm3 {
/* LSIO_PWM_OUT6 and LSIO_PWM_OUT7 */
pinctrl-0 = <&pinctrl_pwm3_0 &pinctrl_pwm3_1>;
PWM and PWMCHIP Correspondence in DTS​
Although both PWM and LPWM belong to pwmchip, the number of devices under PWM/LPWM is not consistent. Therefore, fixed numbering through aliases is not possible. When operating PWM on the board, you need to use the cat command to view the device/uevent under pwmchip to check if the PWM address matches the target PWM address.
For example, to check the pwmchip uevent for pwm0, use the following command on the board:
cat /sys/class/pwm/pwmchip0/device/uevent
DRIVER=drobot-pwm
OF_NAME=pwm
OF_FULLNAME=/soc/a55_apb0/pwm@34140000
OF_COMPATIBLE_0=d-robotics,pwm
OF_COMPATIBLE_N=1
MODALIAS=of:NpwmT(null)Cd-robotics,pwm
Correspondence Table of PWM in 40-Pin Header​
40-Pin Pin NumberPWM Pin NumberPWM Chip NumberPWM Number in srpi-configDevice Tree Label for the PinDefault Function of the Pin
Pin 29pwm0pwm0pwm0pinctrl_pwm0_0SPI2_SCLK
Pin 31pwm1pwm0pwm0pinctrl_pwm0_1SPI2_SSN
Pin 37pwm2pwm1pwm1pinctrl_pwm1_0SPI2_MISO
Pin 18pwm3pwm1pwm1pinctrl_pwm1_1SPI2_MOSI
Pin 28pwm4pwm2pwm2pinctrl_pwm2_0SCL0
Pin 27pwm5pwm2pwm2pinctrl_pwm2_1SDA0
Pin 32pwm6pwm3pwm3pinctrl_pwm3_0SCL1
Pin 33pwm7pwm3pwm3pinctrl_pwm3_1SDA1
Testing​
Users can refer to the following commands to test the PWM functionality and perform signal measurements to verify whether the PWM is working correctly. For specific hardware pins to be measured, users should refer to the documentation provided for the hardware they are using.
The following commands are provided as an example to verify PWM0 channel 0.
cd /sys/class/pwm/pwmchip0/
echo 0 > export
cd pwm0
# Configure Period to 100us
echo 100000 > period
# Configure Duty Cycle to 50% = 100us * 0.5 = 50us
echo 50000 > duty_cycle
# Enable PWM Output
echo 1 > enable
# The following is for reading register values
echo "Regs of PWM 3:"
echo "PWM_EN `devmem 0x34170000 32`"
echo "PWM_INT_CTRL `devmem 0x34170004 32`"
echo "PWM0_CTRL `devmem 0x34170008 32`"
echo "PWM0_CLK `devmem 0x34170010 32`"
echo "PWM0_PERIOD `devmem 0x34170020 32`"
echo "PWM0_STATUS `devmem 0x34170028 32`"
echo "PWM1_CTRL `devmem 0x34170030 32`"
echo "PWM1_CLK `devmem 0x34170034 32`"
echo "PWM1_PERIOD `devmem 0x34170040 32`"
echo "PWM1_STATUS `devmem 0x34170048 32`"
