7.1.3 RDK S600 Hardware Bringup
The S600 boardid is determined by the combined effect of ADC0, ADC1, ADC2, ADC4, ADC5, and ADC6. Among them, ADC0, ADC1, and ADC2 are used for D-Robotics hardware differentiation and cannot be modified by customers. ADC4 is used to differentiate the module baseboard, ADC5 is used to differentiate the baseboard version, and ADC4 and ADC5 can be modified by users. ADC6 is reserved and forced to be 0x1. For details on how to set the voltage divider resistors for the ADC, please contact the D-Robotics FAE team for support.
ADC0, ADC1, and ADC2 channels have a total of 8 levels, corresponding to 0x0-0x7. ADC4 and ADC5 channels have a total of 7 levels, corresponding to 0x0-0x6. The boardid of the S600 is a 28-bit unsigned integer, for example 0x5131310, where boardid[27:24] corresponds to ADC0, which is 0x5; boardid[23:20] corresponds to ADC1, which is 0x1; boardid[19:16] corresponds to ADC2, which is 0x3; boardid[15:12] corresponds to ADC4, which is 0x1; boardid[11:8] corresponds to ADC5, which is 0x3; boardid[7:4] corresponds to ADC6, which is 0x1; boardid[3:0] defaults to 0x0.
The boardid is formed by ADC sampling and implemented in the SBL. The corresponding code path is mcu/BootLoader/BoardId/src/Board_Id_Matrixp.c, function SBL_GetADC_To_AonSram.
Adding New Hardware Under MCU
What needs to be done on the MCU side is to implement your own Acore peripheral power-on method. If you are following D-Robotics' design, customers do not need to modify the MCU and can ignore this part.
Add Acore Power Management Code
Boot Stage
In the file mcu/BootLoader/Sys/src/Sys_InitSocEarly.c, within the function Sys_Lld_SetPmicGpio, add the PMIC EN PIN setting code.
void Sys_Lld_SetPmicGpio(void)
#if ((SOC_TYPE == SOC_TYPE_S600) || (SOC_TYPE == SOC_TYPE_S300))
uint32 boardid = 0U;
//coverity[misra_c_2012_rule_11_4_violation:SUPPRESS], ## violation reason SYSSW_V_11.4_01
//coverity[misra_c_2012_rule_18_4_violation:SUPPRESS], ## violation reason SYSSW_V_18.4_01
boardid = *((uint32 *)AON_SRAM_ADC);
LogSync("boardid 0x%x\r\n",boardid);
switch (boardid)
case 0x501FFF0U:
case 0x502FFF0U:
case 0x503FFF0U:
case 0x504FFF0U:
case 0x505FFF0U:
case 0x506FFF0U:
case 0x507FFF0U:
case 0x5111110U:
case 0x5121210U:
case 0x5131310U:
/*MAIN_DRAM_PRE_PWR_EN_M*/
Sys_Lld_SetBits32(0x23202000U, BIT_12);
Sys_Lld_SetBits32(0x23202004U, BIT_12);
break;
default:
LogSync("can't find boardid\r\n");
break;
#endif
If you are fully using D-Robotics' power logic, you can place your boardid under the boardid cases starting with 0x5 in the code. If it is a custom boardid, you need to create a new case branch.
Reboot/Suspend Scenarios
In the PMIC configuration of the D-Robotics S600 MD, located at mcu/Config/McalCdd/gen_s600_md/Pmic/src/Pmic_PBcfg.c, add the PIN information in PmicGpioConfig.
const Pmic_GpioConfigType PmicGpioConfig[PMIC_GPIO_INIT_CONFIG_NUM] = {
[PMIC_DEV_ID_0] = {
.Name = "VR5510",
.Type = PMIC_SUPPLY_FOR_MCU,
.GpioSite = 0U,
.LpGpioSite = 0U,
[PMIC_DEV_ID_1] = {
.Name = "MAIN_DRAM_PRE_PWR_EN_M",
.Type = PMIC_SUPPLY_FOR_MCUDEVICE,
.GpioSite = (PMIC_GPIO_TYPE_PINKEEP << PMIC_LLD_GPIO_CLASS_OFFSET) | PMIC_PINKEEP_GPIO_MAIN_DRAM_PRE_PWR_EN_M,
.GpioEnableLevel = 1U,
.GpioEnDelay = 15000U,
.GpioDisDelay = 0U,
If the user uses the PMIC configuration of the D-Robotics S600 MD, they need to modify it according to their own power solution.
Add Version Information
- In
mcu/Service/Board/BoardInfo/inc/McuVersion.h, add boardid information.
#elif ((SOC_TYPE == SOC_TYPE_S600) || (SOC_TYPE == SOC_TYPE_S300))
#define RDK_S600_V1_0 0x5131310
#define RDK_S600_V1_0_NAME "Matrix_V2.0"
#endif
RDK_S600_V1_0is defined as the new boardid.RDK_S600_V1_0_NAMEis defined as the new hardware name.
- In
mcu/Service/Board/BoardInfo/src/Hobot_Board_Info.c, add boardinfo.
static Hobot_BoardInfo_t g_BoardInfo[BOARD_TYPE_NUM] = {
/* RDK S600 V1.0 */
{0x5131310, "S600", "RDK", "", "V1.0"},
0x5131310is the new boardid.S600is defined as the chip name.RDKis defined as the hardware name.V1.0is defined as the hardware version.
- In
mcu/Service/Board/BoardInfo/src/McuVersion.c, add version comparison.
static int BoardId_Check(uint32 BoardId)
switch(BoardId)
case RDK_S600_V1_0:
result = Compare_board_id(RDK_S600_V1_0_NAME);
break;
#endif
Disable SLEEP KEY Handling
In the RDK S600 design, there is a SLEEP KEY whose functions are to put the device to sleep via key press and to enter the uboot fastboot state via key press during startup. The PIN used for the SLEEP KEY is AON GPIO 8. The other functions of this PIN are SPI8_CSN1 or CAN11_RX. If you are using any of these functions, you need to make the following modifications in the RDK SDK code to ensure normal startup.
In the MCU0 code, the interrupt status of AON GPIO 8 is checked to decide whether to enter sleep mode. The interrupt is registered in the ICU module, so you need to disable the interrupt for AON GPIO 8 in the ICU module.
In the Icu_Gpio_ChannelConfig_PB array in the MCU code file mcu/Config/McalCdd/gen_s600_md/Icu/src/Icu_PBCfg.c, make the following settings:
/** @brief gpio mod 4 channel 8 */
.PinId = 8,
.instanceNo = 4,
.DefaultStartEdge = GPIO_ICU_FALLING_EDGE,
.NotificationEnable = FALSE,
.GpioChannelNotification = Icu_Gpio_Channel_4_8_ISR,
.IntEnable = FALSE,
.IntMask = TRUE,
- Change
NotificationEnabletoFALSE. - Change
IntEnabletoFALSE. - Change
IntMasktoTRUE.
Adding New Hardware Under SPL and Uboot
The SPL is the SPL under Uboot.
Add Configuration File
The Uboot configuration file is located in the SDK directory source/bootloader/uboot/configs, with the corresponding configuration file hobot_s600_defconfig.
The Uboot configuration file is specified in the bootloader board-level configuration file. For the debug configuration file, the path is source/bootloader/device/rdk/s600/board_s600_debug.mk, with the variable HR_UBOOT_CONFIG_FILE specifying the Uboot configuration file.
# hobot_s600_defconfig
export HR_UBOOT_CONFIG_FILE=hobot_s600_defconfig
export HR_UBOOT_OTA_CONFIG_FILE=hobot_s600_ota.config
export HR_ARCH_UBOOT="arm"
If customers need to generate their own Uboot config file, they can replace it as described above. Generally, reusing D-Robotics' configuration is sufficient.
Add Device Tree
The Uboot device tree file is located in the SDK directory source/bootloader/uboot/arch/arm/dts/drobot-s600-rdk.dts. The device tree is specified by the variable CONFIG_DEFAULT_DEVICE_TREE in the configuration file.
CONFIG_DEFAULT_DEVICE_TREE="drobot-s600-rdk"
If customers need to add their own device tree file, note that they must #include "hobot-s600-soc.dtsi" in their device tree file, then override settings later, and finally replace as described above. Generally, reusing D-Robotics' configuration is sufficient. When adding your own device tree file, remember to include it in the Makefile for compilation.
Add Board ID
In the Uboot dts file source/bootloader/uboot/arch/arm/dts/hobot-s600-boardcfg.dtsi, under board_cfg, add board-level configuration information.
board_cfg {
s600_rdk_1_0 {
u-boot,dm-spl;
boardid = <0x5131310>;
soc_name = "S600";
hw_name = "rdk";
version = "V1P0";
pcie_mode = "rc";
fdt_feat = "drobot-s600-rdk";
pxe_label = "drobot-s600-rdk-v1p0-kernel";
bootsrc = "strappin";
u-boot,dm-spl: Indicates that this dts configuration will be used in the SPL stage and must be added.boardid: Represents the new boardid to be added by the customer.soc_name: Represents the chip name.hw_name: Hardware name.version: Hardware version.pcie_mode: PCIe mode, defaults to rc.fdt_feat: The name of the dtb used by Uboot and SPL.pxe_label: Kernel configuration in extlinux.bootsrc: Indicates selecting the boot medium based on strap pin.
In the uboot code source/bootloader/uboot/arch/arm/mach-hobot/super/s600_boot_info.c, for the function hb_get_fb_key_status, force it to return 1.
static uint32_t hb_get_fb_key_status(void)
return 1;
Adding New Hardware Under Kernel
The Kernel configuration file is located in the SDK directory source/hobot-drivers/configs. The configuration file corresponding to the S600 is drobot_s600_defconfig.
The Kernel configuration file is specified in mk_kernel.sh.
# mk_kernel.sh
export KERNEL_DEFCONFIG=drobot_s600_defconfig
If customers need to generate their own Kernel config file, they can replace it as described above. Generally, reusing D-Robotics' configuration is sufficient.
Add Device Tree
The Kernel device tree file is located in the SDK directory source/hobot-drivers/kernel-dts.
If customers need to add their own device tree file, note that they must #include "rdk-s600-mcb.dtsi" in their device tree file, then override settings later. Generally, reusing D-Robotics' configuration is sufficient. When adding your own device tree file, remember to include it in the Makefile for compilation.
Extlinux Configuration
In the S600, Uboot parses the Kernel configuration based on extlinux and selects the corresponding dtb, Kernel image, and initramfs to load.
The extlinux file is located at source/kernel/scripts/package/rdk_extlinux.
Take the RDK-S600-V1P0 version as an example:
label drobot-s600-rdk-v1p0-kernel
lantin /lantinhv
domu /vmlinuz-KERNEL_VERSION
domufdt /hobot/rdk-s600-mcb-v1p0.dtb
domuinitrd /initrd.img-KERNEL_VERSION
The label must correspond to the pxe_label in source/bootloader/uboot/arch/arm/dts/hobot-s600-boardcfg.dtsi.
The domufdt file rdk-s600-mcb-v1p0.dtb must be consistent with the Kernel device tree naming to be used.
Loading ko Based on boardid
In the file source/hobot-utils/debian/usr/bin/hobot-loadko.sh, you need to decide whether to load the PCIe driver based on the boardid.
boardid_sys_path="/sys/class/boardinfo/adc_boardid"
if [ -f "$boardid_sys_path" ]; then
boardid="$(cat $boardid_sys_path)"
if [[ "$boardid" =~ ^0x(64|65|6A|6B)[0678][04567]$ ]];then # S100
case ${boardid} in
*"0")
# Check if TPIC2810 exists, if so, manual reset USB controller
if [ -f /sys/class/i2c-adapter/i2c-2/2-0060/name ] &&
[ "$(cat /sys/class/i2c-adapter/i2c-2/2-0060/name)" = "tpic2810" ];then
/usr/bin/pcie-usb-reset.sh
fi
/usr/bin/start-pcie.sh &
*"7") ;&
*"6") ;&
*"5") ;&
*"4")
modprobe hobot-pcie-rc
# check & update asm3042 firmware
/usr/bin/update-asm3042-firmware.sh
esac
elif [[ "$boardid" =~ ^0x(51)[1234567][01234567][1234567][1234567].$ ]];then # S600
# S600 Boardid rules
else
echo "<$LOG_WARN>Unsupported boardid:$boardid, PCIE not Initialized!" > /dev/kmsg
fi
fi
Configuring Ion Based on boardid
In the file source/hobot-utils/debian/usr/hobot/bin/hb_switch_ion.sh, you need to select the ion configuration based on the boardid.
function get_dtb()
# get chip
if [[ "$boardid" =~ ^0x(51)[1234567][01234567][1234567][1234567].$ ]]; then
# S600
if [[ "$boardid" == "0x5111110" ]]; then
echo "rdk-s600-mcb-v0p1.dtb"
elif [[ "$boardid" == "0x5121210" ]]; then
echo "rdk-s600-mcb-v0p2.dtb"
elif [[ "$boardid" == "0x5131310" ]]; then
echo "rdk-s600-mcb-v1p0.dtb"
else
echo "Invalid"
fi
else
On-Board Debugging
When debugging on the board, it is recommended to use the debug image. The release image disables most logs, making it difficult to locate issues when problems occur.
Method to compile the debug image:
In the script pack_image.sh, the default configuration selects the beta configuration.
Check if the Startup Information Meets Expectations
- The SBL log will print the ADC level values.
[00.022777 0]Adc:0:2481:0x5
[00.023121 0]Adc:1:586:0x1
[00.023453 0]Adc:2:1521:0x3
[00.023797 0]Adc:3:110:0x0
[00.024130 0]Adc:4:590:0x1
[00.024463 0]Adc:5:1517:0x3
[00.024805 0]Adc:6:584:0x1
[00.025138 0]Adc:7:1566:0x3
[00.025471 0]boardid :0x5131310
- The SPL log will print the ADC level values.
U-Boot SPL 2022.04-00885-ge6f5dae98d (May 28 2026 - 16:43:04 +0800)
hb_fetch_boardinfo targetid[0x5131310]
- The Uboot log will print the Model, which can be used to determine if it matches the definition in the Uboot dts.
U-Boot 2022.04-00885-ge6f5dae98d (May 28 2026 - 16:43:04 +0800)
Model: D-Robotics S600 Module Board
- The Uboot log will print the boardid, for example, 5131310 below.
system_slot: 0 adc_boardinfo: 5131310
- The Uboot log will print the label corresponding to extlinux, as well as the Kernel image, dtb, and initramfs.
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
15: drobot-s600-rdk-v1p0-kernel
Retrieving file: /lantinhv
Retrieving file: /vmlinuz-6.1.158-rt58-DR-5.1.0-2605281643-g37fae2-g1133e0
Uncompressing Kernel Image
Retrieving file: /initrd.img-6.1.158-rt58-DR-5.1.0-2605281643-g37fae2-g1133e0
Retrieving file: /hobot/rdk-s600-mcb-v1p0.dtb
- Check the board info in bootargs.
Mainly check hobotboot.socname=S600, board.hwname=rdk, board.ver=V1P0, board.pcie_mode=rc, etc., to see if they match the definitions in Uboot.
root@ubuntu:~# cat /proc/cmdline
console=ttyS0,921600n8 systemd.show-status=auto loglevel=1 hobot.kernel_in=scsi0 hobotboot.socname=S600 board.hwname=rdk board.ver=V1P0 board.pcie_mode=rc hobotboot.slot_suffix=_a hobotboot.mode=normal hobotboot.secureboot=1 hobotboot.bootcount=1 systemd.unified_cgroup_hierarchy=0 hobotboot.serial=8e09458433902940 clk_ignore_unused earlycon=uart8250,mmio32,0x3484C000 no_console_suspend root=/dev/ram0 rdinit=/init rootwait net.ifnames=0 root=/dev/disk/by-partuuid/7060c50b-9cc5-834a-994c-89e3df6e42c9 rw rootfstype=ext4 rootwait
- View board info in the Kernel command line.
root@ubuntu:~# cd /sys/class/boardinfo/
root@ubuntu:/sys/class/boardinfo# ls
adc_boardid board_name bootdevice_name chip_id ddr_size ddr_type hw_name hw_version pcie_mode pg_map soc_gen soc_name soc_uid
root@ubuntu:/sys/class/boardinfo# cat *
0x5131310
S600_rdk_V1P0
scsi0
22881793
0x7fff
LPDDR5
rdk
V1P0
rc
0x8000000
super
S600
8e09458433902940750b6e1900000786
