7.3.7. QAT Experience Summary¶
7.3.7.1. Hyperparameter¶
Except the hyper-parameters in the following table, other parameters are recommended to be consistent in the QAT stage with the floating point stage.
Hyperparameter |
Recommended configuration |
Advanced configuration (try if the recommended configuration doesn’t work) |
Remark |
LR |
Starting from 0.001, do 2 lr decay with scale=0.1 with StepLR |
1. Adjust lr between 0.0001->0.001, with lr decay of 1-2; |
Epoch |
10% of floating point epochs |
According to the convergence of loss and metric, consider whether it is necessary to extend the epoch appropriately. |
Weight decay |
consistent with floating point |
It is recommended to make appropriate adjustments around 4e-5. If the weight decay is too small, |
optimizer |
When qat accuracy is low, it is recommended to try SGD |
transforms (data augmentation) |
The QAT stage can be appropriately weakened. For example, the color conversion of classification can be removed, |
Reduced data augmentation may also benefit floating point models |
7.3.7.2. Quantization Parameters¶
The adjustable parameters of the QAT stage are shown below:
Quantization related parameters |
network output layer |
use high precision output |
averaging_constant(qconfig_params) |
1. When calibration is not used, use the default value; |
1. When there is a large gap between calibration accuracy and floating point, do not set activation averaging_constant to 0.0; |
ReLU |
When the featuremap value is huge, try to use ReLU with an upper bound, such as ReLU6, ReLU8, etc. |
