7.3.5. FX Based Quantization¶
FX is a mechanism for torch to process computational graphs. Due to the existence of computational graphs, FX based quantization has the following advantages over eagle mode :
Automatic matching of
fuse patterncan be realized, and users no longer need to manually execute thefuseprocess.It provides possibility for other optimization based on calculation chart.
On the whole, the process of FX quantification is highly consistent with the eagle mode . Generally, you only need to replace the interface:
prepare_calibration->prepare_calibration_fxprepare_qat->prepare_qat_fxconvert->convert_fx
Among them, prepare_calibration_fx and prepare_qat_fx interfaces are integrated with automatic fuse processes. In addition, we also provide a separate fuse_fx interface for debugging or research.
7.3.5.1. Restriction¶
FX uses symbolic execution to record operations in the model. This method has many limitations. See the relevant sections of the official document for details limitations-of-symbolic-tracing.
If operations not supported by FX, such as control flow, are used in the user model, they can be wrapped as a function or method as a whole by wrapping. FX will no longer pay attention to their internal logic, but will retain their calls as they are.
We have extended torch.fx.wrap to support more packaging forms. For details, see the interface document of fx.fx_helper.wrap .
The following example illustrates the use of wrap :
[3]:
from torch import nn
from torch.nn import functional as F
from horizon_plugin_pytorch.quantization.quantize_fx import QuantizationTracer
from horizon_plugin_pytorch.quantization.fx.graph_module import GraphModuleWithAttr
class FxWrapExampleNet(nn.Module):
def __init__(self):
super(FxWrapExampleNet, self).__init__()
self.quant = QuantStub()
self.conv = nn.Conv2d(3, 3, 1)
self.bn = nn.BatchNorm2d(3)
self.relu = nn.ReLU()
self.dequant = DeQuantStub()
def forward(self, input):
# The main body of the model needs to be fused, quantified, etc
x = self.quant(input)
x = self.conv(x)
x = self.bn(x)
x = self.relu(x)
x = self.dequant(x)
# Post processing, without quantification, and including conditional branches
if self.training:
print("Run softmax")
return F.softmax(x, dim=1)
else:
print("Run argmax")
return torch.argmax(x, dim=1)
model = FxWrapExampleNet()
tracer = QuantizationTracer([], [])
graph = tracer.trace(model)
graph.print_tabular()
graph_model = GraphModuleWithAttr(model, graph)
print(graph_model.code)
data = torch.rand(1, 3, 64, 64)
ret = graph_model(data)
Run softmax
opcode name target args kwargs
placeholder input_1 input () {}
call_module conv conv (input_1,) {}
call_module bn bn (conv,) {}
call_module relu relu (bn,) {}
call_function softmax <function softmax at 0x7f0ac35be040> (relu,) {'dim': 1, '_stacklevel': 3, 'dtype': None}
output output output (softmax,) {}
input_1 = input
conv = self.conv(input_1); input_1 = None
bn = self.bn(conv); conv = None
relu = self.relu(bn); bn = None
softmax = torch.nn.functional.softmax(relu, dim = 1, _stacklevel = 3, dtype = None); relu = None
return softmax
As you can see, the post-processing torch.argmax and print statements in the model after trace have been discarded. If you need to keep the post-processing as it is, you can wrap it.
[4]:
from horizon_plugin_pytorch.fx.fx_helper import wrap as fx_wrap
def __init__(self):
# Wrap post-processing as a method
@fx_wrap
def _post_process(self, model_output):
if self.training:
return F.softmax(model_output, dim=1)
else:
print("Run argmax")
return torch.argmax(model_output, dim=1)
x = self.conv(x)
x = self.bn(x)
x = self.relu(x)
x = self.dequant(x)
return self._post_process(x)
ret = graph_model.eval()(data)
get_attr _self _self () {}
call_method _post_process _post_process (_self, relu) {}
output output output (_post_process,) {}
input_1 = input
_self = self._self
_post_process = _self._post_process(relu); _self = relu = None
return _post_process
Run softmax
Run argmax
It can be seen that the packaged post-processing is called as a whole in the model after trace , the internal logic will be retained as it is, and the print statement can also print the content normally.
