6.2.3. The hb_perf Tool¶
The hb_perf tool is used to analyze the performance of the quantized heterogeneous models.
6.2.3.1. How to Use¶
hb_perf [OPTIONS] BIN_FILE
6.2.3.2. Parameters¶
- Parameters:
- -h, --help
- --version
- -m
Followed by the model name. Specify the desired model when BIN_FILE is a pack model for dumping model compilation information for this specified model.
6.2.3.3. Output Contents¶
Model information will be generated to the hb_perf_result folder in current directory and saved in the html and json files using the model name, as follows:
hb_perf_result/
└── mobilenetv1
├── mobilenetv1
├── mobilenetv1.html
├── MOBILENET_subgraph_0.html
├── MOBILENET_subgraph_0.json
└── temp.hbm
