sample_pipeline Usage Guide
Function Overview​
sample_pipeline is used to implement single or multi-sensor pipeline concatenation, covering common user pipeline scenarios. Users can learn how to build various pipelines by exploring the subdirectories under sample_pipeline.
sample_pipeline Architecture Description​
sample_pipeline contains multiple examples, each residing as a subdirectory under app/multimedia_samples/sample_pipeline. Each subdirectory is described below:
DirectoryDescription
single_pipe_vin_isp_ynr_pym_vpuExample of a simple single-sensor pipeline concatenated with encoding
single_pipe_vin_isp_ynr_pym_gdcExample of a single-sensor pipeline concatenated with GDC transformation
single_pipe_vin_isp_ynr_pym_gdc_vpuExample of a single-sensor pipeline concatenated with GDC transformation and encoding
multi_pipe_vin_isp_ynr_pym_gdc_vpuExample of a multi-sensor pipeline concatenated with encoding
uvc_capture_sampleUVC camera capture example
single_3dgpu_bpuExample of GPU concatenated with BPU via zero-copy memory
single_pipe_vin_isp_ynr_pym_vpu​
Function Overview​
The single_pipe_vin_isp_ynr_pym_vpu example concatenates the VIN, ISP, PYM, and CODEC modules, representing one of the most fundamental module concatenation examples. The image from the Camera Sensor passes through VIN and ISP processing before reaching the PYM module. The PYM module is configured with six output channels as follows:
  • Channel 0 outputs the full-resolution image processed by ISP and YNR. The output data from this channel is then fed into an encoder and saved as an H264 video stream.
  • Channel 1 outputs an NV12-formatted image scaled down by a factor of 2 in both width and height, aligned to 16 pixels.
  • Channel 2 outputs an NV12-formatted image scaled down by a factor of 4 in both width and height, aligned to 16 pixels.
  • Channel 3 outputs an NV12-formatted image scaled down by a factor of 8 in both width and height, aligned to 16 pixels.
  • Channel 4 outputs an NV12-formatted image scaled down by a factor of 16 in both width and height, aligned to 16 pixels.
  • Channel 5 outputs an NV12-formatted image scaled down by a factor of 32 in both width and height, aligned to 16 pixels.
Note: The minimum resolution supported by PYM output is 32. If either the scaled width or height is smaller than 32, the image will not be saved.
Code Location and Directory Structure​
  • Code location: /app/multimedia_samples/sample_pipeline/single_pipe_vin_isp_ynr_pym_vpu
  • Directory structure:
└── single_pipe_vin_isp_ynr_pym_vpu.c
Compilation​
  • Enter the single_pipe_vin_isp_ynr_pym_vpu directory and run make to compile.
  • The compiled binary is named single_pipe_vin_isp_ynr_pym_vpu and located in the source directory.
Execution​
How to Run the Program​
Directly executing ./single_pipe_vin_isp_ynr_pym_vpu displays help information:
# ./single_pipe_vin_isp_ynr_pym_vpu
No sensors specified.
Usage: single_pipe_vin_isp_ynr_pym_vpu [OPTIONS]
-l <link_port> Specify the port for connecting serdes sensors, 0:A 1:B 2:C 3:D
-h Show this help message
index: 0 sensor_name: imx219-30fps config_file:linear_1920x1080_raw10_30fps_1lane.c
index: 1 sensor_name: sc1336_gmsl-30fps config_file:linear_1280x720_raw10_30fps_2lane.c
index: 2 sensor_name: ar0820std-30fps config_file:linear_3840x2160_30fps_1lane.c
index: 3 sensor_name: ar0820std-1080p30 config_file:linear_1920x1080_yuv_30fps_1lane.c
Program Option Descriptions​
  • -s: Specifies the Camera Sensor model and configuration.
  • -l: Specifies the Link Port for Serdes-type sensors (e.g., Port A corresponds to -l 0).
Runtime Behavior​
The single_pipe_vin_isp_ynr_pym_vpu program produces the following outputs:
  1. Saves an NV12 image from each PYM output channel to the current working directory every 60 frames.
  2. Feeds the output from PYM channel 0 into an encoder and saves the encoded stream to a file.
Example: Using imx219 as the sensor input, execute ./single_pipe_vin_isp_ynr_pym_vpu -s 0.
Sample log output:
# ./single_pipe_vin_isp_ynr_pym_vpu -s 0
Using index:0 sensor_name:imx219-30fps config_file:linear_1920x1080_raw10_30fps_1lane.c
mipi mclk is not configed.
mipi rx used phy: 00000000
Searching camera sensor on device: /proc/device-tree/soc/vcon@1 i2c bus: 2 mipi rx phy: 1
INFO: Found sensor_name:imx219-30fps on mipi rx csi 1, i2c addr 0x10, config_file:linear_1920x1080_raw10_30fps_1lane.c
[0] use [isp + ynr].
vin [hw:1]
isp [hw:1] [slot_id:0] [mode:1]
ynr [hw:1] [slot_id:0] [mode:1]
pym [hw:1] [slot_id:0] [mode:1]
vin ->online-> isp ->online-> ynr ->online-> pym
INFO: ISP channel info:
input info: [mipi_rx: 1] [is_online: 1]
isp channel info: [hw_id: 1] [slot_id: 0] [mode:1]
pym config:
ichn input width = 1920, height = 1080
ochn[0] ratio= 1, width = 1920, height = 1080 wstride=1920 vstride=1080 out[1920*1080]
ochn[1] ratio= 2, width = 960, height = 540 wstride=960 vstride=540 out[960*540]
ochn[2] ratio= 4, width = 480, height = 270 wstride=480 vstride=270 out[480*270]
ochn[3] ratio= 8, width = 240, height = 134 wstride=240 vstride=134 out[240*134]
ochn[4] ratio= 16, width = 120, height = 66 wstride=128 vstride=66 out[120*66]
ochn[5] ratio= 32, width = 60, height = 32 wstride=64 vstride=32 out[60*32]
####################### pym chn 0 #######################
=== Frame Info ===
Frame ID: 1
Timestamps: 1960130089350
tv: 1746703610.867799
trig_tv: 1746703610.867799
Frame Done: 8
Buffer Index: 0
=== Graphic Buffer ===
File Descriptors: 26 -1 -1
Plane Count: 2
Format: 8
Width: 1920
Height: 1080
Stride: 1920
Vertical Stride: 1080
Is Contiguous: 1
Share IDs: 181 0 0
Flags: 67108881
Sizes: 2073600 1036800 0
Virtual Addresses: 0xffff849f0000 0xffff84bea400 (nil)
Physical Addresses: 17296588800 17298662400 0
Offsets: 0 0 0
####################### pym chn 1 #######################
=== Frame Info ===
Frame ID: 1
Frame Done: 8
Buffer Index: 0
File Descriptors: 27 -1 -1
Plane Count: 2
Format: 8
Width: 960
Height: 540
Stride: 960
Vertical Stride: 540
Is Contiguous: 1
Share IDs: 182 0 0
Flags: 67108881
Sizes: 518400 259200 0
Virtual Addresses: 0xffff84930000 0xffff849ae900 (nil)
Physical Addresses: 17299734528 17300252928 0
Offsets: 0 0 0
####################### pym chn 2 #######################
=== Frame Info ===
Frame ID: 1
Frame Done: 8
Buffer Index: 0
File Descriptors: 28 -1 -1
Plane Count: 2
Format: 8
Width: 480
Height: 270
Stride: 480
Vertical Stride: 270
Is Contiguous: 1
Share IDs: 183 0 0
Flags: 67108881
Sizes: 129600 64800 0
Virtual Addresses: 0xffff84900000 0xffff8491fa40 (nil)
Physical Addresses: 17300520960 17300650560 0
Offsets: 0 0 0
####################### pym chn 3 #######################
=== Frame Info ===
Frame ID: 1
Frame Done: 8
Buffer Index: 0
File Descriptors: 29 -1 -1
Plane Count: 2
Format: 8
Width: 240
Height: 134
Stride: 240
Vertical Stride: 134
Is Contiguous: 1
Share IDs: 184 0 0
Flags: 67108881
```Sizes: 32160 16080 0
Virtual Addresses: 0xffff848f0000 0xffff848f7da0 (nil)
Physical Addresses: 17300717568 17300749728 0
Offsets: 0 0 0
####################### pym chn 4 #######################
=== Frame Info ===
Frame ID: 1
Frame Done: 8
Buffer Index: 0
File Descriptors: 30 -1 -1
Plane Count: 2
Format: 8
Width: 120
Height: 66
Stride: 128
Vertical Stride: 66
Is Contiguous: 1
Share IDs: 185 0 0
Flags: 67108881
Sizes: 8448 4224 0
Virtual Addresses: 0xffff848e0000 0xffff848e2100 (nil)
Physical Addresses: 17300783104 17300791552 0
Offsets: 0 0 0
####################### pym chn 5 #######################
=== Frame Info ===
Frame ID: 1
Frame Done: 8
Buffer Index: 0
File Descriptors: 31 -1 -1
Plane Count: 2
Format: 8
Width: 60
Height: 32
Stride: 64
Vertical Stride: 32
Is Contiguous: 1
Share IDs: 186 0 0
Flags: 67108881
Sizes: 2048 1024 0
Virtual Addresses: 0xffff848d0000 0xffff848d0800 (nil)
Physical Addresses: 17300848640 17300850688 0
Offsets: 0 0 0
The following files will be saved at runtime:
single_pipe_vin_isp_ynr_pym_vpu.h264
pym_output_nv12_chn0_1920x1080_stride_1920_count_0.yuv
pym_output_nv12_chn1_960x540_stride_960_count_0.yuv
pym_output_nv12_chn2_480x270_stride_480_count_0.yuv
pym_output_nv12_chn3_240x134_stride_240_count_0.yuv
pym_output_nv12_chn4_120x66_stride_128_count_0.yuv
pym_output_nv12_chn5_60x32_stride_64_count_0.yuv
single_pipe_vin_isp_ynr_pym_gdc​
Function Overview​
The single_pipe_vin_isp_ynr_pym_gdc sample demonstrates a basic pipeline that chains together the VIN, ISP, PYM, and GDC modules. The image from the camera sensor passes through the VIN, ISP, and PYM modules before reaching the GDC module, which applies geometric distortion correction based on a GDC bin file to generate YUV images.
  • Code location: /app/multimedia_samples/sample_pipeline/single_pipe_vin_isp_ynr_pym_gdc
└── single_pipe_vin_isp_ynr_pym_gdc.c
Compilation​
  • Enter the single_pipe_vin_isp_ynr_pym_gdc directory and run make to compile.
  • The output binary will be single_pipe_vin_isp_ynr_pym_gdc in the source directory.
Execution​
Running the program directly (./single_pipe_vin_isp_ynr_pym_gdc) displays help information:
# ./single_pipe_vin_isp_ynr_pym_gdc
Usage: single_pipe_vin_isp_pym_vpu [OPTIONS]
-f <gdc_bin_file> Specify sensor gdc_bin_file path
index: 4 sensor_name: ovx3cstd-30fps config_file:linear_1920x1280_yuv_30fps_1lane.c
  • -s: Specifies the camera sensor model and configuration.
  • -l: Specifies the link port for SerDes-type sensors (e.g., Port A corresponds to -l 0).
Note
The link port value must match the physical port on the deserializer to which the SerDes sensor is connected. Ensure the sensor is connected to the specified port.
Runtime Behavior​
The single_pipe_vin_isp_ynr_pym_gdc program outputs the following:
  1. Saves one NV12 image from each GDC output channel to the current working directory every 30 frames.
Example: Using imx219 as the sensor input, run:
./single_pipe_vin_isp_ynr_pym_gdc -s 0 -f ../../vp_sensors/gdc_bin/imx219_gdc.bin
Sample log output:
# ./single_pipe_vin_isp_ynr_pym_gdc -s 0 -f ../../vp_sensors/gdc_bin/imx219_gdc.bin
vin [hw:1]
pym config:
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 1, timestamp: 21677343453900
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 31, timestamp: 21678330776125
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 61, timestamp: 21679318103925
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 91, timestamp: 21680305428000
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 121, timestamp: 21681292757750
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_121_ts_21681292757750.yuv
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_1_ts_21677343453900.yuv
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_31_ts_21678330776125.yuv
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_61_ts_21679318103925.yuv
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_91_ts_21680305428000.yuv
single_pipe_vin_isp_ynr_pym_gdc_vpu​
Function Overview​
The single_pipe_vin_isp_ynr_pym_gdc_vpu sample demonstrates a basic pipeline chaining the VIN, ISP, YNR, PYM, GDC, and CODEC modules. The camera sensor image flows through VIN, ISP, YNR, and PYM modules, then reaches the GDC module. GDC applies geometric distortion correction using a GDC bin file to produce YUV images, which are then passed to the encoder and saved as an H.264 video bitstream.
  • Code location: /app/multimedia_samples/sample_pipeline/single_pipe_vin_isp_ynr_pym_gdc_vpu
└── single_pipe_vin_isp_ynr_pym_gdc_vpu.c
Compilation​
  • Enter the single_pipe_vin_isp_ynr_pym_gdc_vpu directory and run make to compile.
  • The output binary will be single_pipe_vin_isp_ynr_pym_gdc_vpu in the source directory.
Execution​
Running the program directly (./single_pipe_vin_isp_ynr_pym_gdc_vpu) displays help information:
# ./single_pipe_vin_isp_ynr_pym_gdc_vpu
```Usage: single_pipe_vin_isp_pym_vpu [OPTIONS]
Program Parameter Options Description​
  • -s: Specify the Camera Sensor model and configuration.
  • -l: Specify the Link Port for Serdes-type sensors. For example, if connected to Port A, specify as 0: -l 0.
Note
The value for the link setting depends on the port to which the Serdes sensor is connected on the deserializer. Please ensure the Serdes sensor is connected to the specified port.
Execution Results​
The output of single_pipe_vin_isp_ynr_pym_gdc_vpu is as follows:
  2. Sends the GDC channel output images to the encoder for encoding and saves the encoded data to files.
Example: Using imx219 as the sensor input, execute:
./single_pipe_vin_isp_ynr_pym_gdc_vpu -s 0 -f ../../vp_sensors/gdc_bin/imx219_gdc.bin
Sample log output:
# ./single_pipe_vin_isp_ynr_pym_gdc_vpu -s 0 -f ../../vp_sensors/gdc_bin/imx219_gdc.bin
vin [hw:1]
pym config:
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 1, timestamp: 21970340530375
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 31, timestamp: 21971327856500
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 61, timestamp: 21972315184900
gdc(296805) dump yuv 1920x1080(stride:1920), buffer size: 2073600 + 1036800 frame id: 91, timestamp: 21973302504675
The following files will be saved during execution:
single_pipe_vin_isp_ynr_pym_gdc_vpu.h264
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_1_ts_21970340530375.yuv
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_31_ts_21971327856500.yuv
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_61_ts_21972315184900.yuv
gdc_handle_296805_chn0_1920x1080_stride_1920_frameid_91_ts_21973302504675.yuv
multi_pipe_vin_isp_ynr_pym_gdc_vpu​
Function Overview​
multi_pipe_vin_isp_ynr_pym_gdc_vpu supports simultaneous input from multiple sensors and processes video streams through multiple processing modules such as VIN, ISP, PYM, GDC, and CODEC.
Notes:
  1. The GDC module requires a bin file as input. This sample program searches for bin files in the directory /app/multimedia_samples/vp_sensors/gdc_bin. The GDC module runs only if a suitable bin file is found.
  2. The CODEC module requires a minimum input resolution of 256 (width) × 128 (height). If the output resolution of the selected PYM channel is smaller than this minimum, the program will exit immediately.
  • Code location: /app/multimedia_samples/sample_pipeline/multi_pipe_vin_isp_ynr_pym_gdc_vpu
└── multi_pipe_vin_isp_ynr_pym_gdc_vpu.c
Compilation​
  • Enter the multi_pipe_vin_isp_ynr_pym_gdc_vpu directory and run make to compile.
  • The output binary is multi_pipe_vin_isp_ynr_pym_gdc_vpu, located in the source directory.
Execution​
Execute ./multi_pipe_vin_isp_ynr_pym_gdc_vpu directly to display help information:
# ./multi_pipe_vin_isp_ynr_pym_gdc_vpu
Usage: multi_pipe_vin_isp_ynr_pym_gdc_vpu [Options]
-c, --config="sensor=id link=port channel=pym_chn type=TYPE output=FILE, 'channel' and 'type' and 'output' is not mandatory"
Configure parameters for each video pipeline, can be repeated up to 6 times
sensor -- Sensor index, can have multiple parameters, reference sensor list.
link -- Specify the port for connecting serdes sensors, 0:A 1:B 2:C 3:D, can be set to [0-3].
channel -- Pym channel index bind to encode, default 0, can be set to [0-5].
type -- Encode type, default is h264, can be set to [h264, h265].
output -- Save codec stream data to file, default is 'pipeline[xx]_[width]x[height]_[xxx]fps.[type]'.
-v, --verbose Enable verbose mode
-h, --help Show help message
Support sensor list:
  • -c, --config="sensor=id channel=vse_chn type=TYPE output=FILE"
    • Configures parameters for each video pipeline. This option can be repeated multiple times (up to 6).
    • sensor is mandatory; channel, type, and output are optional. If not specified, the program uses default values.
    • sensor: Sensor index (mandatory). Multiple parameters are allowed; refer to the sensor list.
    • link: Link Port for Serdes-type sensors (ignored for MIPI-type sensors). For example, if connected to Port A, specify as 0: -l 0.
    • channel: VSE channel index (optional, default: 0, range: [0–5]).
    • type: Encoding type (optional, default: h264, options: [h264, h265]).
    • output: Filename for saving encoded stream data (optional, default: pipeline[xx]_[width]x[height]_[xxx]fps.[type]).
  • -v, --verbose
    • Enables verbose mode.
  • -h, --help
    • Displays help information.
Notes:
  1. Serdes-type sensors must specify a Link Port.
  2. To adjust the number of video pipelines, simply add or remove -c parameter sets.
Execution Results​
The output of multi_pipe_vin_isp_ynr_pym_gdc_vpu: Each video processing pipeline encodes the processed video stream into H.264/H.265 format and saves it to a file.
Example:
  1. Use imx219 (MIPI-type) and sc1336 (Serdes-type) as sensor inputs.
  2. Execute the command:
    ./multi_pipe_vin_isp_ynr_pym_gdc_vpu -c "sensor=0" -c "sensor=1 link=0"
Sample log output:
#./multi_pipe_vin_isp_ynr_pym_gdc_vpu -c "sensor=0"  -c"sensor=1 link=0"
sensor_type:0
MIPI host: 0x2
Host 1: Used
Using index:1 sensor_name:sc1336_gmsl-30fps config_file:linear_1280x720_raw10_30fps_2lane.c
sensor_type:1
MIPI host: 0x2
Host 1: Used
Pipeline index 0:
Sensor index: 0
Sensor name: imx219-30fps
Active mipi host: 1
PYM Channel: 0
Encode type: h264
Pipeline index 1:
Sensor index: 0
Sensor name: sc1336_gmsl-30fps
Active mipi host: 4
PYM Channel: 0
Encode type: h264
Verbose: 0
Pipeline Connect Param:
isp [hw:1] [slot_id:4] [mode:1]
ynr [hw:1] [slot_id:4] [mode:1]
pym [hw:1] [slot_id:4] [mode:1]
[1] use [isp + ynr].
isp [hw:1] [slot_id:5] [mode:1]
ynr [hw:1] [slot_id:5] [mode:1]
pym [hw:1] [slot_id:5] [mode:1]
isp channel info: [hw_id: 1] [slot_id: 4] [mode:1]
pym config:
ochn[1] ratio= 2, width = 960, height = 540 wstride=960 vstride=536 out[960*536]
ochn[2] ratio= 4, width = 480, height = 270 wstride=480 vstride=264 out[480*264]
ochn[3] ratio= 8, width = 240, height = 134 wstride=240 vstride=128 out[240*128]
ochn[4] ratio= 16, width = 120, height = 66 wstride=128 vstride=64 out[120*64]
ochn[5] ratio= 32, width = 60, height = 32 wstride=64 vstride=32 out[56*32]
[0] use [gdc].
[0] encoder input resolution is 1920*1080, output file is pipeline0_1920x1080_30fps.h264.
Create Encode idx: 0, init successful
vc_index:0
input info: [mipi_rx: 4] [is_online: 1]
isp channel info: [hw_id: 1] [slot_id: 5] [mode:1]
pym config:
ichn input width = 1280, height = 720
ochn[0] ratio= 1, width = 1280, height = 720 wstride=1280 vstride=720 out[1280*720]
ochn[1] ratio= 2, width = 640, height = 360 wstride=640 vstride=360 out[640*360]
ochn[2] ratio= 4, width = 320, height = 180 wstride=320 vstride=176 out[320*176]
ochn[3] ratio= 8, width = 160, height = 90 wstride=160 vstride=88 out[160*88]
ochn[4] ratio= 16, width = 80, height = 44 wstride=80 vstride=40 out[80*40]
[Warning] ochn[5] ratio= 32, height = 22 < PYM_MIN_HEIGHT(32), so not enable.
[1] not use [gdc].
[1] encoder input resolution is 1280*720, output file is pipeline1_1280x720_30fps.h264.
Create Encode idx: 1, init successful
All deserial link info:
[link_port:0] sc1336_gmsl:0@256
[link_port:1] sc1336_gmsl:0@256
[link_port:2] sc1336_gmsl:0@256
[link_port:3] sc1336_gmsl:0@256
uvc_capture_sample​
Function Overview​
uvc_capture_sample is a program for testing the UVC camera video capture pipeline. It captures images from a UVC camera and saves the output images, and supports displaying ISP-related information.
  • Code location: /app/multimedia_samples/sample_pipeline/uvc_capture_sample
uvc_capture_sample
├── common_utils.c
├── common_utils.h
├── uvc_capture_sample.c
├── uvc_capture_sample.h
├── v4l2_common_utils.c
└── v4l2_common_utils.h
Compilation​
  • Enter the uvc_capture_sample directory and run make to compile.
  • The output binary is uvc_capture_sample, located in the source directory.
Execution​
Run the program directly with ./uvc_capture_sample -h to display help information.
  • -i, --video_id <id>
    • Specifies the video device node, e.g., video0, video1.
  • -d, --dump_file
    • Whether to save image files. Enabling this option saves captured images to files.
  • -F, --format
    • Sets the image format; choose a format supported by the UVC camera, such as YUYV or NV12.
  • -l, --loop_cnt <num>
    • Sets the number of capture loops (i.e., how many frames to capture).
  • -H, --height <px>
    • Sets the image height (in pixels).
  • -W, --width <px>
    • Sets the image width (in pixels).
  • -E, --isp_info
    • Displays ISP exposure and white balance information.
  • -h, --help
Examples:
  • Configure a UVC camera video pipeline using video0, specify YUYV format, and save 5 captured frames.
./uvc_capture_sample -i 0  -l 5 -W 1920 -H 1080 -F YUYV  -d
  • Configure a UVC camera video pipeline using video0, specify YUYV format, save 5 captured frames, and print current exposure and white balance information.
./uvc_capture_sample -i 0  -l 5 -W 1920 -H 1080 -F YUYV  -d -E
Execution Output​
Run the following command:
Example log output:
ptc[0].video_id = 0
ptc[0].loop_cnt = 5
ptc[0].pic_width = 1920
ptc[0].pic_height = 1080
ptc[0].pic_format = 6
ptc[0].dump_mask = 1
DEBUG: index = 0, max_num = 24
pipe_num:0
TestContext[0] create pthread success
loop_cnt: 5
open device: /dev/video0 (fd=3)
driver: uvcvideo
card: FHD Camera Microphone: FHD Came
version: 6.1.83
all caps: 84a00001
device caps: 04200001
0: Motion-JPEG 0x47504a4d 0x1
filedump(./yuv_dump/isp_5_s0_c0_b1_f0_005838.yuv, size(4147200) is successed
loop cnt use up
pipe(0)Test thread 281473524101408---join done.
------ Test case uvc_capture_sample done ------
single_3dgpu_bpu​
Function Overview​
The single_3dgpu_bpu example chains the GPU OpenCL and BPU processing units together. The program first resizes the image via OpenCL, then runs MobileNetV2 inference on the BPU. The OpenCL output is used directly as the BPU inference input, so the memory is shared between the two units without any copy.
  • Code location: /app/multimedia_samples/sample_pipeline/single_3dgpu_bpu
single_3dgpu_bpu
├── bpu_mobilenetv2.c
├── bpu_mobilenetv2.h
├── mobilenetv2_image_labels.h
├── opencl_resize.c
├── opencl_resize.h
└── single_3dgpu_bpu.c
Compilation​
  • Enter the single_3dgpu_bpu directory and run make to compile.
  • The output binary is single_3dgpu_bpu, located in the source directory.
Execution​
Executing ./single_3dgpu_bpu -h displays the help information:
# ./single_3dgpu_bpu -h
[UCP]: log level = 3
[UCP]: UCP version = 3.13.6
[VP]: log level = 3
[DNN]: log level = 3
[HPL]: log level = 3
[UCPT]: log level = 6
Usage: ./single_3dgpu_bpu -i <input_nv12> -W <width> -H <height>
-i, --input NV12 image file
-W, --width Source image width
-H, --height Source image height
-h, --help Show this help
BPU model is hard-coded to: /opt/hobot/model/s100/basic/mobilenetv2_224x224_nv12.hbm
  • -i, --input: Specifies the input NV12 image file. Mandatory.
  • -W, --width: Specifies the source image width. Mandatory.
  • -H, --height: Specifies the source image height. Mandatory.
  • -h, --help: Shows the help information.
Notes:
  1. The input image must be in NV12 format, and both the width and height must be even numbers.
  2. The BPU model path is hard-coded to /opt/hobot/model/s100/basic/mobilenetv2_224x224_nv12.hbm. Make sure this model file exists on the board before running.
Execution Output​
The execution flow of single_3dgpu_bpu is as follows: the program reads the input NV12 image, resizes it via OpenCL, then runs MobileNetV2 classification inference on the resized image via the BPU, and finally prints the inference results.
Example: Taking a 1920x1080 NV12 image as input, run ./single_3dgpu_bpu -i nv12_1920x1080_beach.yuv -W 1920 -H 1080
Example log output:
# ./single_3dgpu_bpu -i nv12_1920x1080_beach.yuv -W 1920 -H 1080
[VP]: log level = 3
=== GPU OpenCL <-> BPU Zero-Copy Sample ===
[INFO] Input: nv12_1920x1080_beach.yuv (1920x1080)
[INFO] Model: /opt/hobot/model/s100/basic/mobilenetv2_224x224_nv12.hbm (hard-coded)
[INFO] hbmem module opened, version: 1.0.0
[INFO] src hbmem buffer allocated: fd=4, size=3110400, virt=0xffff7fe60000, phys=0x460000000
[INFO] dst hbmem buffer allocated: fd=5, size=75264, virt=0xffff86240000, phys=0x460300000
[INFO] Loaded NV12 image: nv12_1920x1080_beach.yuv (1920x1080)
[INFO] Using OpenCL device: Mali-G78AE r0p1
[INFO] OpenCL context created
[INFO] OpenCL buffers imported from hbmem dma-bufs (zero-copy)
[INFO] OpenCL bilinear resize executed on hbmem buffers (zero-copy)
[BPU][[BPU_MONITOR]][281472928418848][INFO]BPULib verison(2, 2, 15)[f21ee84]!
[DNN]: 3.13.6_(4.7.5 HBRT)
[INFO] BPU model loaded: mobilenetv2_224x224_nv12 (input: 224x224, outputs: 1)
[INFO] BPU inference completed
[INFO] BPU inference Top-5 results:
#1: lakeside, lakeshore (0.635)
#2: valley, vale (0.053)
#3: seashore, coast, seacoast, sea-coast (0.046)
#4: coral reef (0.038)
#5: sandbar, sand bar (0.030)
[INFO] BPU model released
[INFO] OpenCL deinitialized
[INFO] hbmem module closed
[INFO] Cleanup complete
