sample_gpu_3d Usage Guide
Function Overview​
The 3D GPU supports the following standard APIs:
  • OpenGLES
  • OpenCL
  • Vulkan
Sample code is provided for two of these APIs:
  1. OpenCL Example
  2. OpenGLES Example
Please select the corresponding API example based on your specific requirements for reference and usage.
OpenCL​
sample_matrix_multiply​
Function Overview​
Description: sample_matrix_multiply performs the same matrix multiplication operation using both the 3D GPU and CPU, and prints the execution time for each.
Code Location and Directory Structure​
  • Code location: /app/multimedia_samples/sample_gpu_3d/cl/sample_matrix_multiply
  • Directory structure:
└── sample_matrix_multiply
└── matrix_multiply.c
Compilation​
  • Enter the sample_matrix_multiply directory and run make to compile.
  • The output binary is matrix_multiply, located in the sample_matrix_multiply source directory.
Execution​
How to Run the Program​
Execute the binary: ./matrix_multiply
Program Parameter Options​
None
Execution Result​
Command executed:
./matrix_multiply
Log output:
./matrix_multiply
CPU execution time: 0.997923 seconds
OpenCL execution time: 0.038153 seconds
Matrices are identical!
Result explanation:
The same matrix multiplication operation was performed:
  1. CPU execution time: 0.997923 seconds
  2. GPU execution time: 0.038153 seconds
From the total execution time, it is evident that the GPU demonstrates significantly higher performance than the CPU for matrix multiplication operations.
OpenGL ES​
sample_bezier​
Function Overview​
Description: sample_bezier uses the 3D GPU to draw a Bézier curve, displayed in two ways:
  1. On the desktop monitor
  2. Saved as an image file
  • Code location: /app/multimedia_samples/sample_gpu_3d/gles/sample_bezier
sample_bezier/
├── bezier.c
└── Makefile
Compilation​
  • Enter the sample_bezier directory and run make to compile.
  • The output binary is bezier, located in the sample_bezier source directory.
Execution​
Before running the program, complete the following preparations:
  1. Connect the RDKS100 to a monitor via HDMI.
  2. Connect a mouse and keyboard to the RDKS100, and log into the Ubuntu system through the monitor's graphical interface.
To run the program:
  1. Navigate to the directory: cd /app/multimedia_samples/sample_gpu_3d/gles/sample_bezier
  2. Execute the program: ./bezier
Note: If the user executing the program differs from the user logged into the graphical interface, run the following commands (e.g., if the program is executed by a user logged in via ssh or serial console):
  1. For example, using the user sunrise, run id -u sunrise to check that the user ID is 1000.
  2. Export the environment variable WAYLAND_DISPLAY using the export command. Note that 1000 in the command below is the user ID obtained in step 1.
root@ubuntu:/app/multimedia_samples/sample_gpu_3d/gles/sample_bezier# id -u sunrise
1000
root@ubuntu:/app/multimedia_samples/sample_gpu_3d/gles/sample_bezier# export WAYLAND_DISPLAY=/run/user/1000/wayland-0
No parameters
Execution Result​
Log output: None
Result explanation:
  1. A window appears on the desktop monitor, displaying a red Bézier curve.
  2. The content shown in the window is also saved as a file: a BMP image named bezier.bmp is generated in the current directory.
