hbmem sample User Guide
Function Overview
hbmem API usage instructions, including the creation and usage of com buffer, graphic buffer, graphic buffer group, queue, pool, and share pool, as well as multi-process sharing.
This sample is implemented based on the libhbmem API, calling the APIs provided by libhbmem to achieve memory allocation for different buffer types and inter-process sharing.
HBMEM Sample Block Diagram
1. Code location: /app/communication_demo/hbmem_demo/sample_hbmem
2. Directory structure:
├── sample_alloc.c
├── sample.c
├── sample_common.c
├── sample_common.h
├── sample_pool.c
├── sample_queue.c
├── sample_share.c
└── sample_share_pool.c
API Process Description
The libhbmem library calls ion for buffer allocation
HBMEM Sample Call Sequence
Flowchart for com buffer, graph buffer, and graphic buffer group allocation
HBMEM Allocate Buffer
Queue usage flowchart
HBMEM Queue
Pool usage flowchart
HBMEM Memory Pool
Share pool usage flowchart
HBMEM Shared Memory Pool
Compilation
Compilation Environment
This sample supports direct compilation on the board.
Compilation Instructions
This sample mainly depends on the header files provided by libhbmem:
#include <hb_mem_mgr.h>
#include <hb_mem_err.h>
The libraries required for compilation are as follows:
LIBS += -lhbmem -lpthread -lalog -ldl -lstdc++
Compilation Commands
# Enter the sample directory:
cd /app/communication_demo/hbmem_demo/sample_hbmem
# Compile this sample:
make
# Output file:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample
Execution
Supported Platforms
  • RDK S600
Execution Guide
Execution Methods
Create com buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 1
Create cached and non-cached com buffer, assign values, compare time consumption
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 2
Create com buffer in various heaps
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 3
Create graph buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 4
Create graph buffer in various heaps
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 5
Create graph buffer group
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 6
Create graph buffer group in various heaps
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 7
Intra-process common buffer sharing
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 8
Intra-process common buffer sharing, consume_cnt
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 9
Inter-process common buffer sharing
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 10
Intra-process graphic buffer sharing
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 11
Intra-process graphic buffer sharing, consume_cnt
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 12
Inter-process graphic buffer sharing
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 13
Intra-process graphic buffer group sharing
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 14
Intra-process graphic buffer group sharing, consume_cnt
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 15
Inter-process graphic buffer group sharing
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 16
Inter-process share pool sharing
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 17
Share pool usage
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 18
Buffer queue usage
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 19
Pool usage
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 20
Implement buffer conversion between graphic buffer and common buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 21
Increase user-space reference count for common buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 22
Increase user-space reference count for graphic buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 23
Execution Parameter Description
  • -m Specifies the sample test case, see the execution results display for details
Test Result Description
  • If the log ends with xxxx done, the sample execution is successful
Execution Results Display
Create com buffer
sample_mode = 1
Ready to sample_alloc_com_buf
alloc com buf, share_id: 16
[1752:1752] Do system command cat /sys/kernel/debug/ion/clients/1752*.
heap_name: size_in_bytes : handle refcount : handle import : buffer ptr : buffer refcount : buffer share id : buffer share count
ion_cma: 400000 : 1 : 1 : fd48e1ab : 3: 16 : 1
[1752:1752] Do system command cat /sys/kernel/debug/ion/heaps/ion_cma | grep -w 1752 | grep -w libhbmem_sample.
libhbmem_sample 1752 4194304
libhbmem_sample 1752 other 4194304 0
[1752:1752] Result 0.
free com buf
[1752:1752] Result 256.
sample_alloc_com_buf done
(Other execution output examples retain the original text structure, with only formatting and keyword adjustments applied; repetitive content omitted here.)
