USB Peripherals
Overview​
USB (Universal Serial Bus) is a high-speed serial communication standard designed to unify PC peripheral interfaces. Its main advantages are plug-and-play, hot-plugging, and power delivery.
Key Features​
Topology: Strict host–device model; the host manages everything and supports tree expansion (up to 127 devices).
Differential signaling: Data is transmitted differentially on D+ and D− lines for strong noise immunity.
Speed generations: USB 2.0 reaches 480 Mbps; USB 3.x/4 reaches tens of Gbps.
Power delivery: Default 5 V, from 500 mA (2.0) up to 240 W (PD), enabling data transfer and charging at the same time.
Connector types: Type-A (common on hosts), Type-B (device side), Type-C (reversible, more capable), and others.
Usage​
Because USB is a general-purpose interface, different device types and protocols use different Python APIs. Below are three common Python–USB interfaces: USB serial, USB camera, and USB audio.
USB Serial​
Serial communication most often uses a USB-to-serial module (e.g. CH340, CP2102), which appears as a COM port on Windows or /dev/ttyUSB0 on Linux. Use pyserial, installable via pip.
warning
Ubuntu 24.04 has some changes to Python package management compared to previous versions. The system Python has PEP 668 (Externally Managed Environment) enabled by default, so it is not recommended to use pip install directly. It is recommended to use a virtual environment or Conda instead. The method for creating a virtual environment is as follows:
sudo apt install python3-venv python3-pip
python3 -m venv myenv
source myenv/bin/activate
# If (myenv) appears in the terminal, the environment has been created successfully and you can use pip install normally.
(myenv) root@ubuntu:~#
pip install pyserial
Typical workflow: list available serial ports → open port → send/receive data → close port
# Required imports
import serial
import serial.tools.list_ports
# List available serial ports
ports = serial.tools.list_ports.comports()
for p in ports:
print(p.device, p.description)
# Open serial port
ser = serial.Serial(
port='/dev/ttyUSB0', # Adjust to your device
baudrate=115200, # Baud rate
timeout=1 # Read timeout (seconds); None blocks
# Send data
ser.write(b'Hello UART\r\n')
# Read data
data = ser.read(10) # Read 10 bytes; may return fewer on timeout
ser.close()
USB Camera​
USB cameras typically use the driverless UVC protocol and appear as video devices. OpenCV makes them easy to use; install via pip.
pip install opencv-python
Typical workflow: open camera → set properties → read frames → release camera
# Required imports
import cv2
# Open camera
cap = cv2.VideoCapture(0)
# Optional: set resolution and frame rate (must match device capabilities)
cap.set(cv2.CAP_PROP_FRAME_WIDTH, 640)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 480)
cap.set(cv2.CAP_PROP_FPS, 30)
# Read frames in a loop
while True:
ret, frame = cap.read() # ret is bool; frame is an image matrix
# Process image (display, analyze, etc.)
cap.release()
USB Audio​
For USB audio devices, you usually do not need to handle USB protocols directly. These devices follow the USB Audio Class (UAC) standard and are exposed as regular audio devices by the OS. Python recommends sounddevice for recording and playback, with soundfile for WAV I/O.
Install dependencies:
pip install sounddevice soundfile numpy
Typical recording workflow:
import sounddevice as sd
import soundfile as sf
duration = 5 # Recording duration in seconds
# Use default input device, or specify device=index after sd.query_devices()
samplerate = int(sd.query_devices(kind='input')['default_samplerate']) # Device default sample rate
print(f"Recording at {samplerate} Hz ...")
recording = sd.rec(int(duration * samplerate), samplerate=samplerate, channels=1, dtype='int16')
sd.wait() # Wait for recording to finish
sf.write('default_mic.wav', recording, samplerate)
print("Saved default_mic.wav")
Typical playback workflow:
data, samplerate = sf.read('default_mic.wav')
print(f"Playing at {samplerate} Hz ...")
sd.play(data, samplerate)
sd.wait() # Wait for playback to finish
print("Playback complete")
Example Applications​
USB Camera Example​
Hardware Connection​
Connect the USB camera to the USB port of the RDK S600 development board.
Software Call​
The following Python example shows how to capture a frame with OpenCV:
import cv2
if not cap.isOpened():
print("Cannot open camera")
exit()
if not ret:
exit()
cv2.imwrite('capture.jpg', frame)
print("Screenshot saved as capture.jpg")
cap.release()
Save as e.g. test_usb_camera.py.
Connect the USB camera, then run python3 test_usb_camera.py. If successful, an image file appears in the current directory.
USB Audio Example​
Connect the USB microphone (or a USB camera with built-in mic) to the USB port of the RDK S600 development board.
Software Call​
The following Python example records audio, plays it back, and saves a WAV file.
import numpy as np
devices = sd.query_devices()
# Input device
in_idx = sd.default.device[0]
for i, d in enumerate(devices):
if d['max_input_channels'] > 0 and 'USB' in d['name']:
in_idx = i
break
rates = [96000, 48000, 44100, 32000, 22050, 16000, 11025, 8000]
sr = 48000
for r in rates:
try:
sd.check_input_settings(device=in_idx, samplerate=r, channels=1, dtype='int16')
sr = r
break
except:
pass
print(f"Recording... device index {in_idx}, sample rate {sr} Hz")
rec = sd.rec(int(3 * sr), samplerate=sr, channels=1, dtype='int16', device=in_idx)
sd.wait()
sf.write('usb_mic.wav', rec, sr)
print("Saved usb_mic.wav")
# Output device
out_idx = sd.default.device[1]
if d['max_output_channels'] > 0 and 'USB' in d['name']:
out_idx = i
break
dev_sr = int(devices[out_idx]['default_samplerate'])
if sr != dev_sr:
dur = len(rec) / sr
n = int(dur * dev_sr)
if rec.ndim == 1:
rec = np.interp(np.linspace(0, len(rec) - 1, n), np.arange(len(rec)), rec)
else:
out = np.zeros((n, rec.shape[1]))
for c in range(rec.shape[1]):
out[:, c] = np.interp(np.linspace(0, len(rec) - 1, n), np.arange(len(rec)), rec[:, c])
rec = out.astype(rec.dtype)
print(f"Playing... device index {out_idx}, sample rate {dev_sr} Hz")
sd.play(rec, dev_sr, device=out_idx)
sd.wait()
Save as e.g. test_usb_audio.py.
Connect a USB microphone (or a USB camera with built-in mic), then run python3 test_usb_audio.py. Speak during Recording...; playback runs during Playing.... The recording is saved as usb_mic.wav.
