Product Overview
RDK™ Stereo Camera GS130WI is a MIPI-based stereo depth camera featuring dual SC132GS global shutter image sensors and an ICM-42688-P 6-axis IMU. It supports synchronized dual-camera exposure and external triggering. The camera has a 70 mm baseline, 1080×1280 resolution per channel, up to 120 fps output frame rate, high dynamic range (HDR), high signal-to-noise ratio (40 dB), and 850/940 nm near-infrared enhancement, making it suitable for robotics vision, machine vision inspection, and motion pose sensing applications.
GS130WI product overview
Compatible Boards
The following table lists compatibility between this product and RDK developer kit boards:
Board NameSupportNotes
RDK X3Not supportedSingle MIPI channel only
RDK X3 ModuleNot supported-
RDK X5Supported-
RDK X5 ModuleSupportedRequires official carrier board or other carrier board
RDK S100/S100PSupportedRequires Camera expansion board
RDK S600Supported-
Other development boards with matching MIPI pinout and dual MIPI interfacesSupportedDriver development required by user
Hardware Interfaces
GS130WI hardware interfaces
  1. Right MIPI Camera interface: for right camera and IMU data transmission;
  2. Left MIPI Camera interface: for left camera data transmission;
  3. External interrupt interface: for receiving interrupt signals from the IMU or sending interrupt signals to the IMU;
  4. IMU interrupt selection switch: for switching the interrupt connection of the IMU INT2 pin.
For details, see Hardware Reference.
Key Specifications
NameDescription
Resolution1.3 MP
Pixel size1080×1280
Maximum frame rate120 fps
Output formatRAW RGB 12/10/8 bit
Typical output configuration1280×1080@30fps, 10-bit
1280×1080@60fps, 10-bit
Gyroscope noise2.8 mdps/rt-Hz
Gyroscope range± 15.625 / 31.25 / 62.5 / 125 / 250 / 500 / 1000 / 2000 dps
Accelerometer noise70 ug/rt-Hz
Accelerometer range± 2 / 4 / 8 / 16 g
Stereo baseline70mm
Field of view (FOV)H: 96.8°
V: 115.6°
D: 157.2°
Video interfaceMIPI CSI-2 (2-lane)
Maximum transfer rate2.4 Gbps
