5.1.5 使用ROS2 package
前提:已成功安装TogetheROS.Bot
tros.b和ROS2 Foxy/Humble/Jazzy版本接口完全兼容,能够复用ROS2丰富工具包,这里以安装和使用ROS2 image-transport为例介绍如何在tros.b中使用ROS package。
安装ROS2 package​
1 添加ROS apt源​
安装tros.b时,已自动添加ROS apt源,无需手动添加。
更新apt仓库
sudo apt update
如果sudo apt update命令执行失败或报错,请查看常见问题章节的Q10: apt update 命令执行失败或报错如何处理?解决。
如果sudo apt update命令执行失败或报错,请查看常见问题章节的Q6: apt update 命令执行失败或报错如何处理?解决。
2 安装packages​
sudo apt install ros-foxy-image-transport
sudo apt install ros-foxy-image-transport-plugins
sudo apt install ros-humble-image-transport
sudo apt install ros-humble-image-transport-plugins
sudo apt install ros-jazzy-image-transport
sudo apt install ros-jazzy-image-transport-plugins
使用ROS2 package​
与ROS使用一样
source /opt/tros/setup.bash
ros2 run image_transport list_transports
运行结果如下,展示了image_transport package支持的图像格式
root@ubuntu:/opt/tros# ros2 run image_transport list_transports
Declared transports:
image_transport/compressed
image_transport/compressedDepth
image_transport/raw
image_transport/theora
Details:
"image_transport/compressed"
- Provided by package: compressed_image_transport
- Publisher:
This plugin publishes a CompressedImage using either JPEG or PNG compression.
- Subscriber:
This plugin decompresses a CompressedImage topic.
"image_transport/compressedDepth"
- Provided by package: compressed_depth_image_transport
- Publisher:
This plugin publishes a compressed depth images using PNG compression.
- Subscriber:
This plugin decodes a compressed depth images.
"image_transport/raw"
- Provided by package: image_transport
- Publisher:
This is the default publisher. It publishes the Image as-is on the base topic.
- Subscriber:
This is the default pass-through subscriber for topics of type sensor_msgs/Image.
"image_transport/theora"
- Provided by package: theora_image_transport
- Publisher:
This plugin publishes a video packet stream encoded using Theora.
- Subscriber:
This plugin decodes a video packet stream encoded using Theora.
