7.3.6 Video Processing
Overview
VPS (Video Process System) is a video processing system that supports image scaling, zooming, cropping, rotation, GDC correction, frame rate control, and pyramid image output.
Function Description
Basic Concepts
Group
The
VPSprovides the concept of groups to users, and each group time-sharing multiplexes theIPU,GDC,PYMhardware. MultipleVPS groupscan be cascaded for use. -
Channel
The channel of
VPSrepresents an output ofVPS. The output channels are mainly divided into ordinary image channels and pyramid image channels. The ordinary channel outputs the single-layer data after scaling, cropping, or rotating, and the pyramid channel outputs multi-layer pyramid scaled data.
The VPS can be bound to other modules via the system control interface provided by System Control. It can accept inputs from the VIN and VDEC modules, and its outputs can be connected to the VOT, VENC, or another VPS module for more channels. Input sources are connected to VPS, and receivers are connected from VPS. Users can manage groups through the VPS interface, with each group allowed to bind to only one input source, and each channel capable of binding to different modules. When connecting VPS to VIN, the HB_SYS_SetVINVPSMode function must be called to configure the online or offline mode between VIN and VPS.
The VPS hardware consists of an IPU, a PYM, and two GDCs. It offers seven output channels (chn0 to chn6), with chn0 to chn4 supporting downsampling, chn5 enabling upsampling, and all channels capable of cropping (ROI), rotation, correction, and frame rate control. Chn6 serves as the pyramid online channel. The hardware reuses resources, with the gray block in the OSD being CPU overlay, and the three beige blocks representing hardware overlays.
Upscaling Functionality:
- Limitations:
- Horizontal scaling up to 1.5x, width must be a multiple of 4, minimum 32x32, maximum 4096.
- Vertical scaling up to 1.5x, height must be even, minimum 32x32, maximum 4096.
- Only chn5 supports upsampling.
Downsampling Functionality:
- Limitations:
- Maximum horizontal downsampling to 1/8th of the original size (greater than 1/8), minimum 32x32, maximum 4096.
- Maximum vertical downsampling to 1/8th of the original size (greater than 1/8), minimum 32x32, maximum 4096.
- Chn0 to chn4 support downsampling.
IPU Channel Size Constraints:
| Scaler | FIFO(bytes) | Resolution(pixel) |
| Scaler 5 (IPU US) | 4096 | 8M |
| Scaler 2 (IPU DS2) | 4096 | 8M |
| Scaler 1 (IPU DS1) | 2048 | 2M |
| Scaler 3 (IPU DS3) | 2048 | 2M |
| Scaler 4 (IPU DS4) | 1280 | 1M |
| Scaler 0 (IPU DS0) | 1280 | 1M |
Cropping Functionality:
VPS allows cropping of input images, selecting a ROI region for resizing or shrinking.
PYM Pyramid Processing Functionality:
Input:
- Maximum width: 4096
- Maximum height: 4096
- Minimum width: 64
- Minimum height: 64
Output:
- Minimum width: 48
- Minimum height: 32
Layers:
- 24 layers for shrinking (0-23, with Base layers at 0, 4, 8, 12, 16, 20, and ROI layers based on Base layers)
- 6 layers for zooming (24-29, fixed scales: 1.28x, 1.6x, 2x, 2.56x, 3.2x, 4x)
- Non-online channels: PYM channels 0-5
One
PYMcan be used per group.
Cautionary Notes:
PYMhardware requires at least BASE0 and BASE4 layers to be enabled. -
When using the online input (chn6), the total output data volume of all PYM ds layers (0-23) must not exceed 2.5 times the input data volume, and the sum of US layer widths (24-29) should not exceed the input width, otherwise, there may be unknown risks.
After binding
IPUtoPYM, it cannot be further bound toVOT,VPS, orVENCmodules.
Rotation Functionality:
VPSsupports 90°, 180°, and 270° rotations.- Supports either Group rotation (all channels affected) or Channel rotation (rotation of specific chn0-chn5 pairs).
- PYM-processed channels cannot be rotated.
GDC Correction Functionality:
VPSaccepts distortion correction files for input image correction.- Supports either Group correction (all channels affected) or Channel correction (specific chn0-chn5 pairs).
- Channels can be corrected independently.
Frame Rate Control Functionality:
- Channels 0-5 of
VPSsupport frame rate control, allowing any frame rate up to or equal to the input frame rate.
API Reference
HB_VPS_CreateGrp
Function Declaration:
int HB_VPS_CreateGrp(int VpsGrp, const VPS_GRP_ATTR_S *grpAttr);
Function Description:
Creates a VPS Group
Parameter Descriptions:
| Parameter Name | Description | Input/Output |
| VpsGrp | Group ID | Input |
| grpAttr | Group attribute pointer | Input |
Return Values:
| Return Value | Description |
| 0 | Success |
| Non-zero | Failure |
Cautionary Note:
Up to 8 groups can be created. Group attributes mainly include input width, height, and GDC buffer depth.
Reference Code:
VPS reference code
HB_VPS_DestroyGrp
int HB_VPS_DestroyGrp(int VpsGrp);
Destroys a VPS Group
Return Values:
| 0 | Success |
Cautionary Note:
The group must already exist.
Reference Code:
None
HB_VPS_StartGrp
int HB_VPS_StartGrp(int VpsGrp);
Starts processing for a VPS Group
Return Values:
| 0 | Success |
Cautionary Note:
The group must already be created.
Reference Code:
VPS reference code
HB_VPS_StopGrp
int HB_VPS_StopGrp(int VpsGrp);
Stops processing for a VPS Group
| VpsGrp | Group ID |
Return Values:
| 0 | Success |
Cautionary Note:
The group must already be created and started.
Reference Code:
VPS reference code
HB_VPS_GetGrpAttr
【Function Declaration】
int HB_VPS_GetGrpAttr(int VpsGrp, VPS_GRP_ATTR_S *grpAttr);
【Function Description】
Get the attributes of VPS Group.
【Parameter Description】
| VpsGrp | Group Number | Input |
| grpAttr | Pointer to attribute struct | Output |
【Return Value】
| 0 | Success |
【Note】
None
【Reference Code】
None
HB_VPS_SetGrpAttr
int HB_VPS_SetGrpAttr(int VpsGrp, const VPS_GRP_ATTR_S *grpAttr);
Set the attributes of VPS Group.
| grpAttr | Pointer to attribute struct | Input |
| 0 | Success |
【Notes】
No
【Reference Code】
VPS Reference Code
HB_VPS_SetGrpRotate
int HB_VPS_SetGrpRotate(int VpsGrp, ROTATION_E enRotation);
Set the rotation function for VPS Group, rotate all outputs of VPS
| VpsGrp | Group number | Input |
| enRotation | Rotation parameter | Input |
【Return Value】
| 0 | Success |
【Notes】
This interface needs to be called before HB_VPS_SetChnAttr, disable ChnRotate after enabling GroupRotate; isp binding ipu must be in offline mode
【Reference Code】
VPS Reference Code
HB_VPS_GetGrpRotate
int HB_VPS_GetGrpRotate(int VpsGrp, ROTATION_E *enRotation);
Retrieves the rotation feature property for a VPS Group
| enRotation | Pointer to rotation parameter | Output |
Return Values
| 0 | Success |
Note
None
Reference Code
No reference code provided
HB_VPS_SetGrpRotateRepeat
int HB_VPS_SetGrpRotateRepeat(int VpsGrp, ROTATION_E enRotation);
Sets dynamic group rotation: This interface saves the channel configuration for the current group and subsequent bound VPS groups. It automatically recalculates dimensions, ROI regions, initializes the group, and rebinds VIN based on the provided
enRotation.
Return Values
| 0 | Success |
Note
This interface is not supported for scenarios with PYM configuration.
Reference Code
HB_VPS_SetGrpGdc
int HB_VPS_SetGrpGdc(int VpsGrp, char* buf_addr, uint32_t buf_len, ROTATION_E enRotation)
Sets the GDC correction function for a VPS Group, ensuring all outputs from VPS have correction effects applied.
| buf_addr | Address of the correction file | Input |
| buf_len | Length of the correction file | Input |
Return Values
| 0 | Success |
Note
This interface must be called before HB_VPS_SetChnAttr. Different correction bin files are required based on the lens, distortion, and dimensions.
Reference Code
VPS Reference Code
HB_VPS_SendFrame
int HB_VPS_SendFrame(int VpsGrp, void* videoFrame, int ms);
Sends data to VPS
| videoFrame | Pointer to image data; the VPS feedback data structure is of type hb_vio_buffer_t; | Input |
| ms | Timeout parameter; -1 for blocking interface, 0 for non-blocking, positive values for timeout in milliseconds (ms) | Input |
Return Values
| 0 | Success |
Note
None
Reference Code
VPS Reference Code
HB_VPS_SetChnAttr
int HB_VPS_SetChnAttr(int VpsGrp, int VpsChn, const VPS_CHN_ATTR_S *chnAttr);
Set the attributes of VPS channel (set the output size of a specific channel in IPU)
| VpsChn | Channel number | Input |
| chnAttr | Channel attribute | Input |
【Return Value】
| 0 | Success |
【Notice】
This interface supports dynamically configuring the output size of IPU. Dynamic configuration needs to call this interface after StartGrp. The new size for dynamic configuration cannot be larger than the initial configuration size. If you need to change from a smaller size to a larger size after starting, you need to call this interface twice before StartVps, passing the maximum size for the first time and the minimum size for the second time.
【Reference Code】
VPS reference code
HB_VPS_GetChnAttr
int HB_VPS_GetChnAttr(int VpsGrp, int VpsChn, VPS_CHN_ATTR_S *chnAttr);
Get the attributes of VPS channel
| chnAttr | Channel attribute | Output |
| 0 | Successful |
| Non-zero | Failed |
【Notes】
None
【Reference Code】
None
HB_VPS_EnableChn
int HB_VPS_EnableChn(int VpsGrp, int VpsChn);
Enable the VPS channel
【Return Value】
| 0 | Successful |
| Non-zero | Failed |
【Notes】
If the channel is not enabled, the GetChnFrame interface cannot obtain images.
【Reference Code】
VPS reference code
HB_VPS_DisableChn
int HB_VPS_DisableChn(int VpsGrp, int VpsChn);
Disable a VPS channel
| VpsChn | Channel ID | Input |
Return Values
| 0 | Success |
Caution
None
Reference Code
VPS Reference Code
HB_VPS_SetChnRotate
int HB_VPS_SetChnRotate(int VpsGrp, int VpsChn, ROTATION_E enRotation);
Set the image rotation angle for a VPS channel
| enRotation | Rotation Type | Input |
Return Values
| 0 | Success |
Caution
SetChnRotate must be called after SetChnAttr, and up to two CHNs can be rotated simultaneously. It is also supported after startup for dynamic channel rotation control.
Reference Code
VPS Reference Code
HB_VPS_GetChnRotate
int HB_VPS_GetChnRotate(int VpsGrp, int VpsChn, ROTATION_E *enRotation);
Retrieve the image rotation property for a VPS channel
| enRotation | Rotation Type | Output |
Return Values
| 0 | Success |
Caution
None
Reference Code
N/A
HB_VPS_SetChnGdc
int HB_VPS_SetChnGdc(int VpsGrp, int VpsChn, char* buf_addr, uint32_t buf_len, ROTATION_E enRotation)
Sets the GDC correction feature for a VPS channel
| buf_addr | Correction file address | Input |
| buf_len | Correction file length | Input |
Return Values
| 0 | Success |
Note
This interface must be called after HB_VPS_SetChnAttr, and at most two CHNs can be corrected simultaneously. Different lenses, distortions, and dimensions require different calibration bin files.
Reference Code
VPS reference code
HB_VPS_UpdateGdcSize
int HB_VPS_UpdateGdcSize(int VpsGrp, int VpsChn, uint16_t out_width, uint16_t out_height)
Updates the GDC correction output size (the default input and output sizes for GDC are the same, but this interface allows changing the GDC output size)
| out_width | Output width | Input |
| out_height | Output height | Input |
Return Values
| 0 | Success |
Note
This interface should be called after HB_VPS_SetChnGdc and HB_VPS_SetGrpGdc. The provided output size must match the calibration bin file. The output dimensions cannot be larger than the current GDC input size.
Reference Code
Scenario where GDC correction output size differs from input in a group:
ret = HB_VPS_SetGrpGdc(grp_id, bin_buf, buf_len, degree);
ret = HB_VPS_UpdateGdcSize(grp_id, 0, 1280, 720);
Scenario where GDC correction output size differs from input in a channel:
ret = HB_VPS_SetChnGdc(grp_id, chn_id, bin_buf, buf_len, degree);
HB_VPS_SetChnCrop
int HB_VPS_SetChnCrop(int VpsGrp, int VpsChn, const VPS_CROP_INFO_S *cropInfo)
Configures the cropping for a VPS channel.
| cropInfo | Crop properties | Input |
Return Values
| 0 | Success |
Note
Call this function after HB_VPS_SetChnAttr; the ROI region must be within the IPU input size.
Reference Code
VPS Reference Code
HB_VPS_GetChnCrop
int HB_VPS_GetChnCrop(int VpsGrp, int VpsChn, VPS_CROP_INFO_S *cropInfo)
Retrieves the fixed cropping settings for a VPS channel.
| cropInfo | Crop properties | Output |
Return Values
| 0 | Success |
Note
No additional notes.
Reference Code
None
HB_VPS_SetChnFrameRate
int HB_VPS_SetChnFrameRate(int VpsGrp, int VpsChn, FRAME_RATE_CTRL_S *frameRate)
Sets the frame rate for a VPS channel.
| frameRate | Frame rate control structure | Input |
Return Values
| 0 | Success |
Note
Reference Code
None
HB_VPS_TriggerSnapFrame
int HB_VPS_TriggerSnapFrame(int VpsGrp, int VpsChn, uint32_t frameCnt)
Trigger snapshot frames; Mark frameCnt frames starting from the current one.
| frameCnt | Number of frames to capture | Input |
Return Values
| 0 | Success |
Note
Must be called after initialization.
Reference Code
No reference code provided.
HB_VPS_GetChnFrame
int HB_VPS_GetChnFrame(int VpsGrp, int VpsChn, void *videoFrame, int ms)
Retrieve a processed image frame from a channel
| videoFrame | Pointer to the image data structure (hb_vio_buffer_t for normal BUF structure, pym_buffer_t for pyramid BUF structure) | Output |
| ms | Timeout parameter -1 for blocking interface 0 for non-blocking interface Positive value for timeout in milliseconds (ms) | Input |
Return Values
| 0 | Success |
Note
The retrieved image structure can be either a normal BUF structure (hb_vio_buffer_t) or a pyramid BUF structure (pym_buffer_t).
Reference Code
VPS Reference Code (not provided)
HB_VPS_GetChnFrame_Cond
int HB_VPS_GetChnFrame_Cond(int VpsGrp, int VpsChn, void *videoFrame, int ms, int time);
Retrieves a processed image from the channel conditionally.
| videoFrame | Pointer to the image data | Output |
| time | Time condition: 0 means discard old frames and wait for a new one; other values are not supported yet. | Input |
Return Values
| 0 | Success |
Note
Reference Code
VPS Reference Code (not included here as it would typically be a part of the implementation and not shown in the documentation)
HB_VPS_ReleaseChnFrame
int HB_VPS_ReleaseChnFrame(int VpsGrp, int VpsChn, void *videoFrame);
Release a frame of channel image.
| videoFrame | Image information | Input |
【Return Value】
| 0 | Success |
【Note】
None.【Reference Code】 VPS reference code
HB_VPS_SetPymChnAttr
int HB_VPS_SetPymChnAttr(int VpsGrp, int VpsChn, const VPS_PYM_CHN_ATTR_S *pymChnAttr);
Set pyramid channel attributes
| pymChnAttr | Pyramid channel attributes pointer | Input |
【Return Value】
| 0 | Success |
