看门狗驱动调试指南
代码路径​
drivers/watchdog/hobot_wdt.c # watchdog 驱动代码源文件
include/linux/watchdog.h # watchdog 驱动代码头文件
dts 配置​
/* arch/arm64/boot/dts/hobot/hobot-xj3.dtsi */
watchdog: watchdog@0xA1002000 {
compatible = "hobot,hobot-wdt";
reg = <0 0xA1002000 0 0x1000>;
clocks = <&timer0_mclk>;
clock-names = "watchdog_mclk";
interrupt-parent = <&gic>;
interrupts = <0 15 4>;
pet-time = <6>;
bark-time = <11>;
bite-time = <15>;
status = "disabled";
/* arch/arm64/boot/dts/hobot/hobot-x3-sdb.dts */
&watchdog {
/* arch/arm64/boot/dts/hobot/hobot-xj3-xvb.dtsi */
&watchdog {
内核配置​
/* arch/arm64/configs/xj3_debug_defconfig */
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
# CONFIG_WATCHDOG_SYSFS is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_ARM_SP805_WATCHDOG is not set
# CONFIG_ARM_SBSA_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
# CONFIG_MAX63XX_WATCHDOG is not set
CONFIG_HOBOT_WATCHDOG=y
# CONFIG_HOBOT_WATCHDOG_ENABLE is not set/*打开这个选项系统会自动喂狗*/
CONFIG_HOBOT_WATCHDOG_TEST=y
# CONFIG_MEN_A21_WDT is not set
CONFIG_WATCHDOG=y
CONFIG_HOBOT_WATCHDOG_ENABLE=y/*打开这个选项系统会自动喂狗*/
# CONFIG_HOBOT_WATCHDOG_TEST is not set
使用示例​
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h> //UNIX标准函数定义
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h> //文件控制定义
#include <termios.h> //PPSIX终端控制定义
#include <errno.h> //错误号定义
#include <pthread.h>
#include <linux/watchdog.h>
#include <string.h>
#include <sys/ioctl.h>
int watchdogfd;
int feeddog = 1;
void* feeddogthread()
int feeddogvalue;
int returnval;
feeddogvalue = 65535;
while (feeddog) {
//每隔10秒,将重载看门狗计数寄存器的值
printf("feed dog\n");
returnval = write(watchdogfd, &feeddogvalue, sizeof(int));
sleep(10);
int main()
pthread_t watchdogThd;
//int watchdogfd;
int returnval;
char readline[32], *p;
//打开看门狗设备
if ((watchdogfd = open("/dev/watchdog", O_RDWR|O_NONBLOCK)) < 0) {
printf("cannot open the watchdog device\n");
exit(0);
int timeout = 15;
int timeleft;
ioctl(watchdogfd, WDIOC_SETTIMEOUT, &timeout);
printf("The timeout was set to %d seconds\n", timeout);
//创建喂狗线程
returnval = pthread_create(&watchdogThd, NULL, feeddogthread, NULL);
if (returnval < 0)
printf("cannot create feeddog thread\n");
while (1) {
printf("Command (e quit): ");
memset(readline, '\0', sizeof(readline));
fgets(readline, sizeof(readline), stdin);
/* 去字符串前部空字符 */
p = readline;
while(*p == ' ' || *p == '\t')
p++;
switch(*p) {
case 'g':
ioctl(watchdogfd, WDIOC_GETTIMEOUT, &timeout);
printf("The timeout was is %d seconds\n", timeout);
break;
case 'e':
printf("Close watchdog an exit safety!\n");
//write(watchdogfd, "V", 1);
int disable_dog = WDIOS_DISABLECARD;
ioctl(watchdogfd, WDIOC_SETOPTIONS, &disable_dog);
close(watchdogfd);
break;
case 's':
printf("stop feed dog\n");
feeddog = 0;
break;
case 't':
ioctl(watchdogfd, WDIOC_GETTIMELEFT, &timeleft);
printf("The timeout was is %d seconds\n", timeleft);
break;
case 'r':
printf("we don't close watchdog. The machine will reboot in a few seconds!\n");
printf("wait......\n");
break;
default:
printf("get error char: %c\n", *p);
