2.6 GUI Network Configuration Process
This section describes how to configure static IP, DNS, and Proxy settings for the ETH network via the GUI interface in the Ubuntu system.
Modifying Static IP and DNS Configuration
  1. After entering the desktop, click the bottom-left corner to open the application list and select the Settings app. In the pop-up window, choose Network.
image-show-app
  1. Ethernet (eth0) and Ethernet (eth1) correspond to configurations for different physical network ports, as shown below:
image-phy-eth
image-sel-eth
  1. Taking Ethernet (eth1) as an example, click the gear icon next to the edit button. In the pop-up window, select IPv4, choose Manual for manual configuration, and enter the IP address, subnet mask, and gateway in the Addresses field below.
image_set_static_ip
  1. Scroll down and enter the DNS configuration in the DNS field below.
image_set_static_dns
  1. To assign multiple IP addresses to a single network interface (using Ethernet (eth1) as an example), click the plus sign (+) on the right. Configure the additional IP address following the same steps as in steps 3 and 4. After completing the configuration, ensure that the netplan-eth1 option is selected (indicated by a ).
image-sel_ok
Modifying Proxy Configuration
Similar to configuring a static IP, follow these steps to modify the Proxy settings:
  2. Scroll down and click the gear icon next to Network Proxy to access its configuration.
image-proxy
  1. Enter the required proxy settings in the pop-up window.
image-proxy_set
Modify Static IP, DNS Configuration
  1. After entering the desktop, click the bottom left corner to open the application list, select the settings application, and in the pop-up interface, choose Network.
image-show-app
  1. Ethernet (eth0), Ethernet (eth1), Ethernet (eth3), and Ethernet (eth4) correspond to different physical network port configurations. The mapping between configuration and physical ports is as follows:
image-phy-ethimage-sel-eth
  1. Take modifying Ethernet (eth1) as an example. Click the gear icon in the options on the right side of the modify button. In the pop-up interface, select IPV4, choose Manual for manual configuration, and enter the IP address, subnet mask, and gateway in the Addresser field below.
image_set_static_ip
  1. Enter the DNS configuration in the DNS field below.
  1. To configure multiple IP addresses for a single network card, take Ethernet (eth1) as an example. Click the plus sign on the right, configure the IP address following the same steps as in steps 3 and 4. After completing the configuration, make sure to select netplan-eth1 and verify that the option appears.
image-sel_ok
Modify Proxy Configuration
Similar to modifying a static IP, the steps to modify the Proxy configuration are as follows:
  2. Select Proxy and click to enter the configuration.
image-proxy
  1. Fill in the required configuration in the redirected interface.
image-proxy_set_0image-proxy_set_1
