Instance Segmentation - Ultralytics YOLOE11
S100 only
This sample applies only to RDK S100. The RDK S600 system image does not include the corresponding HBM model, and the related sample code is only shipped with the S100 system image; it is not supported on S600 yet.
This sample shows how to run the Ultralytics YOLOE11 instance segmentation model on BPU using hbm_runtime. The program implements the full pipeline from input image preprocessing, model inference, and postprocessing to result visualization. The sample code is located in /app/pydev_demo/05_open_instance_seg_sample/01_yoloe11_seg/.
Model Description​
  • Introduction:
    Ultralytics YOLOE11 is a high-performance edge-side instance segmentation model suitable for open-vocabulary object detection and segmentation tasks. Through multi-scale feature extraction, dense classification, and prototype mask generation, the model effectively identifies objects in images and outputs fine-grained instance segmentation results. This sample uses the lightweight version of Ultralytics YOLOE11 with a 640x640 input image, supporting generalized object classification and segmentation across 4585 classes.
  • HBM model name: yoloe_11s_seg_pf_nashe_640x640_nv12.hbm
  • Input format: NV12, size 640x640
  • Output:
    • Detection boxes (xyxy format)
    • Class ID and confidence score
    • Instance segmentation masks (one independent mask per instance)
  • Model download URL (automatically downloaded by the program):
    https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yoloe_11s_seg_pf_nashe_640x640_nv12.hbm
Features​
  • Model loading
    Use hbm_runtime to load the specified quantized model and parse metadata such as input/output names, shapes, and quantization parameters.
  • Input preprocessing
    Resize the BGR image to 640x640, convert it to NV12 format (Y and UV separated), and construct the inference input tensor.
  • Inference execution
    Execute forward inference through the .run() interface. Scheduling policies such as running priority and BPU core binding are supported.
  • Output postprocessing
    Postprocess multi-scale outputs, including:
    • Class confidence filtering (based on score threshold)
    • DFL bounding box decoding
    • Mask prototype fusion and mask generation
    • NMS filtering and result merging
    • Scale detection boxes and masks back to the original image size
    • Optional mask morphological opening and boundary contour drawing
Environment Dependencies​
This sample has no special environment requirements. You only need to ensure the dependencies in pydev are installed.
Directory Structure​
├── yoloe11_seg.py # Main inference script
└── README.md # Usage instructions
Parameter Description​
ParameterDescriptionDefault Value
--model-pathBPU quantized model path (*.hbm)/opt/hobot/model/s100/basic/yoloe_11s_seg_pf_nashe_640x640_nv12.hbm
--test-imgInput test image path/app/res/assets/office_desk.jpg
--label-fileClass label file path (one class per line)/app/res/labels/coco_extended.names
--priorityModel scheduling priority (0~255)0
--bpu-coresBPU core IDs to use (for example, --bpu-cores 0 1)[0]
--nms-thresIoU threshold for non-maximum suppression (NMS)0.7
--score-thresObject detection confidence threshold0.25
--is-openWhether to apply morphological opening to masksFalse
--is-pointWhether to draw mask boundary contour pointsFalse
Quick Start​
  • Run the model
    • Use default parameters
      python yoloe11_seg.py
    • Run with specified parameters
      python yoloe11_seg.py \
      --model-path /opt/hobot/model/s100/basic/yoloe_11s_seg_pf_nashe_640x640_nv12.hbm \
      --priority 0 \
      --bpu-cores 0 \
      --test-img /app/res/assets/office_desk.jpg \
      --label-file /app/res/labels/coco_extended.names \
      --img-save-path result.jpg \
      --nms-thres 0.7 \
      --score-thres 0.25 \
      --is-open False \
      --is-point False
  • View the result
    After successful execution, results will be drawn on the original image and saved to the path specified by --img-save-path.
    [Saved] Result saved to: result.jpg
Notes​
  • If the specified model path does not exist, the program will attempt to download the model automatically.
License​
