sample_pym Usage Instructions
Function Overview​
sample_pym reads a YUV file into memory allocated by hbm, passes it to PYM, which processes it in a pyramid layer manner, and finally dumps the processed YUV data to the file system.
Code Location and Directory Structure​
  • Code location: /app/multimedia_samples/sample_pym
  • Directory structure:
sample_pym/
└── sample_pym.c
Compilation​
Run the make command in the source code directory to compile:
cd /app/multimedia_samples/sample_pym
make
Execution​
How to Run the Program​
Execute the program directly with ./sample_pym to display help information:
Program Argument Options​
./sample_pym
Usage: sample_pym [OPTIONS]
-i, --input_file FILE Specify the input file
-w, --input_width WIDTH Specify the input width
-h, --input_height HEIGHT Specify the input height
-f, --feedback Specify feedback mode
-V, --verbose Enable verbose mode
  • -i: Specifies the input YUV file. The test program uses files in NV12 format as input.
  • -w: Width of the input YUV image.
  • -h: Height of the input YUV image.
  • -f: Specifies the PYM operating mode. By default, it runs in Vflow mode.
Execution Example​
Taking a YUV image with input resolution 1920×1080 as an example, run:
./sample_pym -i /app/res/assets/nv12_1920x1080.yuv -w 1920 -h 1080.
This feeds a YUV image into PYM, initializes six channels, performs downsampling operations at scales of 1, 1/2, 1/4, 1/8, 1/16, and 1/32 respectively, and saves the processed images as YUV files:
  • Channel 0 outputs the original resolution: 1920 × 1080.
  • Channel 1 outputs width and height each halved: 960 × 540.
  • Channel 2 outputs width and height each quartered: 480 × 270.
  • Channel 3 outputs width and height each reduced by 1/8: 240 × 134.
  • Channel 4 outputs width and height each reduced by 1/16: 120 × 66.
  • Channel 5 outputs width and height each reduced by 1/32: 60 × 32.
Output log as follows:
pym vnode work mode: vflow
Using input file:/app/res/assets/nv12_1920x1080.yuv, input:1920x1080
(read_yuvv_nv12_file):file read(/app/res/assets/nv12_1920x1080.yuv), y-size(2073600)
pym config:
ichn input width = 1920, height = 1080
ochn[0] ratio= 1, width = 1920, height = 1080 wstride=1920 vstride=1080 out[1920*1080]
ochn[1] ratio= 2, width = 960, height = 540 wstride=960 vstride=540 out[960*540]
ochn[2] ratio= 4, width = 480, height = 270 wstride=480 vstride=270 out[480*270]
ochn[3] ratio= 8, width = 240, height = 134 wstride=240 vstride=134 out[240*134]
ochn[4] ratio= 16, width = 120, height = 66 wstride=128 vstride=66 out[120*66]
ochn[5] ratio= 32, width = 60, height = 32 wstride=64 vstride=32 out[60*32]
Note:
  1. The width output by the PYM module is aligned to 16-byte boundaries. When viewing images, pay attention to cases where the width differs from the wstride parameter.
