hbmem sample usage instructions
Function Overview​
Instructions for using hbmem APIs, including creation and usage of com buffer, graphic buffer, graphic buffer group, queue, pool, share pool, and multi-process sharing.
Software Architecture Description​
This sample is implemented based on the libhbmem API, invoking APIs provided by libhbmem to allocate memory for different buffer types and enable inter-process sharing.
HBMEM Sample Block Diagram
Code Location and Directory Structure​
1. Code location: /app/communication_demo/hbmem_demo/sample_hbmem
2. Directory structure:
├── sample_alloc.c
├── sample.c
├── sample_common.c
├── sample_common.h
├── sample_pool.c
├── sample_queue.c
├── sample_share.c
└── sample_share_pool.c
API Workflow Description​
The libhbmem library calls ION to allocate buffers.
HBMEM Sample Call Sequence
Allocation flowchart for com buffer, graph buffer, and graphic buffer group:
HBMEM Allocate Buffer
Queue usage flowchart:
HBMEM Queue
Pool usage flowchart:
HBMEM Memory Pool
Share pool usage flowchart:
HBMEM Shared Memory Pool
Compilation​
Compilation Environment​
This sample supports direct compilation on the board.
Compilation Instructions​
This sample primarily depends on header files provided by libhbmem:
#include <hb_mem_mgr.h>
#include <hb_mem_err.h>
Compilation dependencies include the following libraries:
LIBS += -lhbmem -lpthread -lalog -ldl -lstdc++
Compilation Commands​
# Enter the sample directory:
cd /app/communication_demo/hbmem_demo/sample_hbmem
# Compile the sample:
make
# Output file:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample
Execution​
Supported Platforms​
  • RDK S100 / RDK S100P
Running Guide​
Execution Methods​
Create a com buffer:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 1
Create cached and non-cached com buffers, perform assignment, and measure execution time:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 2
Create com buffers in various heaps:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 3
Create a graphic buffer:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 4
Create graphic buffers in various heaps:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 5
Create a graphic buffer group:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 6
Create graphic buffer groups in various heaps:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 7
Intra-process common buffer sharing:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 8
Intra-process common buffer sharing with consume_cnt:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 9
Inter-process common buffer sharing:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 10
Intra-process graphic buffer sharing:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 11
Intra-process graphic buffer sharing with consume_cnt:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 12
Inter-process graphic buffer sharing:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 13
Intra-process graphic buffer group sharing:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 14
Intra-process graphic buffer group sharing with consume_cnt:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 15
Inter-process graphic buffer group sharing:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 16
Inter-process share pool sharing:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 17
Share pool usage:
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 18
```buffer queue usage
```bash
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 19
pool usage
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 20
Implement buffer conversion between graphic buffer and common buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 21
Increment user-space reference count of common buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 22
Increment user-space reference count of graphic buffer
/app/communication_demo/hbmem_demo/sample_hbmem/libhbmem_sample -m 23
Runtime Parameter Description​
  • -m specifies the sample test case; refer to the execution output for details.
Test Result Description​
  • If the log ends with xxxx done, it indicates the sample executed successfully.
Execution Output Examples​
Create com buffer​
sample_mode = 1
Ready to sample_alloc_com_buf
alloc com buf, share_id: 16
[1752:1752] Do system command cat /sys/kernel/debug/ion/clients/1752*.
heap_name: size_in_bytes : handle refcount : handle import : buffer ptr : buffer refcount : buffer share id : buffer share count
ion_cma: 400000 : 1 : 1 : fd48e1ab : 3: 16 : 1
[1752:1752] Do system command cat /sys/kernel/debug/ion/heaps/ion_cma | grep -w 1752 | grep -w libhbmem_sample.
libhbmem_sample 1752 4194304
libhbmem_sample 1752 other 4194304 0
[1752:1752] Result 0.
free com buf
[1752:1752] Result 256.
sample_alloc_com_buf done
(Other execution output examples retain the original text structure, with only formatting and keyword adjustments applied; repetitive content omitted here.)
