4.1.3.3. Other Algorithm Model Samples
Other algorithm model samples refer to the samples in the 05_miscellaneous/ and 06_custom_op/ folders. Amongst, the 05_miscellaneous/ folder contains miscellaneous samples used for other features in the X3 Toolchain, e.g. how to enable the RGB data trained model receives YUV data at Runtime using D-Robotics’ model conversion Toolchain. The 06_custom_op/ folder is a user custom OP sample helps developers understand how to add custom OP when there are Toolchain unsupported OPs.
Usages and directories of the above mentioned samples please refer to below contents.
4.1.3.3.1. How to Use
Each sample is encapsulated into a shell script in order. Run shell scripts in order to understand usage of corresponding tools, API features and usage etc.
4.1.3.3.2. Miscellaneous Samples
4.1.3.3.2.1. lenet_gray
4.1.3.3.2.1.1. Directory
01_lenet_gray/
└── mapper
    ├── 00_init.sh                  // Obtain the model and calibration dataset required for the current sample
    ├── 01_check.sh                 // Check model validity
    ├── 02_get_mnist.sh             // Obtain the calibration dataset
    ├── 03_build.sh                 // Convert the debugging model
    ├── 04_inference.sh             // Run inference using the onnx runtime
    ├── README.md
    ├── lenet_gray_config.yaml
    ├── postprocess.py
    ├── preprocess.py
    └── process_mnist.py
4.1.3.3.2.1.2. Description
This section contains model conversion, simulator runtime and on-board runtime samples of gray image models.
4.1.3.3.2.2. resnet50_feature
4.1.3.3.2.2.1. Directory
02_resnet50_feature
└── mapper
    ├── 02_build.sh                 // Convert the debugging model
    ├── 03_inference.sh             // Run inference using the onnx runtime
    ├── README.md
    ├── inference.py
    └── resnet50_feature_config.yaml
4.1.3.3.2.2.2. Description
This section contains model conversion, simulator runtime and on-board runtime samples of resnet50_feature.
4.1.3.3.2.3. vector-diff
4.1.3.3.2.3.1. Directory
03_vector_diff
└── mobilenet_mapper
    ├── 01_inference_rt.sh
    ├── 02_vec_diff.sh                  // Analyze output data using the vec_diff tool
    ├── ILSVRC2012_val_00000001.bin
    └── README.md
4.1.3.3.2.3.2. Output List
Some CSV list(s) whose filename(s) is/are specified by the vec_diff -o command. In which: Left Files, Right Files, Cosine Similarity,Relative Euclidean Distance, Max Absolute Error and Mean Square Error. See below:
Left Files
Right Files
Cosine Similarity
Max Absolute Error
Mean Square Error
Layerxxx-quanti-input.txt
Layerxxx-float-input.txt
xxx
xxx
xxx
xxx
Layerxxx-quanti-param.txt
Layerxxx-float-param.txt
xxx
xxx
xxx
xxx
4.1.3.3.2.4. multi_input_example
4.1.3.3.2.4.1. Directory
04_multi_input_example
└── mapper
    ├── 02_preprocess.sh            // Run model preprocess
    ├── 04_inference.sh             // Inference a single image
    ├── README.md
    ├── data_preprocess.py
    ├── data_transformer.py
    ├── inference.py
    └── mobilenetv2_multi_config.yaml
4.1.3.3.2.4.2. Description
This section contains model conversion, simulator runtime and on-board runtime samples of multi-input models.
4.1.3.3.2.5. model_verifier
4.1.3.3.2.5.1. Directory
07_model_verifier
├── 01_preprocess.sh                // Run model preprocess
├── 03_model_verify.sh              // Run model verification
├── calibration_data_feature
├── preprocess.py
├── README.md
├── mobilenet_config_bgr.yaml
├── mobilenet_config_yuv444.yaml
└── resnet50_featuremap_config.yaml
4.1.3.3.2.5.2. Description
This section contains samples of model verification tool.
4.1.3.3.2.6. model_info
4.1.3.3.2.6.1. Directory
08_model_info
├── 03_model_info_check.sh          // Obtain and print model information
├── README.md
├── mobilenet_config.yaml
└── preprocess.py
4.1.3.3.2.6.2. Description
This section contains a samples of the model validation tool.
4.1.3.3.2.7. mobilenet_bgr
4.1.3.3.2.7.1. Directory
09_mobilenet_bgr
└── mapper
    ├── 02_preprocess.sh          // Preprocess the dataset
    ├── README.md
    ├── postprocess.py
    └── preprocess.py
4.1.3.3.2.7.2. Description
This is a sample of the MobileNetv1 model whose input_type_rt is specified as bgr.
4.1.3.3.2.8. mobilenet_yuv444
4.1.3.3.2.8.1. Directory
10_mobilenet_yuv444
└── mapper
    ├── README.md
    ├── postprocess.py
    └── preprocess.py
4.1.3.3.2.8.2. Description
This is a sample of the MobileNetv1 model whose input_type_rt is specified as yuv444.
4.1.3.3.3. User Custom OP Sample
4.1.3.3.3.1. Directory
06_custom_op
└── mapper
    ├── 00_init.sh
    ├── 03_build.sh
    ├── 04_inference.sh
    ├── README.md
    ├── create_onnx.py
    ├── custom_op_config.yaml
    ├── custom_op_inference.py
    └── horizon_ops.py
4.1.3.3.3.2. Description
When converting the open-source framework trained floating-point model into fixed-point model, the conversion will fail if there are Toolchain unsupported OP(s). In such case, developers can still convert the model by adding custom OP using the custom OP feature.
The mapper folder contains the scripts and configuration file required by running this sample.
