1.2.2.2 Bootloader (NAND) firmware flashing
Overview​
Bootloader flashing writes low-level firmware (e.g. Miniboot, U-Boot) to NAND Flash. It handles power-on initialization and loading the OS. Use it when the board will not boot, the bootloader is damaged, or you must update the boot stack.
About NAND firmware
  • The minimal RDK system in NAND includes Bootloader (Miniboot, U-Boot).
  • Boards ship with matching NAND firmware.
  • Do not downgrade; that can brick the device.
  • If the device does not boot, reflash NAND firmware.
Flashing tool​
RDK X3 Module bootloader flashing uses hbupdate on a PC.
hbupdate​
  • Local image files.
  • Windows.
  • Fastboot-based Bootloader flashing.
Download​
[Click here] and choose the package for your OS and firmware.
Installation​
Windows
  1. Extract the hbupdate archive.
    Note
    Extract to a path without spaces, non-ASCII characters, or special symbols.
  2. Double-click the .exe to launch hbupdate.
Firmware download​
[Click here] and download the .img for your product capacity.
Flashing steps​
Driver check​
On Windows, confirm drivers before using the tool.
  1. Connect the carrier Micro USB (flashing port) to the PC.
  2. Power on. If USB download gadget is unknown, install/update the driver.
Download and install the driver​
  1. [Click here] to download and extract android_hobot.zip.
  2. Run 5-runasadmin_register-CA-cer.cmd as Administrator.
  3. Update the USB download gadget driver from the extracted folder.
  4. Android Device should appear when done.
Flash the firmware​
Run hbupdate.exe:
  1. Board model (required):
    • RDK_X3_2GB: RDK X3 (Sunrise X3 Pi), 2GB—minimal image only.
    • RDK_X3_4GB: RDK X3 (Sunrise X3 Pi), 4GB—minimal image only.
    • RDK_X3_MD_2GB: RDK X3 Module, 2GB.
    • RDK_X3_MD_4GB: RDK X3 Module, 4GB.
  2. Click Browse and select the image (required).
  3. Click Start:
  4. Power off, disconnect USB, remove the BOOT jumper, and power on again.
If boot is OK, the ACT LED shows two fast blinks and one slow blink.
Verify the result​
  • Success:
  • Failure—confirm Android Device exists:
