USB Camera Real-Time Detection
Example Introduction
The USB camera real-time detection example is located at /app/pydev_demo/07_usb_camera_sample/, providing a Python interface for real-time object detection. It demonstrates how to use hbm_runtime with the YOLOv5X model to perform inference on USB camera footage and display the detection results in a window in real-time.
Included model example:
root@ubuntu:/app/pydev_demo/07_usb_camera_sample$ tree -L 1
├── coco_classes.names
└── usb_camera_yolov5x.py
Effect Demonstration
Note: Since this example pops up a window to display detection results, it needs to be run in a graphical environment. For server version images, it is recommended to use remote tools such as MobaXterm that support X11 forwarding to connect to the development board, allowing the display window to appear on your local computer.
The example reads the USB camera feed in real-time, detects objects in the screen, and overlays bounding boxes, class labels, and confidence scores on the window in real-time.
Hardware Preparation
Hardware Connection
- One RDK development board
- One USB camera (connected to the USB port of the development board)
- Connect power cable and network cable
Quick Start
Code Location on Board
Enter /app/pydev_demo/07_usb_camera_sample/ to see the example files:
root@ubuntu:/app/pydev_demo/07_usb_camera_sample# tree
Compilation and Execution
Python examples do not require compilation; just run them directly:
cd /app/pydev_demo/07_usb_camera_sample
python usb_camera_yolov5x.py
Press the q key to exit (make sure the mouse focus is on the display window).
Execution Effect
After running, the program will automatically find an available USB camera device and start real-time object detection. The detection results will be displayed in a window. Place the mouse focus on the display window and press q to exit the entire program.
root@ubuntu:/app/pydev_demo/07_usb_camera_sample# python usb_camera_yolov5x.py
Opening video device: /dev/video0
Open USB camera successfully
[A][DNN][packed_model.cpp:247][Model](2026-01-20,19:02:15.744.442) [HorizonRT] The model builder version = 1.23.5
[W][DNN]bpu_model_info.cpp:491][Version](2026-01-20,19:02:15.859.240) Model: yolov5s_v2_672x672_bayese_nv12. Inconsistency between the hbrt library version 3.15.55.0 and the model build version 3.15.47.0 detected, in order to ensure correct model results, it is recommended to use compilation tools and the BPU SDK from the same OpenExplorer package.
Place the mouse in the display window and press 'q' to quit
Detailed Introduction
Example Program Parameter Options
| Parameter | Description | Type | Default Value |
--model-path | BPU quantized model path (.bin) | str | /app/model/basic/yolov5s_672x672_nv12.bin |
--priority | Inference priority (0~255, 255 highest) | int | 0 |
--bpu-cores | BPU core index list (e.g., 0 1) | int list | [0] |
--label-file | Class label path | str | coco_classes.names |
--resize-type | Preprocessing resize method (0 direct scaling, 1 letterbox scaling) | int | 1 |
--classes-num | Number of detection classes | int | 80 |
--nms-thres | NMS IoU threshold | float | 0.45 |
--score-thres | Confidence threshold | float | 0.25 |
This section introduces the software architecture and workflow of the USB camera example, explaining the entire execution process from model loading to result output, helping developers understand the overall code structure and data flow.
- Camera Detection and Opening - Automatically search
/dev/video*and open the first available USB camera, set resolution and frame rate - Model Loading - Load the model file using the
hbm_runtimemodule - Image Loading - Read real-time image frames
- Image Preprocessing - Scale camera frames to model input size, convert BGR to NV12, and organize tensors according to model input format
- Model Inference - Execute YOLOv5X forward inference on the BPU
- Result Post-processing - Dequantize outputs, decode prediction boxes, confidence filtering and NMS, map coordinates back to original image
- Visualization Output - Draw bounding boxes, class labels, and confidence scores on the image, display in real-time window, exit with
q
API Flow Description
This section lists the main API interfaces used in the example program, explaining the functionality, input parameters, and return values of each interface, helping developers quickly understand the code implementation details and interface calling methods. Interfaces prefixed with cv2. are general interfaces from the OpenCV library, while the others are custom interfaces from D-Robotics.
find_first_usb_camera()Automatically search for USB camera
cv2.VideoCapture(device)Open the camera
hbm_runtime.HB_HBMRuntime(model_path)Load the quantized model, input: model path
load_class_names(label_file)Load class names, input: class file path
cap.read()Get image frame
resized_image(img, input_W, input_H, resize_type)Image scaling, input: image, target width, target height, resize type, return: scaled image
bgr_to_nv12_planes(image)Convert BGR to NV12 format, input: BGR image, return: y plane, uv plane
model.run(input_data)Execute model inference, input: preprocessed image data, return: model output
dequantize_outputs(outputs, output_quants)Dequantize results, input: model output, specified type, return: dequantized results
decode_outputs(output_names, fp32_outputs, STRIDES, ANCHORS, classes_num)Decode model output, input: output name list, model output, strides, anchors, number of classes, return: prediction results
filter_classification(cls_output, conf_thres)Filter prediction results, input: classification output, confidence threshold, return: confidence scores, class IDs, valid indices
NMS(dbboxes, scores, ids, nms_thresh)Non-maximum suppression, input: detection boxes, confidence scores, classes, IoU threshold, return: retained indices
scale_coords_back(boxes, img_w, img_h, input_W, input_H, resize_type)Scale detection boxes back to original image size, input: detection boxes, original image width, original image height, model input width, model input height, resize method, return: scaled detection boxes
draw_boxes(img, boxes, ids, scores, coco_names, rdk_colors)Draw detection results, input: image, detection boxes, class IDs, confidence scores, class list, color mapping
cv2.imshow(...)/cv2.waitKey(1)
Display and exit with key press
FAQ
Q: What to do if the error "No USB camera found" occurs?
A: Make sure the camera is plugged in and a video* device exists under /dev; try v4l2-ctl --list-devices to check.
Q: What if the model file does not exist?
A: Check if --model-path is correct, and look for the corresponding model under /app/model/basic.
Q: Video lag or stuttering?
A: Reduce the camera resolution or frame rate, or decrease the model input size.
Q: How to exit the program?
A: Place the mouse focus on the display window and press the q key to exit.
