9.2 Linux Command Usage
📄️ rsync
Rsync is a fast and powerful file copying tool. It can copy files locally or from another host using any remote shell, and it can also copy files with a remote rsync daemon. It provides numerous options that allow control over various aspects of its behavior and enables flexible specification of the files to be copied. Rsync is known for its incremental transfer algorithm, which reduces the amount of data sent over the network by only sending the differences between the source and existing files in the target. Rsync is widely used for backup and mirroring operations, as well as an improved alternative to the standard copy command for everyday use.
📄️ tar
The tar command can be used to create archives for files and directories in Linux. With tar, you can create archives (backup files) for specific files, modify files within an archive, or add new files to an archive. Tar was originally used to create archives on tapes, but now users can create archives on any device. Using the tar command, you can pack a large number of files and directories into a single file, which is very useful for backing up files or combining multiple files into one file for network transmission.
