PWM 驱动调试指南
X3 有两类控制器:一类是标准 PWM,有 3 组,每组三个,共 9 个,另一类是 LPWM,主要用于支持 Sensor 的同步曝光。
  • PWM 默认支持频率范围是 192MHz 到 46.8KHz,每组 PWM 的占空比寄存器 RATIO 精度为 8bit。
  • LPWM 默认支持频率范围是 100KHz 到 24.4Hz,没有占空比寄存器,只有一个高电平持续时间 HIGH,HIGH 寄存器配置单位是 us,最大支持设置高电平为 160us,所以 LPWM 的占空比与频率有关。
  • LPWM 是为了 Sensor 同步设计的,不是一个通用的 PWM,单纯 PWM 功能建议使用 PWM。
驱动代码​
代码路径​
drivers/pwm/pwm-hobot.c
内核配置​
Device Drivers
-> Pulse-Width Modulation (PWM) Support
-> Hobot PWM controller support
-> Hobot lite PWM controller support
DTS 节点配置​
在hobot-xj3.dtsi这个文件里面有pwm和lpwm的配置,一般来讲不需要做任何修改。
/* arch/arm64/boot/dts/hobot/hobot-xj3.dtsi */
lpwm: lpwm@0xA500D000 {
compatible = "hobot,hobot-lpwm";
reg = <0 0xA5018000 0 0x1000>;
interrupt-parent = <&gic>;
interrupts = <0 68 4>;
pinctrl-names = "lpwm0", "lpwm1","lpwm2","lpwm3", "lpwm_pps";
pinctrl-0 = <&lpwm0_func>;
pinctrl-1 = <&lpwm1_func>;
pinctrl-2 = <&lpwm2_func>;
pinctrl-3 = <&lpwm3_func>;
pinctrl-4 = <&lpwm_pps>;
clocks = <&lpwm_mclk>;
clock-names = "lpwm_mclk";
status = "disabled";
pwm_c0: pwm@0xA500D000 {
compatible = "hobot,hobot-pwm";
#pwm-cells = <3>;
reg = <0 0xA500D000 0 0x1000>;
interrupts = <0 44 4>;
pinctrl-names = "pwm0", "pwm1","pwm2";
pinctrl-0 = <&pwm0_func>;
pinctrl-1 = <&pwm1_func>;
pinctrl-2 = <&pwm2_func>;
clocks = <&pwm0_mclk>;
clock-names = "pwm_mclk";
当需要使能对应串口的时候,可以到对应的板级文件修改,这里以hobot-x3-sdb_v4.dts为例,使能pwm0-2、pwm3-5。
/* arch/arm64/boot/dts/hobot/hobot-x3-sdb_v4.dts */
&pwm_c0 {
pinctrl-1 = <>;
pinctrl-2 = <>;
&pwm_c1 {
pinctrl-0 = <>;
pinctrl-1 = <&pwm4_func>;
pinctrl-2 = <>;
测试​
用户可以使用如下脚本进行pwm功能测试,并进行信号测量,验证pwm工作是否正常。
echo 8 8 8 8  > /proc/sys/kernel/printk
for i in 0 3
do
cd /sys/class/pwm/pwmchip${i}
echo 0 > export
echo 1 > export
echo 2 > export
cd pwm0
echo 10000 > period
echo 3000 > duty_cycle
echo 1 > enable
cd ../pwm1
echo 10000 > period
echo 1000 > duty_cycle
echo 1 > enable
cd ../pwm2
echo 10000 > period
echo 1 > enable
done
#以下是进行寄存器读取
echo "pwm0 pinctrl:`devmem 0xa6004010 32`"
echo "pwm1 pinctrl:`devmem 0xa6004058 32`"
echo "pwm2 pinctrl:`devmem 0xa600405C 32`"
echo "pwm3 pinctrl:`devmem 0xa6004060 32`"
echo "pwm4 pinctrl:`devmem 0xa6004064 32`"
echo "pwm5 pinctrl:`devmem 0xa6004048 32`"
echo "pwm6 pinctrl:`devmem 0xa600404C 32`"
echo "pwm7 pinctrl:`devmem 0xa6004030 32`"
echo "pwm8 pinctrl:`devmem 0xa6004034 32`"
echo "Regs of PWM 0 1 2:"
echo "PWM_EN `devmem 0xA500d000 32`"
echo "PWM_SLICE `devmem 0xA500d004 32`"
echo "PWM_FREQ `devmem 0xA500d008 32`"
echo "PWM_FREQ1 `devmem 0xA500d00C 32`"
echo "PWM_RATIO `devmem 0xA500d014 32`"
echo "PWM_SRCPND `devmem 0xA500d01C 32`"
echo "PWM_INTMASK `devmem 0xA500d020 32`"
echo "Regs of PWM 3 4 5:"
echo "PWM_EN `devmem 0xA500e000 32`"
echo "PWM_SLICE `devmem 0xA500e004 32`"
echo "PWM_FREQ `devmem 0xA500e008 32`"
echo "PWM_FREQ1 `devmem 0xA500e00C 32`"
echo "PWM_RATIO `devmem 0xA500e014 32`"
echo "PWM_SRCPND `devmem 0xA500e01C 32`"
echo "PWM_INTMASK `devmem 0xA500e020 32`"
