7.1.3 RDK S100 Hardware Bringup
The S100 boardid is determined by the combined effect of ADC0, ADC1, ADC3, and ADC4. Among these, ADC0 and ADC1 are used for Donggua hardware differentiation and cannot be modified by the customer; ADC3 is used to identify the power-up sequence of Acore peripherals, allowing customers to customize the power-up sequence and modify the ADC3 voltage divider resistor accordingly; ADC4 is used to identify the hardware version. For details on how to set the ADC voltage divider resistors, please contact the Donggua FAE team for support.
Each ADC channel has 16 levels, corresponding to 0x0~0xF. The boardid of the S100 is a 16-bit unsigned integer, for example 0x6A84, where boardid[15:12] corresponds to ADC0 as 0x6; boardid[11:8] corresponds to ADC1 as 0xA; boardid[7:4] corresponds to ADC3 as 0x8; boardid[3:0] corresponds to ADC4 as 0x4.
The boardid is formed by ADC sampling and implemented in SBL. This part is closed-source code, and customers do not need to worry about it.
Adding Hardware Under MCU
Note
What needs to be done on the MCU side is to implement your own power-up method for Acore peripherals. If you are following Donggua's design, customers do not need to modify the MCU and can ignore this part.
Adding Acore Peripheral Power Management Code
Boot Stage
In the file mcu/McalCdd/Common/Power/S100/scp/boot/src/main_top_init.c, within the function Rdk_S100_Peri_Pwr_Init, add the power-up code.
static Std_ReturnType Rdk_S100_Peri_Pwr_Init(void)
Std_ReturnType CheckStatus = (Std_ReturnType)E_OK;
uint32 AdcCode3 = 0U;
AdcCode3 = *((uint32 *)AON_SRAM_ADC + 3U);
switch (AdcCode3)
case 0x6:
case 0x7:
CheckStatus = Rdk_S100_Peri_Pwr_Init_V121();
break;
case 0x8:
CheckStatus = Rdk_S100_Peri_Pwr_Init_V0P5();
break;
default:
break;
return CheckStatus;
As shown in the code, different Acore peripheral power-up flows are followed based on the ADC3 level. If the customer customizes the Acore peripheral power-up method, they need to assign a new ADC3 level and implement their own power-up method.
Power-Down Stage of reboot/suspend
In this stage, power-down operations need to be implemented.
In the file mcu/McalCdd/Common/Power/S100/scp/Drivers/src/Pmu.c, within the function Pmu_MainDomainPeriOff, add the power-down code.
Std_ReturnType Pmu_MainDomainPeriOff(void)
switch (AdcCode3)
case 0x6:
case 0x7:
CheckStatus = Pmu_MainDomainPeriOffV121();
break;
case 0x8:
CheckStatus = Pmu_MainDomainPeriOffV0P5();
break;
default:
break;
return CheckStatus;
Power-Up Stage of reboot/resume
In this stage, power-up operations need to be implemented.
In the file mcu/McalCdd/Common/Power/S100/scp/Drivers/src/Pmu.c, within the function Pmu_MainDomainPeriOn, add the power-up code.
static Std_ReturnType Pmu_MainDomainPeriOn(void)
switch (AdcCode3)
case 0x6:
case 0x7:
CheckStatus = Pmu_MainDomainPeriOnV121();
break;
case 0x8:
CheckStatus = Pmu_MainDomainPeriOnV0P5();
break;
default:
break;
return CheckStatus;
Adding Hardware Under spl and Uboot
spl refers to the spl under Uboot.
Adding Configuration Files
The Uboot configuration files are located in the SDK directory source/bootloader/uboot/configs. The configuration file for debug mode is hobot_s100_defconfig, and for release mode it is hobot_s100_rel_defconfig.
The Uboot configuration file is specified in the bootloader board-level configuration file. For the debug configuration file, the path is source/bootloader/device/rdk/s100/board_s100_debug.mk, and the variable HR_UBOOT_CONFIG_FILE specifies the Uboot configuration file.
# hobot_s100_defconfig
export HR_UBOOT_CONFIG_FILE=hobot_s100_defconfig
export HR_UBOOT_OTA_CONFIG_FILE=hobot_s100_ota.config
export HR_ARCH_UBOOT="arm"
If customers have requirements, they can generate their own Uboot config file and replace it as described above. Generally, reusing Donggua's configuration is sufficient.
Adding Device Trees
The Uboot device tree file is located in the SDK directory source/bootloader/uboot/arch/arm/dts/drobot-s100-rdk.dts. The device tree is specified by the variable CONFIG_DEFAULT_DEVICE_TREE in the configuration file.
CONFIG_DEFAULT_DEVICE_TREE="drobot-s100-rdk"
If customers have requirements, they can add their own device tree files, ensuring to #include "drobot-s100-soc.dtsi" in their device tree file, then override it later, and finally replace it as described above. Generally, reusing Donggua's configuration is sufficient. When adding your own device tree file, ensure it is included in the Makefile for compilation.
Adding boardid
  1. Add socname, hwname, board version, and pcie mode based on boardid.
Add board information to the g_board_info array in the file source/bootloader/uboot/arch/arm/mach-hobot/super/boot_info.c.
/* arch/arm/mach-hobot/super/boot_info.c */
/* hb_boardinfo_t structure information
struct hb_boardinfo_t {
uint32_t board_id;
char* soc_name;
char* hw_name;
char* pcie_mode;
char* version;
struct hb_boardinfo_t g_board_info[BOARD_TYPE_NUM] = {
/* S100P */
{0x6460, "S100P", "RDK", "rc", "V1.21"},
{0x6470, "S100P", "RDK", "rc", "V1.2"},
{0x6484, "S100P", "RDK", "rc", "V0P5"},
{0x6485, "S100P", "RDK", "rc", "V0P6"},
{0x6486, "S100P", "RDK", "rc", "V1P0"},
{0x6487, "S100P", "RDK", "rc", "V1P1"},
{0x6560, "S100P", "RDK", "ep", "V1.21"},
{0x6570, "S100P", "RDK", "ep", "V1.2"},
{0x6584, "S100P", "RDK", "ep", "V0P5"},
{0x6585, "S100P", "RDK", "ep", "V0P6"},
{0x6586, "S100P", "RDK", "ep", "V1P0"},
{0x6587, "S100P", "RDK", "ep", "V1P1"},
/* S100 */
{0x6A60, "S100", "RDK", "rc", "V1.21"},
{0x6A70, "S100", "RDK", "rc", "V1.2"},
{0x6A84, "S100", "RDK", "rc", "V0P5"},
{0x6A85, "S100", "RDK", "rc", "V0P6"},
{0x6A86, "S100", "RDK", "rc", "V1P0"},
{0x6A87, "S100", "RDK", "rc", "V1P1"},
{0x6B60, "S100", "RDK", "ep", "V1.21"},
{0x6B70, "S100", "RDK", "ep", "V1.2"},
{0x6B84, "S100", "RDK", "ep", "V0P5"},
{0x6B85, "S100", "RDK", "ep", "V0P6"},
{0x6B86, "S100", "RDK", "ep", "V1P0"},
{0x6B87, "S100", "RDK", "ep", "V1P1"},
  1. Add Kernel configuration based on boardid.
Add Kernel configuration to the hb_super_btype_list array in the file source/bootloader/uboot/arch/arm/mach-hobot/super/super_board.c.
/* arch/arm/mach-hobot/super/super_board.c */
/* hb_super_btype_node structure
struct hb_super_btype_node {
uint32_t boardid_adc0;
uint32_t boardid_adc1;
uint32_t boardid_adc3;
uint32_t boardid_adc4;
char fdt_feat[32];
char pxe_label[32];
const static struct hb_super_btype_node hb_super_btype_list[] = {
{0x6, 0x4, 0x6, 0x0, "rdk-s100-v1-21", "drobot-s100-rdk-v1-21-kernel"},
{0x6, 0x5, 0x6, 0x0, "rdk-s100-v1-21", "drobot-s100-rdk-v1-21-kernel"},
{0x6, 0xA, 0x6, 0x0, "rdk-s100-v1-21", "drobot-s100-rdk-v1-21-kernel"},
{0x6, 0xB, 0x6, 0x0, "rdk-s100-v1-21", "drobot-s100-rdk-v1-21-kernel"},
{0x6, 0x4, 0x7, 0x0, "rdk-s100-v1-2", "drobot-s100-rdk-v1-2-kernel"},
{0x6, 0x5, 0x7, 0x0, "rdk-s100-v1-2", "drobot-s100-rdk-v1-2-kernel"},
{0x6, 0xA, 0x7, 0x0, "rdk-s100-v1-2", "drobot-s100-rdk-v1-2-kernel"},
{0x6, 0xB, 0x7, 0x0, "rdk-s100-v1-2", "drobot-s100-rdk-v1-2-kernel"},
{0x6, 0x4, 0x8, 0x4, "rdk-s100p-v0p5", "drobot-s100p-rdk-v0p5-kernel"},
{0x6, 0x5, 0x8, 0x4, "rdk-s100p-v0p5", "drobot-s100p-rdk-v0p5-kernel"},
{0x6, 0xA, 0x8, 0x4, "rdk-s100-v0p5", "drobot-s100-rdk-v0p5-kernel"},
{0x6, 0xB, 0x8, 0x4, "rdk-s100-v0p5", "drobot-s100-rdk-v0p5-kernel"},
{0x6, 0x4, 0x8, 0x5, "rdk-s100p-v0p6", "drobot-s100p-rdk-v0p6-kernel"},
{0x6, 0x5, 0x8, 0x5, "rdk-s100p-v0p6", "drobot-s100p-rdk-v0p6-kernel"},
{0x6, 0xA, 0x8, 0x5, "rdk-s100-v0p6", "drobot-s100-rdk-v0p6-kernel"},
{0x6, 0xB, 0x8, 0x5, "rdk-s100-v0p6", "drobot-s100-rdk-v0p6-kernel"},
{0x6, 0x4, 0x8, 0x6, "rdk-s100p-v1p0", "drobot-s100p-rdk-v1p0-kernel"},
{0x6, 0x5, 0x8, 0x6, "rdk-s100p-v1p0", "drobot-s100p-rdk-v1p0-kernel"},
{0x6, 0xA, 0x8, 0x6, "rdk-s100-v1p0", "drobot-s100-rdk-v1p0-kernel"},
{0x6, 0xB, 0x8, 0x6, "rdk-s100-v1p0", "drobot-s100-rdk-v1p0-kernel"},
{0x6, 0x4, 0x8, 0x7, "rdk-s100p-v1p1", "drobot-s100p-rdk-v1p1-kernel"},
{0x6, 0x5, 0x8, 0x7, "rdk-s100p-v1p1", "drobot-s100p-rdk-v1p1-kernel"},
{0x6, 0xA, 0x8, 0x7, "rdk-s100-v1p1", "drobot-s100-rdk-v1p1-kernel"},
{0x6, 0xB, 0x8, 0x7, "rdk-s100-v1p1", "drobot-s100-rdk-v1p1-kernel"},
In hb_super_btype_node, fdt_feat is the name of the Kernel dtb, and pxe_label is the Kernel configuration in extlinux. The names must correspond to each other.
Adding Hardware Under Kernel
The Kernel configuration files are located in the SDK directory source/hobot-drivers/configs. The configuration file corresponding to the S100 is drobot_s100_defconfig.
The Kernel configuration file is specified in mk_kernel.sh.
# mk_kernel.sh
export KERNEL_DEFCONFIG=drobot_s100_defconfig
If customers have requirements, they can generate their own Kernel config file and replace it as described above. Generally, reusing Donggua's configuration is sufficient.
Adding Device Trees
The Kernel device tree files are located in the SDK directory source/hobot-drivers/kernel-dts.
If customers have requirements, they can add their own device tree files, ensuring to #include "rdk-v0p5.dtsi" in their device tree file, then override it later. Generally, reusing Donggua's configuration is sufficient. When adding your own device tree file, ensure it is included in the Makefile for compilation.
The naming of the dtb needs to correspond to the fdt_feat in the hb_super_btype_list array in source/bootloader/uboot/arch/arm/mach-hobot/super/super_board.c.
extlinux Configuration
In the S100, Uboot parses the Kernel configuration based on extlinux and selects the corresponding dtb, Kernel image, and initramfs to load.
The extlinux file is located at source/kernel/scripts/package/rdk_extlinux.
Take the RDK-S100-V1P1 version as an example:
label drobot-s100-rdk-v1p1-kernel
kernel /vmlinuz-KERNEL_VERSION
fdt /hobot/rdk-s100-v1p1.dtb
initrd /initrd.img-KERNEL_VERSION
The label must correspond to the pxe_label in the hb_super_btype_list array in source/bootloader/uboot/arch/arm/mach-hobot/super/super_board.c.
The rdk-s100-v1p1.dtb in fdt must be consistent with the naming of the Kernel device tree to be used.
Loading ko Based on boardid
In the file source/hobot-utils/debian/usr/bin/hobot-loadko.sh, it is necessary to choose whether to load the pcie driver and asm3042 firmware based on the boardid.
boardid_sys_path="/sys/class/boardinfo/adc_boardid"
if [ -f "$boardid_sys_path" ]; then
boardid="$(cat $boardid_sys_path)"
if [[ "$boardid" =~ ^0x(64|65|6A|6B)[0678][04567]$ ]];then
case ${boardid} in
*"0")
# Check if TPIC2810 exists, if so, manual reset USB controller
if [ -f /sys/class/i2c-adapter/i2c-2/2-0060/name ] &&
[ "$(cat /sys/class/i2c-adapter/i2c-2/2-0060/name)" = "tpic2810" ];then
/usr/bin/pcie-usb-reset.sh
fi
/usr/bin/start-pcie.sh &
*"7") ;&
*"6") ;&
*"5") ;&
*"4")
modprobe hobot-pcie-rc
# check & update asm3042 firmware
/usr/bin/update-asm3042-firmware.sh
esac
elif [[ "$boardid" =~ ^0x(51)[1234567][01234567][1234567][1234567].$ ]];then
# S600 Boardid rules
else
echo "<$LOG_WARN>Unsupported boardid:$boardid, PCIE not Initialized!" > /dev/kmsg
fi
fi
On-Board Debugging
When debugging on the board, it is recommended to use the debug image, as the release image disables most logs, making it impossible to locate issues when problems occur.
Method to compile the debug image:
In the script pack_image.sh, the default configuration selects the beta configuration.
Check if the Boot Information Matches Expectations
  • The SBL log will print the ADC level values.
[00.023702 0]Adc:0:1116:0x6
[00.024039 0]Adc:1:2403:0xa
[00.024376 0]Adc:2:1765:0x8
[00.024712 0]Adc:3:1738:0x8
[00.025049 0]Adc:4:632:0x4
  • The spl log will print the ADC level values.
U-Boot SPL 2022.04-00905-g5272120b20 (Feb 28 2026 - 08:51:01 +0800)
boot_flags.boardid_adc_ch0 0x6
boot_flags.boardid_adc_ch1 0xa
boot_flags.boardid_adc_ch3 0x8
boot_flags.boardid_adc_ch4 0x4
  • The Uboot log will print the Model, which can determine whether it is consistent with the definition in the Uboot dts.
U-Boot 2022.04-00905-g5272120b20 (Feb 28 2026 - 08:51:01 +0800)
Model: D-Robotics S100 SIP Board
  • The Uboot log will print the boardid, for example, 6a84 below.
system_slot: 0 adc_boardinfo: 6a84
  • The Uboot log will print the label corresponding to extlinux, as well as the Kernel image, dtb, and initramfs.
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
3: drobot-s100-rdk-v0p5-kernel
Retrieving file: /initrd.img-6.1.158-rt58-DR-4.0.5-2602251559-g9f678e-g9b251c
Retrieving file: /vmlinuz-6.1.158-rt58-DR-4.0.5-2602251559-g9f678e-g9b251c
Retrieving file: /hobot/rdk-s100-v0p5.dtb
  • Check the board info in bootargs.
Mainly hobotboot.socname=S100 board.hwname=RDK board.ver=V0P5 board.pcie_mode=rc, etc., to see if they are consistent with the definitions in Uboot.
root@ubuntu:~# cat /proc/cmdline
console=ttyS0,921600n8 systemd.show-status=auto loglevel=1 hobot.kernel_in=nvme0 hobotboot.socname=S100 board.hwname=RDK board.ver=V0P5 board.pcie_mode=rc hobotboot.reason=hwreset hobotboot.slot_suffix=_a hobotboot.mode=normal hobotboot.secureboot=1 hobotboot.bootcount=1 systemd.unified_cgroup_hierarchy=0 hobotboot.serial=060c049530906941 clk_ignore_unused earlycon=uart8250,mmio32,0x394B0000 no_console_suspend root=/dev/ram0 rdinit=/init rootwait net.ifnames=0 root=/dev/nvme0n1p17 rw rootfstype=ext4 rootwait
  • View board info in the Kernel command line.
root@ubuntu:~# cd /sys/class/boardinfo/
root@ubuntu:/sys/class/boardinfo# ls
adc_boardid board_name bootdevice_name chip_id ddr_size ddr_type hw_name hw_version pcie_mode soc_gen soc_name soc_uid
root@ubuntu:/sys/class/boardinfo# cat *
0x6A84
S100_RDK_V0P5
nvme0
21845505
0x2fff
LPDDR5
RDK
V0P5
rc
s100
S100
060c0495309069410f94dc4c00001079
