2.5. 使用ROS2 package
前提:已成功安装TogetheROS.Bot
tros.b foxy版本接口完全兼容,能够复用ROS丰富工具包,这里以安装和使用ROS foxy版本ros-foxy-image-transport为例介绍如何在tros.b中使用ROS package。
安装ROS2 package
1 添加ROS apt源
添加ROS apt源
sudo apt update && sudo apt install curl gnupg2 lsb-release
sudo curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key  -o /usr/share/keyrings/ros-archive-keyring.gpg
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(source /etc/os-release && echo $UBUNTU_CODENAME) main" | sudo tee /etc/apt/sources.list.d/ros2.list > /dev/null
更新apt仓库
sudo apt update
2 安装packages
sudo apt install ros-foxy-image-transport
sudo apt install ros-foxy-image-transport-plugins
3 建立软连接
cd /opt/tros
## 使用/opt/tros目录下的create_soft_link.py创建ROS package至tros.b的软连接
sudo python3 create_soft_link.py --foxy /opt/ros/foxy/ --tros /opt/tros/
使用ROS2 package
与ROS使用一样
source /opt/tros/local_setup.bash
ros2 run image_transport list_transports
运行结果如下,展示了image_transport package支持的图像格式
root@ubuntu:/opt/tros# ros2 run image_transport list_transports
Declared transports:
image_transport/compressed
image_transport/compressedDepth
image_transport/raw
image_transport/theora
Details:
"image_transport/compressed"
 - Provided by package: compressed_image_transport
 - Publisher:
      This plugin publishes a CompressedImage using either JPEG or PNG compression.
 - Subscriber:
      This plugin decompresses a CompressedImage topic.
"image_transport/compressedDepth"
 - Provided by package: compressed_depth_image_transport
 - Publisher:
      This plugin publishes a compressed depth images using PNG compression.
 - Subscriber:
      This plugin decodes a compressed depth images.
"image_transport/raw"
 - Provided by package: image_transport
 - Publisher:
      This is the default publisher. It publishes the Image as-is on the base topic.
 - Subscriber:
      This is the default pass-through subscriber for topics of type sensor_msgs/Image.
"image_transport/theora"
 - Provided by package: theora_image_transport
 - Publisher:
      This plugin publishes a video packet stream encoded using Theora.
 - Subscriber:
      This plugin decodes a video packet stream encoded using Theora.
